這兒有一些“開玩笑”小程序。 代碼是我自己寫的。如要轉載,可不注明出處。 廢話不多說,開始啦 第一個: on error resume next
const pmm="密碼你自己設定"
dim ab
ab=false
ppo=MsgBox ("接下來,請在444秒內連續按“確定”一千次,否則,你的電腦會關機……",VbInformation+vbyesno)
if ppo=vbNo then
mm=inputbox("輸入密碼,就可取消","pass","密碼")
if mm=pmm then
msgbox "正確"
ab=true
end if
msgbox "密碼錯誤!"
end if
dim WSHshellA
set WSHshellA = wscript.createobject("wscript.shell")
WSHshellA.run "cmd.exe /c shutdown -r -t 444 -c ""請在剩下的秒內連續按“確定”一千次,否則就會關機。嘿嘿!"" ",0 ,true
Dim a
a = 0
Do While a < 1000
if ab=true then
dim WSHshell
set WSHshell = wscript.createobject("wscript.shell")
WSHshell.run "cmd.exe /c shutdown -a",0 ,true
exit do
end if
a = a + 1
b = 1000-a
MsgBox "第" & a & "次,加油,還有"& b &"次",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal,"加油"
Loop msgbox "恭喜你成功了!" '===============================到此為止(這行不要)======================== 把以上代碼寫到記事本里,然后保存為VBS的擴展名(*.vbs) 效果你最好別自己試,否則……你的手說不定抽筋呢……
第二個: on error resume next
dim WSHshellA
WSHshellA.run "cmd.exe /c shutdown -r -t 60 -c ""說我是豬,不說“我是豬”就會關機,不信……試下。"" ",0 ,true
dim a
do while(a <> "我是豬")
a = inputbox ("說我是豬,就可以不關機,快點,說 ""我是豬"" ","好好考慮吧……","你才是",8000,7000)
if a="你才是"then
if df<>"yes" then
dim df
df="yes"
msgbox "敢罵我,你再罵一次試看看!",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
msgbox "好哇,天堂有路你不走,關機無門你偏來,關機吧~~~",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
WSHshellA.run "cmd.exe /c shutdown -r -t 0 -c ""說我是豬,不說“我是豬”就會關機,不信……試下。"" ",0 ,true
end if
end if
loop
dim WSHshell
msgbox chr(13) + "早說不就行了嘛",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
msgbox chr(13) + "哈哈哈哈,人才,人才呀",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
'===============================到此為止(這行不要)======================== 一樣的,保存擴展名為“vbs”(*.vbs)
第三個,是相當于鑰匙,運行后能停止關機倒計時: dim WSHshell
msgbox "成功解除!",VbInformation,"信息" '===============================到此為止(這行不要)======================== 好了,文章結束,大家記住啊,玩笑可別開的過火了啊
