自己又蛋疼寫的程序。主要是在1602上寫入自定義字符,可以用h1838遙控,沒(méi)有實(shí)際意義,做個(gè)測(cè)試文件,以后自己好再調(diào)試。msp430g2231只有8個(gè)io口(可以拓展為10個(gè))怎么利用這些io口,我想了個(gè)簡(jiǎn)單的辦法。紅外遙控占用一個(gè)io口,1602只是需要4根線(164驅(qū)動(dòng)的)當(dāng)然可以節(jié)省到2個(gè)io口,共占6個(gè)io口的,本來(lái)打算做個(gè)遙控車的,用PWM驅(qū)動(dòng),但肯跌的是自己不能解決電機(jī)反向電流的干擾。一上電機(jī)程序就崩潰,無(wú)奈,只好這樣了。不過(guò)寫入自定義字符確實(shí)是件不錯(cuò)的樂(lè)趣。
補(bǔ)充內(nèi)容:
圖片暫時(shí)無(wú)法上傳,看了很多開(kāi)發(fā)板的原理圖,我發(fā)現(xiàn)高明的設(shè)計(jì)不在于用了什么高端的芯片,而是精明的設(shè)計(jì),雖然我還不具備這樣的能力,也不知道我理解的怎么樣?先寫下我的思路。
部分程序預(yù)覽:
- #include"config.h"
- uchar const pic[8][8]={
- {0x04,0x0E,0x15,0x04,0x04,0x04,0x04,0x00},//↑
- {0x00,0x04,0x04,0x04,0x04,0x15,0x0E,0x04},//↓
- {0x00,0x04,0x08,0x1F,0x08,0x04,0x00,0x00},//←
- {0x00,0x04,0x02,0x1F,0x02,0x04,0x00,0x00},//→
- {0x04,0x04,0x0A,0x1F,0x1F,0x0A,0x04,0x04},//占位符
- {0x00,0x1B,0x1B,0x1B,0x1B,0x1B,0x1B,0x00},/*暫停*/
- {0x11,0x13,0x15,0x19,0x15,0x13,0x11,0x00},/*后退*/
- {0x11,0x19,0x15,0x13,0x15,0x19,0x11,0x00},/*"前進(jìn)*/
- uchar const pic1[8][8]={
- {0x00,0x0E,0x1F,0x11,0x11,0x11,0x11,0x1F},/*電量空*/
- {0x00,0x0E,0x1F,0x11,0x11,0x11,0x1F,0x1F},/*一格電*/
- {0x00,0x0E,0x1F,0x11,0x11,0x1F,0x1F,0x1F},/*2格電*/
- {0x00,0x0E,0x1F,0x11,0x1F,0x1F,0x1F,0x1F},/*3格電*/
- {0x00,0x0E,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F},/*4格電滿電*/
- {0x00,0x0F,0x09,0x0D,0x0B,0x09,0x11,0x00},/*凡*/
- {0x11,0x0E,0x1F,0x11,0x1F,0x04,0x1B,0x04},/*機(jī)器人*/
- {0x00,0x1F,0x0A,0x0A,0x0A,0x11,0x00,0x00},/*pi*/
- //音量大小設(shè)置1-8
- uchar const pic3[8][8]={
- {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1f},/*"未命名文件",1*/
- {0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x1f},/*"未命名文件",2*/
- {0x00,0x00,0x00,0x00,0x00,0x1f,0x1f,0x1f},/*"未命名文件",3*/
- {0x00,0x00,0x00,0x00,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",4*/
- {0x00,0x00,0x00,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",5*/
- {0x00,0x00,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",6*/
- {0x00,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",7*/
- {0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f},/*"未命名文件",8*/
- uchar flag,flag1,flag2;
- uchar flag3,flag4;
- //extern void read_xyz_normol();
- void extern_1m()
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- if (CALBC1_1MHZ==0xFF) // If calibration constant erased
- while(1); // do not load, trap CPU!!
- DCOCTL = 0; // Select lowest DCOx and MODx settings
- BCSCTL1 = CALBC1_1MHZ;
- DCOCTL = CALDCO_1MHZ; // Load 8MHz constants
- void sendbyte(uchar byte)
- uchar c,num;
- num=byte;
- for(c=0;c<8;c++)
- P1OUT&=~0x80;
- CLK0;
- P1OUT|=num&0x80; //(0x80即十進(jìn)制的128, 二進(jìn)制的10000000 按位發(fā)送
- CLK1;
- num<<=1;
- // - - 向LCD1602寫指令
- void LCD_write_command(uchar dat)
- LCD_RS_LOW; // - - 指令
- //LCD_RW_LOW; // - - 寫入
- sendbyte(dat);
- //delay_us(10);
- LCD_EN_HIGH; // - - 允許
- //delay_us(1);
- LCD_EN_LOW;
- // - - 向LCD1602寫數(shù)據(jù)
- void LCD_write_data(uchar dat)
- LCD_RS_HIGH;// - - 數(shù)據(jù)
- //LCD_RW_LOW;// - - 寫入
- sendbyte(dat);
- //delay_us(10);
- LCD_EN_HIGH;// - - 允許
- //delay_us(1);
- LCD_EN_LOW;
- // - - 設(shè)置顯示位置
- void LCD_set_xy(uchar x,uchar y)
- uchar address;
- if(y==1)
- address=0x80+x; // - - 第一行位置
- } else {
- address=0xc0+x; // - - 第二行位置
- // LCD_delay_10us(1);
- LCD_write_command(address);
- // - - 顯示一個(gè)字符函數(shù)
- void LCD_disp_char(uchar x,uchar y,uchar dat) // - - LCD_disp_char(0,1,0x38); // - - 顯示8
- LCD_set_xy(x,y);
- LCD_write_data(dat);
- // - - 顯示一個(gè)字符串函數(shù)
- void LCD_disp_string(uchar x,uchar y,char *s)
- LCD_set_xy(x,y);
- while(*s!='\0')
- LCD_write_data(*s);
- s++;
- void LCD_init(void)
- RSEN_INIT;
- CLKDAT_INIT;
- LCD_READ_DIR;
- LCD_write_command(0x38); // - - 設(shè)置8位格式,2行,5x7
- //delay_us(20);
- LCD_write_command(0x0c); // - - 整體顯示,關(guān)光標(biāo),不閃爍
- //delay_us(20);
- LCD_write_command(0x06); // - - 設(shè)定輸入方式,增量不移位
- //delay_us(20);
- LCD_write_command(0x01); // - - 清除屏幕顯示
- //delay_us(200);
- void lcd1602_write_pic(unsigned char add,uchar const *pic_num)
- unsigned char i;
- add=add<<3;
- for(i=0;i<8;i++)
- LCD_write_command(0x40|add+i);
- LCD_write_data(*pic_num++);
- void lcd1602_write_pic_all()//顯示跳變所有顯示
- uchar i;
- switch(flag)
- case 0:flag=1;break;
- case 1:flag=0;break;
- default:flag=0;break;
- if(flag==0)
- for(i=0;i<8;i++)
- lcd1602_write_pic(i,pic[i]);
- LCD_disp_string(0,1," ");
- for(i=0;i<8;i++)
- LCD_disp_char(i,0,i);
- else{
- for(i=0;i<8;i++)
- lcd1602_write_pic(i,pic1[i]);
- LCD_disp_string(0,0," ");
- for(i=0;i<8;i++)
- LCD_disp_char(i,1,i);
- void lcd1602_write_pic_baterry() //自定義數(shù)據(jù)1
- if(flag>=5)
- flag=0;
- lcd1602_write_pic(1,pic1[flag]);
- LCD_disp_char(15,0,1);
- void lcd1602_write_pic_robot() //自定義數(shù)據(jù)0
- if(++flag1>=15)
- flag1=0;
- LCD_disp_char(14,0,' ');
- else
- LCD_disp_char(flag1-1,0,' ');
- lcd1602_write_pic(0,pic1[6]);
- LCD_disp_char(flag1,0,0);
- void lcd1602_write_pic_dian(unsigned char add) //自定義數(shù)據(jù)0
- if(++flag2==8)
- flag2=0;
- lcd1602_write_pic(add,pic[flag2]);
- LCD_disp_char(10,1,add);
- void lcd1602_write_pic_volum(unsigned char add)
- if(flag3>=8)
- flag3=0;
- lcd1602_write_pic(add,pic3[flag3]);
- LCD_disp_char(15,1,add);
- void lcd1602_write_pic_qu(unsigned char add)
- if(++flag4>=8)
- flag4=0;
- uchar i;
- for(i=0;i<4;i++)
- lcd1602_write_pic(add+i,pic3[(i+flag4)%8]);
- LCD_disp_char(i,1,add+i);
- void sendbyte_4wire(char date)
- uchar i;
- for(i=0;i<2;i++)
- LCD_EN_HIGH;
- sendbyte(date);
- LCD_EN_LOW;
- date<<=4;
- void lcd_4wire(uchar cd,uchar date)
- if(cd==0)
- LCD_RS_LOW;
- else LCD_RS_HIGH;
- sendbyte_4wire(date);
- void lcd_4wire_init()
- RSEN_INIT;
- CLKDAT_INIT;
- lcd_4wire(0,0x28);
- lcd_4wire(0,0x0f);
- lcd_4wire(0,0x06);
- lcd_4wire(0,0x01);
- lcd_4wire(0,0x80);
- void lcd_4wire_setxy(uchar x,uchar y)
- uchar address;
- if(y==1)
- } else {
- lcd_4wire(0,address);
- void LCD_4wire_disp_char(uchar x,uchar y,uchar dat) // - - LCD_disp_char(0,1,0x38); // - - 顯示8
- lcd_4wire_setxy(x,y);
- lcd_4wire(1,dat);
- void lcd_4wire_disp_string(uchar x,uchar y,char *s)
- while(*s!='\0')
- lcd_4wire(1,*s);
- s++;
- void init_TA()
- TACCTL0 = CCIE; // TACCR0 interrupt enabled
- TACCR0 = 50000; //400ms中斷一次
- TACTL = TASSEL_2 + MC_1+ID_3; // SMCLK, upmode
- #pragma vector=TIMER0_A0_VECTOR
- __interrupt void Timer_A (void)
- // LCD_disp_char(0,0,'F');
- // lcd_4wire_disp_string(0,0,"wo shi");
- // lcd1602_write_pic_all();
- lcd1602_write_pic_baterry();
- lcd1602_write_pic_robot();
- lcd1602_write_pic_dian(2);
- lcd1602_write_pic_volum(3);
- lcd1602_write_pic_qu(4);
- //read_xyz_normol();
液晶顯示.rar
2016-3-30 17:22 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
38.72 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
