很好的GPS for51
2016-4-24 17:45 上傳
下面是部分程序預(yù)覽(完整版本請(qǐng)下載本帖附件):
- Copyright 2007
- All rights reserved.
- 文件名 :gps1602.c
- 模塊名稱:
- 功能概要:
- 取代版本:0.0.1
- 修改人 :pulan
- 完成日期:2007.07.27
- 升級(jí)說明:create
- cpu:stc89c58 晶振頻率:11.0592Mhz
- 硬件連接:
- |DB0-----P0.0 | DB4-----P0.4 | WR-------P2.2 | A0--------P2.1 |
- |DB1-----P0.1 | DB5-----P0.5 | RD-------P2.4 | Vo懸空 |
- |DB2-----P0.2 | DB6-----P0.6 | CS-------P2.5 |
- |DB3-----P0.3 | DB7-----P0.7 | RST-------P2.3 |
- #include <reg52.h>
- #include <string.h>
- #define LCM_Data P0
- #define Busy 0x80 //用于檢測(cè)LCM狀態(tài)字中的Busy標(biāo)識(shí)
- sbit LCM_RW = P2^5; //1602定義引腳
- sbit LCM_RS = P2^4;
- sbit LCM_E = P2^6;
- //sbit GPS_SPD=P1^2;
- //sbit SPD_TYPE=P1^3;
- sbit KEY1=P1^1;
- char code TIME_AREA= 8; //時(shí)區(qū)
- //GPS數(shù)據(jù)存儲(chǔ)數(shù)組
- unsigned char JD[10]; //經(jīng)度
- unsigned char JD_a; //經(jīng)度方向
- unsigned char WD[9]; //緯度
- unsigned char WD_a; //緯度方向
- unsigned char time[6]; //時(shí)間
- unsigned char speed[5]; //速度
- unsigned char high[6]; //高度
- unsigned char angle[5]; //方位角
- unsigned char use_sat[2]; //使用的衛(wèi)星數(shù)
- unsigned char total_sat[2]; //天空中總衛(wèi)星數(shù)
- unsigned char lock; //定位狀態(tài)
- //串口中斷需要的變量
- unsigned char seg_count; //逗號(hào)計(jì)數(shù)器
- unsigned char dot_count; //小數(shù)點(diǎn)計(jì)數(shù)器
- unsigned char byte_count; //位數(shù)計(jì)數(shù)器
- unsigned char cmd_number; //命令類型
- unsigned char mode; //0:結(jié)束模式,1:命令模式,2:數(shù)據(jù)模式
- unsigned char buf_full; //1:整句接收完成,相應(yīng)數(shù)據(jù)有效。0:緩存數(shù)據(jù)無效。
- unsigned char cmd[5]; //命令類型存儲(chǔ)數(shù)組
- //顯示需要的變量
- unsigned int dsp_count; //刷新次數(shù)計(jì)數(shù)器
- unsigned char time_count;
- bit page;
- bit spd_type;
- void sys_init(void);
- bit chk_key(void);
- void WriteDataLCM(unsigned char WDLCM);
- void WriteCommandLCM(unsigned char WCLCM,BuysC);
- unsigned char ReadDataLCM(void);
- unsigned char ReadStatusLCM(void);
- void LCMInit(void);
- void LCD_cls(void);
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData);
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData);
- void Delay5Ms(void);
- void Delay400Ms(void);
- * 函數(shù)名稱 :
- * 功能描述 :
- * 參數(shù) : 參數(shù)名稱: 輸入/輸出? 類型 描述
- * 返回值 :
- * 作者 :
- * 創(chuàng)建日期 :2006-12-19
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- *----------------------------------------修改歷史------------------------------------------
- * 當(dāng)前版本 : 修改人: 修改日期:
- * 修改說明 :
- main()
- unsigned char i;
- char Bhour;
- unsigned int Knots;
- sys_init();
- while(1)
- if(buf_full==0) //無GPS信號(hào)時(shí)
- dsp_count++;
- if(dsp_count>=65000)
- LCD_cls(); //清屏
- DisplayListChar(0,0,"No GPS connect..");
- while(buf_full==0);
- LCD_cls();
- dsp_count=0;
- else
- { //有GPS信號(hào)時(shí)
- if(chk_key())
- { //檢測(cè)到按鍵切換顯示
- page=!page;
- LCD_cls();
- if(!page)
- { //頁面1
- if(buf_full|0x01)
- { //GGA語句
- if(lock=='0')
- { //如果未定位
- DisplayListChar(0,0,"*---.--.---- ");
- DisplayListChar(0,1,"* --.--.---- ");
- else
- { //如果已定位
- DisplayOneChar(0,0,JD_a); //顯示經(jīng)度
- for(i=0;i<3;i++)
- DisplayOneChar(i+1,0,JD[i]);
- DisplayOneChar(4,0,'.');
- for(i=3;i<10;i++)
- DisplayOneChar(i+2,0,JD[i]);
- DisplayOneChar(0,1,WD_a); //顯示緯度
- DisplayOneChar(1,1,' ');
- for(i=0;i<2;i++)
- DisplayOneChar(i+2,1,WD[i]);
- DisplayOneChar(4,1,'.');
- for(i=2;i<9;i++)
- DisplayOneChar(i+3,1,WD[i]);
- DisplayOneChar(14,0,use_sat[0]); //顯示接收衛(wèi)星數(shù)
- DisplayOneChar(15,0,use_sat[1]);
- buf_full&=~0x01;
- dsp_count=0;
- if(buf_full|0x02){ //GSV語句
- DisplayOneChar(14,1,total_sat[0]);
- DisplayOneChar(15,1,total_sat[1]);
- buf_full&=~0x02;
- dsp_count=0;
- if(buf_full|0x04)
- buf_full&=~0x04;
- dsp_count=0;
- else
- { //頁面2
- if(buf_full|0x01)
- { //GGA語句
- buf_full&=~0x01;
- dsp_count=0;
- if(buf_full|0x02)
- buf_full&=~0x02;
- dsp_count=0;
- if(buf_full|0x04)
- { //RMC語句
- Bhour=((time[0]-0x30)*10+time[1]-0x30)+TIME_AREA;
- if(Bhour>=24)
- Bhour-=24;
- else if(Bhour<0)
- Bhour+=24;
- DisplayListChar(2,1,"BJT ");
- DisplayOneChar(6,1,Bhour/10+0x30);
- DisplayOneChar(7,1,Bhour%10+0x30);
- DisplayOneChar(8,1,':');
- DisplayOneChar(9,1,time[2]);
- DisplayOneChar(10,1,time[3]);
- DisplayOneChar(11,1,':');
- DisplayOneChar(12,1,time[4]);
- DisplayOneChar(13,1,time[5]);
- if(spd_type)
- DisplayListChar(5,0,"km/h A");
- else
- DisplayListChar(5,0,"knot A");
- if(lock=='0')
- { //如果未定位
- DisplayListChar(0,0,"---.-");
- DisplayListChar(11,0,"---.-");
- else
- { //已經(jīng)定位
- if(spd_type)
- { //km/h顯示
- for(i=0;i<5;i++)
- DisplayOneChar(i,0,speed[i]);
- else
- { //knot顯示
- Knots= (((speed[0]-0x30)*1000
- +(speed[1]-0x30)*100
- +(speed[2]-0x30)*10
- +(speed[4]-0x30))*1000)/1852;
- DisplayOneChar(0,0,Knots/1000+0x30);
- DisplayOneChar(1,0,(Knots%1000)/100+0x30);
- DisplayOneChar(2,0,(Knots%100)/10+0x30);
- DisplayOneChar(3,0,'.');
- DisplayOneChar(4,0,Knots%10+0x30);
- for(i=0;i<5;i++)
- DisplayOneChar(11+i,0,angle[i]);
- buf_full&=~0x04;
- dsp_count=0;
- * 函數(shù)名稱 :
- * 功能描述 :
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- bit chk_key(void)
- if(!KEY1)
- Delay5Ms();
- Delay5Ms();
- if(!KEY1)
- while(!KEY1);
- Delay5Ms();
- Delay5Ms();
- return(1);
- return(0);
- * 函數(shù)名稱 :sys_init
- * 功能描述 :系統(tǒng)初始化
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void sys_init()
- PCON |= 0x80;
- SCON |= 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
- TMOD = 0x21; /* TMOD: timer 1, mode 2, 8-bit reload */
- TH1 = 0xfd; /* TH1: reload value for 4800 baud @ 11.059MHz */
- spd_type=1; //速度單位km/h
- TR1 = 1; /* TR1: timer 1 run */
- LCMInit(); //初始化LCD
- DisplayListChar(0,0,"GPS Monitor V1.2");
- Delay400Ms();
- LCD_cls();
- IE=0x90; //開總中斷、串口中斷
- * 函數(shù)名稱 :WriteDataLCM
- * 功能描述 :寫數(shù)據(jù)
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- ReadStatusLCM(); //檢測(cè)忙
- LCM_Data = WDLCM;
- LCM_RS = 1;
- LCM_RW = 0;
- LCM_E = 0; //若晶振速度太高可以在這后加小的延時(shí)
- LCM_E = 0; //延時(shí)
- LCM_E = 1;
- * 函數(shù)名稱 :WriteCommandLCM
- * 功能描述 :寫指令
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC為0時(shí)忽略忙檢測(cè)
- if (BuysC)
- ReadStatusLCM(); //根據(jù)需要檢測(cè)忙
- LCM_Data = WCLCM;
- LCM_RS = 0;
- LCM_RW = 0;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- * 函數(shù)名稱 :ReadStatusLCM
- * 功能描述 :讀狀態(tài)
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- LCM_Data = 0xFF;
- LCM_RS = 0;
- LCM_RW = 1;
- LCM_E = 0;
- LCM_E = 0;
- LCM_E = 1;
- while (LCM_Data & Busy); //檢測(cè)忙信號(hào)
- return(LCM_Data);
- * 函數(shù)名稱 :LCMInit
- * 功能描述 :LCM初始化
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- LCM_Data = 0;
- WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測(cè)忙信號(hào)
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCM(0x38,1); //顯示模式設(shè)置,開始要求每次檢測(cè)忙信號(hào)
- WriteCommandLCM(0x08,1); //關(guān)閉顯示
- WriteCommandLCM(0x01,1); //顯示清屏
- WriteCommandLCM(0x06,1); // 顯示光標(biāo)移動(dòng)設(shè)置
- WriteCommandLCM(0x0C,1); // 顯示開及光標(biāo)設(shè)置
- * 功能描述 :LCM初始化
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- WriteCommandLCM(0x01,0);
- Delay5Ms();
- * 函數(shù)名稱 :DisplayOneChar
- * 功能描述 :按指定位置顯示一個(gè)字符
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當(dāng)要顯示第二行時(shí)地址碼+0x40;
- X |= 0x80; //算出指令碼
- WriteCommandLCM(X, 0); //這里不檢測(cè)忙信號(hào),發(fā)送地址碼
- WriteDataLCM(DData);
- * 函數(shù)名稱 :DisplayListChar
- * 功能描述 :按指定位置顯示一串字符 ***原來的遇到空格0x20就不顯示***
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- unsigned char ListLength,j;
- ListLength = strlen(DData);
- Y &= 0x1;
- if (X <= 0xF) //X坐標(biāo)應(yīng)小于0xF
- for(j=0;j<ListLength;j++)
- DisplayOneChar(X, Y, DData[j]); //顯示單個(gè)字符
- X++;
- * 函數(shù)名稱 :Delay5M
- * 功能描述 :5ms延時(shí)
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- * 函數(shù)名稱 :Delay400Ms
- * 功能描述 :400ms延時(shí)
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- * 函數(shù)名稱 :uart
- * 功能描述 :串口接收中斷
- * 返回值 :
- * 作者 :
- * 全局變量 :
- * 全局靜態(tài)變量:
- * 局部靜態(tài)變量:
- * 修改說明 :
- void uart(void) interrupt 4
- unsigned char tmp;
- if(RI)
- tmp=SBUF;
- switch(tmp)
- case '
- cmd_number=0; //命令類型清空
- mode=1; //接收命令模式
- byte_count=0; //接收位數(shù)清空
- break;
- case ',':
- seg_count++; //逗號(hào)計(jì)數(shù)加1
- byte_count=0;
- break;
- case '*':
- switch(cmd_number)
- case 1:
- buf_full|=0x01;
- break;
- case 2:
- buf_full|=0x02;
- break;
- case 3:
- buf_full|=0x04;
- break;
- mode=0;
- break;
- default:
- if(mode==1)
- //命令種類判斷
- cmd[byte_count]=tmp; //接收字符放入類型緩存
- if(byte_count>=4)
- { //如果類型數(shù)據(jù)接收完畢,判斷類型
- if(cmd[0]=='G')
- if(cmd[1]=='P')
- if(cmd[2]=='G')
- if(cmd[3]=='G')
- if(cmd[4]=='A')
- cmd_number=1;
- mode=2;
- seg_count=0;
- byte_count=0;
- else if(cmd[3]=='S')
- if(cmd[4]=='V')
- cmd_number=2;
- mode=2;
- seg_count=0;
- byte_count=0;
- else if(cmd[2]=='R')
- if(cmd[3]=='M')
- if(cmd[4]=='C')
- cmd_number=3;
- mode=2;
- seg_count=0;
- byte_count=0;
- else if(mode==2)
- //接收數(shù)據(jù)處理
- switch (cmd_number)
- case 1: //類型1數(shù)據(jù)接收。GPGGA
- switch(seg_count)
- case 2: //緯度處理
- if(byte_count<9)
- WD[byte_count]=tmp;
- break;
- case 3: //緯度方向處理
- if(byte_count<1)
- WD_a=tmp;
- break;
- case 4: //經(jīng)度處理
- if(byte_count<10)
- JD[byte_count]=tmp;
- break;
- case 5: //經(jīng)度方向處理
- if(byte_count<1)
- JD_a=tmp;
- break;
- case 6: //定位判斷
- if(byte_count<1)
- lock=tmp;
- break;
- case 7: //定位使用的衛(wèi)星數(shù)
- if(byte_count<2)
- use_sat[byte_count]=tmp;
- break;
- case 9: //高度處理
- if(byte_count<6)
- high[byte_count]=tmp;
- break;
- break;
- case 2: //類型2數(shù)據(jù)接收。GPGSV
- switch(seg_count)
- case 3: //天空中的衛(wèi)星總數(shù)
- if(byte_count<2)
- total_sat[byte_count]=tmp;
- break;
- break;
- case 3: //類型3數(shù)據(jù)接收。GPRMC
- switch(seg_count)
- case 1:
- if(byte_count<6)
- { //時(shí)間處理
- time[byte_count]=tmp;
- break;
- case 7: //速度處理
- if(byte_count<5)
- speed[byte_count]=tmp;
- break;
- case 8: //方位角處理
- if(byte_count<5)
- angle[byte_count]=tmp;
- break;
- break;
- byte_count++; //接收數(shù)位加1
- break;
- RI=0;
gps 1602.rar
2016-4-24 02:54 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
57.94 KB, 下載次數(shù): 323, 下載積分: 黑幣 -5
51GPS定位
評(píng)分
查看全部評(píng)分
