4 | B1-4 | 330@100MHz | 0805 | B0805 300ohm@100MHz 2A BLM21PG331SN1D MURATA | MURATA | BLM21PG331SN1D |
5 | C10 C19-20 C25 C27 | 1uF | 0805 | C0805 1uF 25V ECJ-2VB1E104K PANASONIC | PANASONIC | ECJ-2VB1E104K |
1 | C12 | 1.0uF | 0603 | C0603 1.0uF 16V C1608X7R1C105K TDK | TDK | C1608X7R1C105K |
11 | C1-2 C6-7 C9 C14-16 C23 C30-31 | 0.1uF | 0603 | C0603 0.1uF 25V GRM188R71E104KA01D Murata | Murata | GRM188R71E104KA01D |
5 | C17-18 C21-22 C24 | 10uF | 1206 | C1206 10uF 25V YAGEO | YAGEO | CC1206ZKY5V8BB106 |
1 | C26 | 470pF | 0603 | C0603 470pF 50V 06033A471JAT2A AVX | AVX | 06033A471JAT2A |
2 | C3-4 | 1nF | 0603 | C0603 1nF 50V X7R0603HTTD102J KOA | KOA | X7R0603HTTD102J |
3 | C5 C11 C13 | 10nF | 0603 | C0603 10nF 16V 0603YC103KAT2A AVX | AVX | 0603YC103KAT2A |
3 | C8 C28-29 | 10uF | 0805 | C0805 10uF 10V GRM21BR61A106KE19L MURATA | MURATA | GRM21BR61A106KE19L |
3 | D1-3 | SBR2U30P1-7 | DIODE_S | Diode SBR2U30P1-7 Vf:0.5V@2A If:2A DIODES INC | DIODES INC | SBR2U30P1-7 |
8 | D4-11 |
| SOT23 | Schottky Diode BAT54S 200mA 30V DIODES INC | DIODES INC | BAT54S |
3 | F1-3 | 1uF | EMIF3TC_0805 | CAP 3T C-Type Chip EMIFIL CKD510JB1A105ST 10V TDK | TDK | CKD510JB1A105ST |
1 | J1 |
| CONRA-8P-200 | 8 Way, 5mm Pitch | CAMDEN | CTB1202/8 |
1 | J3 |
| 2P_200_45 | Terminal, 5.08mm, 2 Way | MULTICOMP | MC24356 |
1 | J4 |
| CON\5.08\3P | Screw Terminal MC24357 5.08mm 180(D) Multicomp | Multicomp | MC24357 |
1 | J5 |
| CON_120PIN_SMD | SDP Connector | Hirose | FX8-120S-SV(21) |
4 | JP1-4 |
| SIP-3P | 3Pin 2.54mm 22-03-2031 MOLEX | MOLEX | 22-03-2031 |
3 | PS1-3 | NANOSMDC035F | 1206 | Polyswitch NANOSMDC035F 350mA 30V TYCO | Tyco | NANOSMDC035F |
1 | R11 | NP | 0805 | SURFACE MOUNT RESISTOR 0.048 X 0.079 INCHES | IPC SM-782 STD. |
| 3 | R12-13 R20 | NP | 0603 | SURFACE MOUNT RESISTOR 0.031 X 0.061 INCHES, 1/10W | IPC SM-782 STD. |
| 2 | R14-15 | 100 | 0603 | R0603 100 1% 0.063W 200ppm MC 0.063W 0603 MULTICOMP | MULTICOMP | MC 0.063W 0603 |
7 | R16 R19 R21 R23 R25 R27 R34 | 100K | 0603 | R0603 100K 5% 1/10W 100ppm CRCW0603100KJNEA VASHAY | VASHAY | CRCW0603100KJNEA |
1 | R17 | 210K | 0603 | R0603 210K 1% 1/10W 100ppm ERJ-3EKF2103V PANASONIC | PANASONIC | ERJ-3EKF2103V |
1 | R18 | 64.9K | 0603 | R0603 64.9K 1% 63mW 100ppm ERJ-3EKF6492V PANASONIC | PANASONIC | ERJ-3EKF6492V |
8 | R1-8 | 1.5K | 0805 | R0805 1.5K 1% 100mW 100ppm CRCW08051K50FKEA VIshay | VIshay | CRCW08051K50FKEA |
12 | R22 R24 R26 R28-33 R35-37 | 33 | 0603 | R0603 33 1% 1/10W 100ppm CRCW060333R0FKEA VISHAY | VISHAY | CRCW060333R0FKEA |
2 | R9-10 | 4.02K | 0805 | R0805 4.02K 1% 125mW 100ppm ERJ-6ENF4021V PANASONIC | PANASONIC | ERJ-6ENF4021V |
10 | TVS1-2 TVS4-11 |
| DO-214AA | TVS SMBJ30CA 600W FAIRCHILD | BOURNS | SMBJ30CA |
1 | TVS3 | SMBJ10CA | DO-214AA | TVS SMBJ10CA 600W FAIRCHILD | FAIRCHILD | SMBJ10CA |
1 | U1 |
| RU-16 | 4 Ohm Ron, 4 - /8 - Channel ±15 V/+12 V/±5 V iCMOS Multiplexer | Analog Devices | ADG1409YRUZ |
1 | U2 |
| RM-8 | Wide Supply Range, Rail-to-Rail Output Instrumentation Amplifier | Analog Devices | AD8226ARMZ |
1 | U3 |
| RM-10 | Precision, Selectable Gain, Fully Differential Funnel Amp | Analog Devices | AD8475ARMZ |
1 | U4 |
| RM-8 | IC ADP3336 ADJ 500mA LDO ADI | Analog Devices | ADP3336ARMZ |
1 | U5 |
| RM-8 | Ultralow Noise, LDO XFET Voltage Reference with Current Sink and Source | Analog Devices | ADR444ARMZ |
1 | U6 |
| RM-8 | 50 mA, High Voltage, Micropower Linear 5V Regulator | Analog Devices | ADP1720ARMZ-5-R7 |
1 | U7 |
| RU-24 | 4.8 kHz Ultra-Low Noise 24-Bit Sigma-Delta ADC with PGA | Analog Devices | AD7192BRUZ |
1 | U8 | 74HC1G125GW | SOT353-1 | IC 74HC1G125GW NXP | NXP | 74HC1G125GW |
1 | U9 | 32K | SOIC8 | IC EEPROM I2C Bus 32K 24LC32A-I/SN MICROCHIP | MICROCHIP | 24LC32A-I/SN |
