查看: 6571|回復(fù): 6
16只LED心形流水燈程序及proteus仿真
花樣心形流水燈
proteus仿真文件可以從下面下載
程序:
  1. //-----------------------------------------------------------------
  2. //        名稱: 花樣流水燈
  3. //-----------------------------------------------------------------
  4. //        說明: 16只LED分兩組按預(yù)設(shè)的多種花樣變換顯示
  5. //
  6. //-----------------------------------------------------------------
  7. #include <reg51.h>
  8. #define INT8U        unsigned char
  9. #define INT16U        unsigned int
  10. code INT16U Pattern[] =        //本例16位的花樣數(shù)組
  11. {
  12.         0xFCFF,0xF9FF,0xF3FF,0xE7FF,0xCFFF,0x9FFF,0x3FFF,0x7FFE,0xFFFC,
  13.         0xFFF9,0xFFF3,0xFFE7,0xFFCF,0xFF9F,0xFF3F,0xFFFF,0xE7E7,0xDBDB,
  14.         0xBDBD,0x7E7E,0xBDBD,0xDBDB,0xE7E7,0xFFFF,0xE7E7,0xC3C3,0x8181,
  15.         0x0000,0x8181,0xC3C3,0xE7E7,0xFFFF,0xAAAA,0x5555,0x1818,0xFFFF,
  16.         0xF0F0,0x0F0F,0x0000,0xFFFF,0xF8F8,0xF1F1,0xE3E3,0xC7C7,0x8F8F,
  17.         0x1F1F,0x3F3F,0x7F7F,0x7F7F,0x3F3F,0x1F1F,0x8F8F,0xC7C7,0xE3E3,
  18.         0xF1F1,0xF8F8,0xFFFF,0x0000,0x0000,0xFFFF,0xFFFF,0x0F0F,0xF0F0,
  19.         0xFEFF,0xFDFF,0xFBFF,0xF7FF,0xEFFF,0xDFFF,0xBFFF,0x7FFF,0xFFFE,
  20.         0xFFFD,0xFFFB,0xFFF7,0xFFEF,0xFFDF,0xFFBF,0xFF7F,0xFF7F,0xFFBF,
  21.         0xFFDF,0xFFEF,0xFFF7,0xFFFB,0xFFFD,0xFFFE,0x7FFF,0xBFFF,0xDFFF,
  22.         0xEFFF,0xF7FF,0xFBFF,0xFDFF,0xFEFF,0xFEFF,0xFCFF,0xF8FF,0xF0FF,
  23.         0xE0FF,0xC0FF,0x80FF,0x00FF,0x00FE,0x00FC,0x00F8,0x00F0,0x00E0,
  24.         0x00C0,0x0080,0x0000,0x0000,0x0080,0x00C0,0x00E0,0x00F0,0x00F8,
  25.         0x00FC,0x00FE,0x00FF,0x80FF,0xC0FF,0xE0FF,0xF0FF,0xF8FF,0xFCFF,
  26.         0xFEFF,0x0000,0xFFFF,0x0000,0xFFFF,0x0000,0xFFFF,0x0000,0xFFFF
  27. };
  28. //-----------------------------------------------------------------
  29. // 延時(shí)函數(shù)
  30. //-----------------------------------------------------------------
  31. void delay_ms(INT16U x)
  32. {
  33.         INT8U t; while(x--) for(t = 0; t < 120; t++);
  34. }
  35. //-----------------------------------------------------------------
  36. // 主程序
  37. //-----------------------------------------------------------------
  38. void main()
  39. {
  40. }
下載:http://www.raoushi.com/bbs/dpj-145709-1.html
http://www.raoushi.com/bbs/dpj-55383-1.html
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
來自 7#
ID:631998 發(fā)表于 2019-10-30 10:24 | 只看該作者
本帖最后由 asw9 于 2019-10-30 16:16 編輯
程序缺少
ID:198772 發(fā)表于 2017-5-10 20:29 | 只看該作者
感謝分享
ID:313046 發(fā)表于 2018-4-21 14:07 | 只看該作者
有沒有電路圖啊
ID:355951 發(fā)表于 2018-6-21 12:54 | 只看該作者
有沒有電路圖啊
ID:313328 發(fā)表于 2018-9-16 17:00 | 只看該作者
可以可以,幫忙了
ID:453086 發(fā)表于 2018-12-24 09:18 | 只看該作者
謝謝大神
