查看: 3430|回復(fù): 1
電子密碼鎖設(shè)計 51單片機+24C04與1602LCD
ID:106841 發(fā)表于 2016-3-22 09:04 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
電子密碼鎖設(shè)計下載: 1602LCD設(shè)計電子密碼鎖.zip (26.03 KB, 下載次數(shù): 53)
  1. //-----------------------------------------------------------------
  2. //原始程序中相鄰兩位密碼不能相同.
  3. //本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
  4. //-----------------------------------------------------------------
  5. //實訓100例中本例內(nèi)的main函數(shù)可用以下代碼替換.
  6. //改動的主要是main函數(shù)中while循環(huán)內(nèi)的代碼.
  7. //-----------------------------------------------------------------
  8. // 主程序
  9. //-----------------------------------------------------------------
  10. void main()
  11. {
  12.    uchar i = 0;
  13.    uchar IIC_Password[10];
  14.    uchar IS_Valid_User = 0;
  15.    P0 = 0xFF;
  16.    P1 = 0xFF;
  17.    P2 = 0xFF;
  18.    TMOD = 0x02;                     //T0設(shè)置為8位自動重裝模式
  19.    TH0 = 175;
  20.    TL0 = 175;
  21.    TR0 = 1;                         //啟動T0
  22.    DelayMS(10);
  23.    LCD_Init();                      //初始化LCD
  24.
  25.    IIC_24C04_Init();                //初始化24C04
  26.
  27.    Display_String(Title_Text,0x00); //在第1行顯示標題
  28.
  29.    //24C04的內(nèi)容已由初始化BIN文件導(dǎo)入
  30.    //將24C04中預(yù)先寫入的密碼讀入pass
  31.    RecString(0xa0, 0 , IIC_Password, 6);
  32.    IIC_Password[6] = '\0';
  33.    while(1)
  34.    {
  35.       P1 = 0xF0;
  36.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
  37.       switch ( KeyNo )
  38.       {
  39.            case 0:  case 1: case 2: case 3: case 4:
  40.            case 5:  case 6: case 7: case 8: case 9:
  41.
  42.                    if ( i<= 5 )             //密碼限制在6位以內(nèi)
  43.                    {
  44.                         //如果i為0則執(zhí)行一次清屏
  45.                         if (i ==0) Display_String("                ",0x40);
  46.
  47.                         UserPassword[i] = KeyNo + '0';
  48.                         UserPassword[i+1] = '\0';
  49.
  50.                         DSY_BUFFER[i] = '*';
  51.                         DSY_BUFFER[i+1] = '\0';
  52.
  53.                         Display_String(DSY_BUFFER,0x40);
  54.
  55.                         i++;
  56.                     }
  57.                     break;
  58.
  59.            case 10: //按A鍵開鎖
  60.                     if (strcmp(UserPassword,IIC_Password) == 0)
  61.                     {
  62.                        LED_OPEN = 0;  //點亮LED
  63.                        Clear_Password();
  64.                        Display_String("Unlock OK!      ",0x40);
  65.                        IS_Valid_User = 1;
  66.                     }
  67.                     else
  68.                     {
  69.                        LED_OPEN =1;   //關(guān)閉LED
  70.                        Clear_Password();
  71.                        Display_String("ERROR !         ",0x40);
  72.                        IS_Valid_User = 0;
  73.                     }
  74.                     i = 0;
  75.                     break;
  76.
  77.            case 11: //按B鍵上鎖
  78.                     LED_OPEN =1;
  79.                     Clear_Password();
  80.                     Display_String(Title_Text,0x00);
  81.                     Display_String("                ",0x40);
  82.                     i = 0;
  83.                     IS_Valid_User = 0;
  84.                     break;
  85.
  86.            case 12: //按C鍵設(shè)置新密碼
  87.                     //如果是合法用戶則提示輸入新密碼
  88.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  89.                     else
  90.                     {
  91.                        i = 0;
  92.                        Display_String("New Password:   ",0x00);
  93.                        Display_String("                ",0x40);
  94.                      }
  95.
  96.                     break;
  97.
  98.            case 13: //按D鍵保存新密碼
  99.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  100.                     else
  101.                     {
  102.                        SendString(0xa0, 0 , UserPassword, 6);
  103.
  104.                        //重新讀入剛寫的密碼
  105.                        RecString(0xa0, 0 , IIC_Password, 6);
  106.                        IIC_Password[6] = '\0';
  107.
  108.                        i = 0;
  109.                        Display_String(Title_Text,0x00);
  110.                        Display_String("Password Saved! ",0x40);
  111.                      }
  112.
  113.                     break;
  114.
  115.            case 14: //按E鍵消除所有輸入
  116.                     i = 0;
  117.                     Clear_Password();
  118.                     Display_String("                ",0x40);
  119.        }
  120.        Beep();
  121.        DelayMS(100);
  122.        P1= 0xF0;
  123.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  124.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  125.    }
  126. }
參與人數(shù) 1黑幣 +50 收起 理由
ID:95922 發(fā)表于 2017-5-13 18:49 | 只看該作者
什么鬼,還要什么下載什么程序生成BIN,我去,浪費
