查看: 3668|回復: 0
商城開發筆記-10-Adapter的封裝以及使用
ID:109770 發表于 2016-3-22 17:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一、Adapter的封裝
       由于我們的RecycleView在項目中很常用,因此有必要對Adapter進行封裝。
封裝的原則是:
BaseAdapter的代碼如下:
import android.content.Context;
import android.support.v7.widget.RecyclerView;
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
import java.util.ArrayList;
import java.util.List;
* Adapter的簡單封裝
public abstract class BaseAdapter<T, H extends BaseViewHolder> extends RecyclerView.Adapter<BaseViewHolder> {
    protected static final String TAG = BaseAdapter.class.getSimpleName();
    protected final Context context;
    protected final int layoutResId;
    protected List<T> datas;
    private OnItemClickListener mOnItemClickListener = null;
    public interface OnItemClickListener {
        void onItemClick(View view, int position);
    public BaseAdapter(Context context, int layoutResId) {
        this(context, layoutResId, null);
    public BaseAdapter(Context context, int layoutResId, List<T> datas) {
        this.datas = datas == null ? new ArrayList<T>() : datas;
        this.context = context;
        this.layoutResId = layoutResId;
    @Override
    public BaseViewHolder onCreateViewHolder(ViewGroup viewGroup, int viewType) {
        View view = LayoutInflater.from(viewGroup.getContext()).inflate(layoutResId, viewGroup, false);
        BaseViewHolder vh = newBaseViewHolder(view, mOnItemClickListener);
        return vh;
    @Override
    public void onBindViewHolder(BaseViewHolder holder, int position) {
        T item = getItem(position);
        convert((H) holder, item);
    @Override
    public int getItemCount() {
        if (datas == null || datas.size() <= 0)
            return 0;
        return datas.size();
    public T getItem(int position) {
        if (position >= datas.size()) return null;
        return datas.get(position);
     * 清空數據
    public void clearData() {
        int size = datas.size();
        datas.clear();
        notifyItemRangeRemoved(0, size);
     * 下拉刷新,清除原有數據,添加新數據
     * @param newData
    public void refreshData(List<T> newData) {
        datas.clear();
        datas.addAll(newData);
        notifyItemRangeChanged(0, datas.size());
     * 在原來數據的末尾追加新數據
     * @param moreData
    public void loadMoreData(List<T> moreData) {
        int lastPosition = datas.size();
        datas.addAll(lastPosition, moreData);
        notifyItemRangeInserted(lastPosition, moreData.size());
     * Implement this method and use the helperto adapt the view to the given item.
     * @param viewHoder A fully initializedhelper.
     * @param item      The item that needs to be displayed.
    protected abstract void convert(H viewHoder, T item);
    public void setOnItemClickListener(OnItemClickListener listener) {
        this.mOnItemClickListener = listener;
BaseViewHolder的代碼如下:
import android.util.SparseArray;
import android.widget.Button;
import android.widget.ImageView;
import android.widget.TextView;
* 封裝的ViewHolder
public class BaseViewHolder extendsRecyclerView.ViewHolder implements View.OnClickListener {
    //使用數組把條目中的View保存起來
    private SparseArray<View> views;
    private BaseAdapter.OnItemClickListener mOnItemClickListener;
    public BaseViewHolder(ViewitemView, BaseAdapter.OnItemClickListener onItemClickListener) {
        super(itemView);
        itemView.setOnClickListener(this);
        this.mOnItemClickListener = onItemClickListener;
        this.views = new SparseArray<View>();
    public TextView getTextView(int viewId) {
        return retrieveView(viewId);
    public Button getButton(int viewId) {
    public ImageView getImageView(int viewId) {
    public View getView(int viewId) {
    protected <T extends View> T retrieveView(int viewId) {
        View view = views.get(viewId);
        if (view == null) {
            view = itemView.findViewById(viewId);
            views.put(viewId, view);
        return (T) view;
    @Override
    public void onClick(View v) {
        if (mOnItemClickListener != null) {
            mOnItemClickListener.onItemClick(v, getLayoutPosition());
為了使用方便,再提供一個SimpleAdapter
* 一個簡易的adapter
public abstract class SimpleAdapter<T> extends BaseAdapter<T, BaseViewHolder> {
    public SimpleAdapter(Context context, int layoutResId) {
        super(context, layoutResId);
    public SimpleAdapter(Contextcontext, int layoutResId, List<T> datas) {
        super(context, layoutResId, datas);
二、封裝Adapter的基本使用
1、使用
mAdapter = newSimpleAdapter<Page.Ware>(getActivity(), R.layout.item_hot_wares) {
    @Override
    protected void convert(BaseViewHolder holder, final Page.Ware item) {
        SimpleDraweeView s = (SimpleDraweeView) holder.getView(R.id.drawee_view);
        s.setImageURI(Uri.parse(item.getImgUrl()));
        holder.getTextView(R.id.text_title).setText(item.getName());
        holder.getTextView(R.id.text_price).setText(item.getPrice() + "");
        holder.getButton(R.id.btn_add).setOnClickListener(new View.OnClickListener() {
            @Override
                Toast.makeText(getActivity(), item.getName(), Toast.LENGTH_SHORT).show();
2、還可以進行點擊監聽
mAdapter.setOnItemClickListener(new BaseAdapter.OnItemClickListener() {
    @Override
    public void onItemClick(View view, int position) {
