最近有朋友問我 如果使用51該如何實(shí)現(xiàn)雙串口功能,而且速度不是很快,于是我就建議使用單片機(jī)自身的串口,另外一個(gè)串口使用io口進(jìn)行模擬。主要實(shí)現(xiàn)方式詳見附件 主要程序如下:
#include <reg51.h>
sbit BT_SND =P1^0;
sbit BT_REC =P1^1;
IO 口模擬232通訊程序
使用兩種方式的C程序 占用定時(shí)器0
#define MODE_QUICK
#define F_TM F0
#define TIMER0_ENABLE TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
void IntTimer0() interrupt 1
F_TM=1;
//發(fā)送一個(gè)字符
void PSendChar(unsigned char inch)
#ifdef MODE_QUICK
ACC=inch;
F_TM=0;
BT_SND=0; //start bit
TIMER0_ENABLE; //啟動(dòng)
while(!F_TM);
BT_SND=ACC0; //先送出低位
F_TM=0;
while(!F_TM);
BT_SND=ACC1;
F_TM=0;
while(!F_TM);
BT_SND=ACC2;
F_TM=0;
while(!F_TM);
BT_SND=ACC3;
F_TM=0;
while(!F_TM);
BT_SND=ACC4;
F_TM=0;
while(!F_TM);
BT_SND=ACC5;
F_TM=0;
while(!F_TM);
BT_SND=ACC6;
F_TM=0;
while(!F_TM);
BT_SND=ACC7;
F_TM=0;
while(!F_TM);
BT_SND=1;
F_TM=0;
while(!F_TM);
TIMER0_DISABLE; //停止timer
#else
unsigned char ii;
ii=0;
F_TM=0;
while(!F_TM);
while(ii<8)
if(inch&1)
BT_SND=1;
BT_SND=0;
F_TM=0;
while(!F_TM);
ii++;
inch>>=1;
BT_SND=1;
F_TM=0;
while(!F_TM);
#endif
//接收一個(gè)字符
unsigned char PGetChar()
#ifdef MODE_QUICK
TIMER0_ENABLE;
F_TM=0;
while(!F_TM); //等過起始位
ACC0=BT_REC;
TL0=TH0;
F_TM=0;
while(!F_TM);
ACC1=BT_REC;
F_TM=0;
while(!F_TM);
ACC2=BT_REC;
F_TM=0;
while(!F_TM);
ACC3=BT_REC;
F_TM=0;
while(!F_TM);
ACC4=BT_REC;
F_TM=0;
while(!F_TM);
ACC5=BT_REC;
F_TM=0;
while(!F_TM);
ACC6=BT_REC;
F_TM=0;
while(!F_TM);
ACC7=BT_REC;
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return ACC;
#else
unsigned char rch,ii;
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
rch>>=1;
if(BT_REC)
rch|=0x80;
ii++;
F_TM=0;
while(!F_TM);
F_TM=0;
while(!F_TM)
if(BT_REC)
break;
return rch;
#endif
//檢查是不是有起始位
bit StartBitOn()
return (BT_REC==0);
unsigned char gch;
TMOD=0x22; /*定時(shí)器1為工作模式2(8位自動(dòng)重裝),0為模式2(8位
自動(dòng)重裝) */
PCON=00;
TR0=0; //在發(fā)送或接收才開始使用
TF0=0;
TH0=(256-96); //9600bps 就是 1000000/9600=104.167微秒 執(zhí)行的
timer是
104.167*11.0592/12= 96
TL0=TH0;
ET0=1;
EA=1;
PSendChar(0x55);
PSendChar(0xaa);
PSendChar(0x00);
PSendChar(0xff);
if(StartBitOn())
gch=PGetChar();
PSendChar(gch);
