查看: 2321|回復: 1
1602顯示超聲波程序
ID:117677 發表于 2016-5-1 13:21 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <AT89x51.H>
#include <intrins.h>
#define  RX  P2_6
#define  TX  P2_7
#define LCM_RW  P0_2
#define LCM_RS  P0_1
#define LCM_E   P0_3
#define LCM_Data  P1
#define Busy    0x80
unsigned char code mcustudio[] ={"  DONGMUFORYOU  "};
unsigned char code Cls[] =      {"                "};
unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','M'};
static unsigned char DisNum = 0;
uint  time=0;
unsigned long S=0;
bit   flag =0;
uchar disbuff[4]={ 0,0,0,0,};
/*********************5ms延時************/
void delay5Ms(void)
uint TempCyc = 5552;
while(TempCyc--);
/***********400ms延時******************/
void delay400Ms(void)
uchar TempCycA = 5;
uint TempCycB;
while(TempCycA--)
    TempCycB=7269;
    while(TempCycB--);
/*********************延遲****************/
void delayms(uint ms)
unsigned char i=100,j;
for(;ms;ms--)
   while(--i)
    j=10;
    while(--j);
/**************讀狀態**********************************/
uchar readStatusLCM(void)
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while(LCM_Data & Busy); //檢測忙信號
return(LCM_Data);
/*****************讀數據***************************************/
/*uchar readDataLCM(void)
LCM_RS = 1;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
return(LCM_Data);
/******************寫數據*********************************/
void writeDataLCM(uchar WDLCM)
readStatusLCM(); //檢測忙
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //若晶振速度太高可以在這后加小的延時
LCM_E = 0; //延時
LCM_E = 1;
/*****************寫指令*********************************/
void writeCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時忽略忙檢測
if (BuysC)
   readStatusLCM(); //根據需要檢測忙
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
/*************初始化*************************************/
void LCMInit(void) //LCM初始化
writeCommandLCM(0x38,0); //顯示模式設置,不檢測忙信號
delay5Ms();
writeCommandLCM(0x38,1); //顯示模式設置,開始要求每次檢測忙信號
writeCommandLCM(0x08,1); //關閉顯示
writeCommandLCM(0x01,1); //顯示清屏
writeCommandLCM(0x06,1); // 顯示光標移動設置
writeCommandLCM(0x0c,1); // 顯示關及光標設置
//按指定位置顯示一個字符
void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
Y &= 0x1;
X &= 0xF; //限制X不能大于15,Y不能大于1
if (Y)
    X |= 0x40; //當要顯示第二行時地址碼+0x40;
X |= 0x80; //算出指令碼
writeCommandLCM(X, 1); //發命令字
writeDataLCM(DData); //發數據
/**************顯示字符*************************************/
//按指定位置顯示一串字符
void displayListChar(uchar X, uchar Y, uchar code *DData)
uchar ListLength;
    ListLength = 0;
Y &= 0x1;
while (DData[ListLength]>0x19) //若到達字串尾則退出
    if (X <= 0xF) //X坐標應小于0xF
      DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
      ListLength++;
      X++;
/************計數*****************************/
void count(void)
   time=TH0*256+TL0;
   TH0=0;
   TL0=0;
   S=(time*1.7)/100;     //算出來是CM
   if((S>=700)||flag==1) //當距離超出測量時,范圍顯示“-”
     flag=0;
     DisplayOneChar(0, 1, ASCII[11]);
     DisplayOneChar(1, 1, ASCII[10]); //顯示點
     DisplayOneChar(2, 1, ASCII[11]);
     DisplayOneChar(3, 1, ASCII[11]);
     DisplayOneChar(4, 1, ASCII[12]); //顯示M
   else  //當距離未超出距離限制時,正常顯示
     disbuff[0]=S%1000/100;
     disbuff[1]=S%1000%100/10;
     disbuff[2]=S%1000%10 %10;
     DisplayOneChar(4, 1, ASCII[disbuff[0]]);
     DisplayOneChar(5, 1, ASCII[10]); //顯示點
     DisplayOneChar(6, 1, ASCII[disbuff[1]]);
     DisplayOneChar(7, 1, ASCII[disbuff[2]]);
     DisplayOneChar(8, 1, ASCII[12]); //顯示M
/*************************中斷**************************/
void timer0() interrupt 1    //T0中斷用來計數器溢出,超過測距范圍
     flag=1;        //中斷溢出標志
/******************啟動模塊*********************************/
void  startModule()            //啟動模塊
    uchar i;
    TX=1;                        //啟動一次模塊
    for(i=0;i<20;i++)     //延遲 以便于進行傳送數據
     _nop_();
    TX=0;
/*****************主函數***********************************/
LCMInit(); //LCM初始化
delay5Ms(); //延時片刻(可不要)
displayListChar(0, 0, mcustudio);
displayListChar(0, 1, Cls);
TMOD=0x01;     //設T0為方式1,GATE=1;
TH0=0;
TL0=0;
ET0=1;             //允許T0中斷
EA=1;      //開啟總中斷
       startModule();
    while(!RX);  //當RX為零時等待
    TR0=1;       //開啟計數
       while(RX);   //當RX為1計數并等待
    TR0=0;    //關閉計數
       count();   //計算
    delayms(80);  //80MS
ID:140358 發表于 2017-6-9 14:51 來自觸屏版 | 只看該作者
為什么我用這個程序不能實時顯示距離
