| B1_C | NUP4202 Diode-TVS Array | ON Semiconductor NUP4202W1T2G | Mouser 863-NUP4202W1T2G |
| B2_C |
| C10_C | 0805, 0.1μF, 50V capacitor | Panasonic-ECG ECJ-2FB1H104K | Stockroom A004-0005-043 |
| C11_C |
| C13_C |
| C15_C |
| C16_C |
| C2_C |
| C3_C |
| C4_C |
| C6_C |
| 8-Jul |
| C7_C |
| C9_C |
| C12_C | 0.079" through hole, 100μF aluminum electrolytic, 6.3V capacitor (DNP) | Panasonic-ECG ECE-A0JKA101 | Digikey P803-ND |
| C19_C | 0805, 10μF, 16V capacitor | Murata GRM21BR61C106KE15L | Stockroom A004-0008-060 |
| C20_C |
| C5_C |
| C8_C |
| C1_C | 0805, 1000pF, 50V capacitor | Panasonic-ECG ECJ-2VB1H102K | Stockroom A004-0008-005 |
| C14_C |
| C17_C | 10.00mm through hole, 100pF ceramic, 4000V safety capacitor | Murata DE1B3KX101KA5B | Mouser 81-DE1B3KX101KA5B |
| C18_C |
| F1_C | 0805, ferrite bead | Murata BLM21PG221SN1D | Digikey 490-1054-1-ND |
| F2_C |
| F3_C |
| F4_C |
| L1_C | 1210, common mode choke | TDK ACM3225-271-2P-T001 | Digikey 445-2032-1-ND (270Ω) |
| L2_C |
| TDK ACM3225-800-2P-T001 | Digikey 445-2030-1-ND (80Ω) |
| R1_C | 0805, 10kΩ resistor |
| Stockroom A003-0018-083 |
| R6_C |
| R7_C |
| R2_C | 0805, 24.0Ω 1% resistor | Rohm Semiconductor MCR10EZHF24R0 | Digikey RHM24.0CCT-ND |
| R3_C |
| R4_C |
| R5_C |
| R8_C | 0805 jumper | | DNP |
| R9_C |
| R10_C |
| SW1_C | switch, 1 position DIP | E-Switch KAJ01LAGT | Digikey EG4415-ND |
| U3_C | ADuM1100 iCoupler Digital Isolator | Analog Devices Inc. ADuM1100ARZ |
| U1_C | ADuM4160 Full/Low Speed USB Digital Isolator | Analog Devices Inc. ADuM4160BRWZ |
| U2_C | ADuM5000 Isolated DC-to-DC Converter | Analog Devices Inc. ADuM5000ARWZ |
| N/A | 2.07"L x 1.5"W x 1.06"H, 0.080" thick aluminum enclosure | Hammond Manufacturing 1590H | Digikey HM365-ND |
| N/A | 2m shielded USB A to USB B cable | Assmann Electronics Inc. AK672-2-R | Digikey AE9932-ND |
| J1_C and J2_C | 4 pin connector socket (comes as a 1 x 20 strip, break off as needed) | Mill-Max Manufacturing Corp. | Digikey ED6520-ND |
