查看: 8347|回復: 7
PM2.5測量例子
ID:114481 發(fā)表于 2016-4-16 08:52 | 顯示全部樓層 |閱讀模式
#include<reg52.h>       //包含單片機寄存器的頭文件
#include <intrins.h>    //包含_nop_()函數(shù)定義的頭文件
sfr  ADC_CONTR=0X0BC;  //AD寄存器設(shè)置
sfr  ADC_RES=0x0BD;
sfr  ADC_RESL=0x0BE;
sfr  P1ASF=0x09D;
uchar a,q,t;
uchar FlagStart;
uchar VALUE;
uint num,DUST_Value,DUST;
long int s1,d0,b,c,d,biao,biao1,biao2;
uchar code qw[]={1,1,1};
uchar qs[4]={0,0,9,0};
uchar key_buffer[8]={0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};//2013-01-03
sbit rs=P2^5;          //將rS位定義為P2.5引腳
sbit e=P2^7;           //將e位定義為P2.7引腳
sbit rw=P2^6;          //將rw位定義為P2.6引腳
sbit k1=P1^4;
sbit k2=P1^5;
sbit k3=P1^6;
sbit k4=P1^7;
sbit D1=P2^1;          //正常指示燈(綠燈)
sbit D2=P2^0;          //警情指示燈(紅燈)
sbit LED=P1^1;         //  傳感器led
sbit beep=P1^3;//蜂鳴器
sbit fuli=P2^2;//負離子發(fā)生器
sbit fan=P2^3;//風扇
uchar code tad[]="value:0000ppm";
uchar code tad1[]="Alarm:0760ppm";
uchar ADC_Get[10]={0};    //定義AD采樣數(shù)組
uchar str[5]={0};
函數(shù)功能:延時若干毫秒
入口參數(shù):x
void delay(uchar x)
uint a,b;
for(a=x;a>0;a--)
  for(b=100;b>0;b--);
函數(shù)功能:ad數(shù)據(jù)轉(zhuǎn)換
uchar ADC( uchar ch)    //ch為幾通道 ,返回結(jié)果
{  uchar i;
  uint temp1;
  P1ASF|=1<<ch;
  ADC_CONTR=0x88+ch;
  for(i=100;i>0;i--);
  while(( ADC_CONTR&0x10)==0);//判斷AD是否轉(zhuǎn)換完
  ADC_CONTR&=~0x10;
  temp1=(ADC_RES<<2)+ADC_RESL;
  return temp1;
        液晶顯示器LED1602
void write_date(uchar date)
rs=1;
P0=date;
delay(5);
e=1;
delay(5);
e=0;
void write_com(uchar com)
rs=0;
P0=com;
delay(5);
e=1;
delay(5);
e=0;
void init()
uchar num;
e=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<14;num++)
   write_date(tad[num]);
    delay(2);
  write_com(0x80+0x40);
   write_date(tad1[num]);
    delay(2);
void write_sfm(uint date)//向1602送顯示
uint qian,bai,shi,ge;
bai=date%10000%1000/100;
shi=date%10000%1000%100/10;
ge=date%10000%1000%100%10;
write_com(0x80+6);
write_date(0x30+qian);
write_date(0x30+bai);
write_date(0x30+shi);
write_date(0x30+ge);
中值濾波/算法:先進行排序,然后將數(shù)組的中間值作為當前值返回。*/
uchar Error_Correct(uchar *str,uchar num)
   unsigned char i=0;
   unsigned char j=0;
   uchar Temp=0;
   //排序
   for(i=0;i<num-1;i++)
   for(j=i+1;j<num;j++)
      if(str[i]<str[j])
     Temp=str[i];
     str[i]=str[j];
     str[j]=Temp;
    //去除誤差,取中間值
    return str[num/2];
函數(shù)功能:報警子程序
void zx()//控制
long int sa;
sa=(qs[3]*1000+(qs[2]*100)+(qs[1]*10)+qs[0]); //報警設(shè)定值
if(DUST>sa) //煙霧檢測值大于設(shè)定值
  D1=1;  //正常指示綠燈滅
  D2=0; //報警紅燈亮
     fuli=0;
  fan=0;
  biao2=1;//蜂鳴器報警
  D1=0; //正常指示綠燈亮
  D2=1;  //報警紅燈滅
  fuli=1;
  fan=1;
  biao2=0;
  beep=1;  //蜂鳴器不響
函數(shù)功能:按鍵識別
void key_scan()//按鍵識別
uchar i;
static uchar key_value,key_state=0;
P1=0xf0;//設(shè)置P1口高4位為輸入口
if((P1&0xf0)!=0xf0)//有鍵按下
  delay(2); //延時消抖
  key_state =P1&0xf0;
  if(key_state!=0xf0) //再判有鍵按下
   switch(key_state)
    case 0xe0:  //S1按下
      key_value=1;
      break;
    case 0xd0://S2按下
     key_value=2;
      break;
    case 0xb0: //S3按下
     key_value=3;
      break;
    case 0x70: //S4按下
     key_value=4;
      break;
   for(i=0;i<7;i++) //按鍵隊列FIFO處理
     key_buffer[i]=key_buffer[i+1];
    key_buffer[7]=key_value; //最新按鍵值存入緩沖隊列
  while((P1&0xf0)!=0xf0);  //等待按鍵釋放
函數(shù)功能:按鍵處理
void key_do()  // 按鍵處理
uchar d,i;
while((key_buffer[0]!=0xff)||(key_buffer[1]!=0xff)||(key_buffer[2]!=0xff)||(key_buffer[3]!=0xff)||(key_buffer[4]!=0xff)||
       (key_buffer[5]!=0xff)||(key_buffer[6]!=0xff)||(key_buffer[7]!=0xff))//有鍵按下
   switch(key_buffer[0])
    case 1:  //S1按下
      biao++;
      TR0=0;
        write_com(0x80+0x40+9);//定位光標閃爍的位置
     write_com(0x0f); //打開光標閃爍
      if(biao==5)
      TR0=1;
      biao=0;
      biao1=0;
      break;
    case 2://S2按下
       if(biao==1)
       if(biao1==0)
       d=qs[0];
       d++;
       if(d==10) d=0;
       write_date(0x30+d);//送顯示
       write_com(0x80+0x40+9);//重新定位光標閃爍的位置
       qs[0]=d;
       //biao1=1;
      if(biao==2)
       if(biao1==0)
        write_com(0x80+0x40+8);//定位光標閃爍的位置
       d=qs[1];
       d++;
       if(d==10) d=0;
       write_com(0x80+0x40+8);//重新定位光標閃爍的位置
       qs[1]=d;
       //biao1=1;
      if(biao==3)
       if(biao1==0)
        write_com(0x80+0x40+7);//定位光標閃爍的位置
       d=qs[2];
       d++;
       if(d==10) d=0;
       write_com(0x80+0x40+7);//重新定位光標閃爍的位置
       qs[2]=d;
      if(biao==4)
       if(biao1==0)
        write_com(0x80+0x40+6);//定位光標閃爍的位置
       d=qs[3];
       d++;
       if(d==10) d=0;
       write_com(0x80+0x40+6);//重新定位光標閃爍的位置
       qs[3]=d;
      biao1=1;
      break;
    case 3: //S3按下
      if(biao==1)
       if(biao1==0)
       d=qs[0];
       d--;
       if(d==-1) d=9;
       qs[0]=d;
      // biao1=1;
        if(biao==2)
       if(biao1==0)
       d=qs[1];
       d--;
       if(d==-1) d=9;
       qs[1]=d;
      if(biao==3)
       if(biao1==0)
       d=qs[2];
       d--;
       if(d==-1) d=9;
       qs[2]=d;
      if(biao==4)
       if(biao1==0)
       d=qs[3];
       d--;
       if(d==-1) d=9;
       qs[3]=d;
      biao1=1;
       break;
    case 4: //S4按下
      TR0=1;
      biao=0;
      write_com(0x0c);//關(guān)閉光標閃爍
       break;
    default: break;
    key_buffer[7]=0xff; //緩沖隊列單元恢復無鍵按下標志
void init1()
biao=0;
biao1=0;
biao2=0;
beep=1;
rw=0;
   FlagStart=0;
   DUST_Value=0;
   LED=0;
EA=1;
ET0=1;
TMOD = 0x11;
TL0 = (65536-10000)/256; //定時10ms
TH0 = (65536-10000)%256;
TH1=(65536-600000)/256;//重賦初值
TL1=(65535-60000)%256;
ET1=1;
TR1=1;
TR0=1;
D1=0;//綠色燈
D2=1;//紅色燈
init();
/*****定時器0中斷服務程序*****/
void Timer0_ISR (void) interrupt 1 using 0
  uint j;
     LED=1;
      //開啟傳感器的LED
     for (j=0;j<222;j++);  //0.28ms  //延時0.28ms
ADC_Get[num]=ADC(0x00);   //開啟ADC采集
num++;
if(num>9)
   FlagStart=1;
   num=0;
   TR0 = 0;   //先關(guān)閉定時器0
   EA = 0;
// for (j=0;j<25;j++);          //采集10次,關(guān)閉定時器0,進行數(shù)據(jù)處理
//for (j=0;j<25;j++);
          //關(guān)閉傳感器LED
LED=0;
函數(shù)功能:主函數(shù)
main()
init1();
if(FlagStart==1)       //10次采集完成
   DUST=Error_Correct(ADC_Get,10);  //求取10次AD采樣的值
   DUST_Value=(DUST/1024.0)*5000;  //轉(zhuǎn)化成電壓值MV
   DUST_Value=DUST_Value*0.172-100.0; //DUST_Value=((DUST)*38)/4-202;// //固體懸浮顆粒濃度計算 Y=0.172*X-0.0999      X--采樣電壓V
   if(DUST_Value<0)       DUST_Value=0;
   if(DUST_Value>760)  DUST_Value=760; //限位
   DUST=(uint)DUST_Value;      //
   write_sfm(DUST);//顯示粉塵濃度值
   TR0 = 1;   //開啟定時器0
   EA = 1;
   FlagStart=0;
   zx();//濃度判斷啟動警報
   key_scan();
   key_do();
   delay(100);
void as() interrupt 3   //定時器T1中斷函數(shù) ,定時啟動數(shù)據(jù)轉(zhuǎn)換和AD轉(zhuǎn)換,并根據(jù)情況進行蜂鳴器報警
TH1=(65536-50000)/256;//重賦初值
TL1=(65535-50000)%256;
t++;  //時間計數(shù)加1
if(t==4) //50ms*4=0.2s,0.2s時間到
{  t=0;
  if(biao2==1)
   beep=!beep;  //蜂鳴器報警
參與人數(shù) 1黑幣 +50 收起 理由
ID:1 發(fā)表于 2016-4-16 10:57 來自觸屏版 | 顯示全部樓層
這個是什么型號的傳感器
ID:114394 發(fā)表于 2016-5-4 09:00 | 顯示全部樓層
l樓主,可不可以分享一下原理圖?謝謝
ID:189066 發(fā)表于 2017-4-14 18:52 | 顯示全部樓層
有用不?
ID:170423 發(fā)表于 2017-4-17 09:22 | 顯示全部樓層
很厲害  就是不知道什么型號的
ID:175237 發(fā)表于 2017-6-29 11:19 | 顯示全部樓層
makr學習
ID:286922 發(fā)表于 2018-3-2 13:56 | 顯示全部樓層
樓主,你好
這段公式是哪里來的 ,不明白可以解釋以下嗎
ID:248394 發(fā)表于 2018-4-18 12:00 | 顯示全部樓層
mark,先收藏起立
