查看: 3631|回復: 3
調溫報警器.聯調后結果顯示就一個0.溫度傳感器是我后來加的.大神們能幫我看看錯誤在哪
ID:108510 發表于 2016-6-3 23:22 | 顯示全部樓層 |閱讀模式
50黑幣
本課程設計借助電路仿真軟件Protues對基于AT89C51單片機的溫度報警器的設計,設計的內容是由單片機、ADC0808作為溫度調節器、并由數碼管顯示的溫度報警器。當調節溫度小于60攝氏度或者高于160攝氏度,系統將產生不同頻率的聲音,并且對應的LED等閃爍。
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. uchar code DSY_CODE[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  5. uchar Temperature[]={0,0,0};
  6. sbit ST= P2^5;
  7. sbit OE= P2^7;
  8. sbit EOC =P2^6;
  9. sbit CLK =P2^4;
  10. sbit H_LED=P3^0;
  11. sbit L_LED=P3^1;
  12. sbit BEEP = P3^7;
  13. uchar t=0;
  14. void DelayMS(intnb x)
  15. {
  16. uchar i;
  17. while(x)
  18. for(i = 0;i< 120; i++);
  19. }
  20. void Show_Temperature()
  21. {
  22. uchar i,DSY_IDX[]= {0xF7,0xFB,0xFD};
  23. for  (i = 0;i < 3; i++)
  24. {
  25.    P0 = DSY_CODE[ Temperature[i] ];
  26.    P2 = DSY_IDX[i];
  27.    DelayMS(5);
  28.    P2 = 0x0F;
  29.   }
  30. }
  31. void main()
  32. {
  33.   uchar d;
  34.   IE = 0x8a;
  35.   TMOD = 18;
  36.   TH0 = 245;
  37.   TL0 = 0;
  38.   TH1 = (65536 -1000) /256;
  39.   TL1 = (65536 -1000) &256;
  40.   TR0 = 1;
  41.   H_LED = L_LED = 1;
  42.   while(1)
  43. {
  44.    ST = 0; ST = 1; ST = 0;
  45.    while(1)
  46.   {
  47.     if(EOC == 1)
  48.     {
  49.       OE = 1;
  50.       d  = P1;
  51.       OE = 0;
  52.       Temperature[2] = d/100;
  53.       Temperature[1] = d%100/10;
  54.       Temperature[0] = d%10;
  55. Show_Temperature();
  56.   if(d < 60)
  57. {
  58.    TR1 = 1;  L_LED = !H_LED;
  59.   }
  60.   else
  61.   if(d > 160)
  62. {
  63.   TR1 = 1;  H_LED = !L_LED;
  64. }
  65.   else
  66. {
  67.   TR1 = 0;  H_LED = L_LED = 1;
  68. }
  69. break;
  70.           }
  71.          }
  72.        }
  73.     }
  74. void T0_INT() interrupt 1
  75. {
  76.    CLK = ~CLK;
  77. }
  78. void T1_INT() interrupt 3
  79. {
  80.   TL1 = (65536 -1000) % 256;
  81.   BEEP = ~BEEP;
  82.       if (++t !=150 ) return;
  83.    else  if (++t !=60 ) return;
  84.    t = 0;
  85.   DelayMS(20);
  86. }
ID:121940 發表于 2016-6-3 23:39 | 顯示全部樓層
你這個圖里面看不到你的溫度傳感器還有你的程序后面部分問題很多 沒辦法改
ID:108510 發表于 2016-6-3 23:50 | 顯示全部樓層
wutianyudengyan 發表于 2016-6-3 23:39
右下邊那個就是.DSB1820
