//這樣就可以了,仿真通過(guò)
#include<reg51.h>
uint bai,shi,ge, num,num1,num2,num3;
sbit dula=P2^6;
sbit beep=P2^3;
sbit wela=P2^7;
uchar code table[10]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,
0x7d,0x07,0x7f,0x6f
void delayms(uchar max) //延時(shí)函數(shù)
uchar i,j;
for(i=max;i>0;i--)
for(j=110;j>0;j--);
void init() //定時(shí)器初始化
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=1;
void T0_time( ) interrupt 1 //中斷函數(shù)
num1++;
if(num1==20)
num1=0;
num3++;
if(num3==999)
num3=0;
bai=num3/100;
shi=num3%100/10;
ge=num3%10;
void display(uint bai,uint shi,uint ge) //顯示函數(shù)
wela=1;
P0=0xfe;
wela=0;
dula=1;
P0=table[bai];
dula=0;
P0=0xff;
delayms(5);
wela=1;
P0=0xfd;
wela=0;
dula=1;
P0=table[shi];
dula=0;
P0=0xff;
delayms(5);
wela=1;
P0=0xfb;
wela=0;
dula=1;
P0=table[ge];
dula=0;
P0=0xff;
delayms(5);
void main() //主函數(shù)
init();
display(bai,shi,ge);
