查看: 3564|回復: 11
我用51板子連接GPS,用1602顯示。可是顯示不出來,有大神能幫我看看么
ID:102745 發表于 2016-3-11 08:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include "LCD1602.h"
#include "UART.h"
#include "Delay.h"
#include "GPS.h"
#include "config.h"
void main(void)
        unsigned char i;
        Uart_Init();
        LCD1602_Init();
        GPS_lock=1;
        GPSUSE_satellite[0]='0';
        GPSUSE_satellite[1]='0';
                if(Data_legitimate==0)                                //無GPS信號時
                        LCD1602_WriteCMD(CMD_clear);
                        Print_String(line_one,"  RTrobot GPS");
                        Print_String(line_two,"Please Waiting. ");
                        while(Data_legitimate==0);
                        Delay_Ms(200);
                else        //有GPS信號
                        if(Data_legitimate|0x01)        //GPGGA處理
                                        if(GPS_lock==0)                                        //未定位
                                                Print_String(line_two,"Waiting...");
                                        else        //已定位
                                                Print_Char(line_one,0,GPS_longitude_dir);                        //顯示經度
                                                for(i=0;i<3;i++)
                                                  Print_Char(line_one,i+1,GPS_longitude[i]);
                                                Print_Char(line_one,4,'.');
                                                for(i=3;i<10;i++)
                                                        Print_Char(line_one,i+2,GPS_longitude[i]);
                                                Print_Char(line_two,0,GPS_latitude_dir);                        //顯示緯度
                                                Print_Char(line_two,1,' ');
                                                for(i=0;i<2;i++)
                                                        Print_Char(line_two,i+2,GPS_latitude[i]);
                                                Print_Char(line_two,4,'.');
                                                for(i=2;i<9;i++)
                                                        Print_Char(line_two,i+3,GPS_latitude[i]);
                                        Data_legitimate&=~0x01;
                        Delay_Ms(500);
串口中斷
void uart(void) interrupt 4
        unsigned char UART_data;
        if(RI)
                UART_data=SBUF;
                switch(UART_data)
                        case '$':
                                GPSDATA_number=0;                //GPS數據類型清空
                                GPSDATA_mode=1;                        //接收命令模式
                                GPSDATA_count=0;                //接收位數清空
                                break;
                        case ',':
                                GPSDOT_count++;                //逗號計數加1
                                GPSDATA_count=0;
                                break;
                        case '*':
                                switch(GPSDATA_number)
                                        case 1:
                                                Data_legitimate|=0x01;//GPGGA
                                                break;
                                        case 2:
                                                Data_legitimate|=0x02;//GPGSV
                                                break;
                                        case 3:
                                                Data_legitimate|=0x04;//GPRMC
                                                break;
                                GPSDATA_mode=0;
                                break;
                        default:
                                if(GPSDATA_mode==1)        //類型種類判斷
                                        GPSDATA_cmd[GPSDATA_count]=UART_data;                        //接收字符放入類型緩存
                                        if(GPSDATA_count==4)        //如果類型數據接收完畢,判斷類型
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='G'&&GPSDATA_cmd[4]=='A')//判斷GPGGA
                                                        GPSDATA_number=1;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='S'&&GPSDATA_cmd[4]=='V')//判斷GPGSV
                                                        GPSDATA_number=2;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='R'&&GPSDATA_cmd[3]=='M'&&GPSDATA_cmd[4]=='C')//判斷GPRMC
                                                        GPSDATA_number=3;
                                                        GPSDATA_mode=2;
                                                        GPSDOT_count=0;
                                                        GPSDATA_count=0;
                                                其他類型照搬
                                else if(GPSDATA_mode==2)                                        //接收數據處理
                                        switch (GPSDATA_number)
                                                case 1:        //類型1數據接收。GPGGA
                                                        switch(GPSDOT_count)
        case 2:        //緯度處理
        if(GPSDATA_count<9)
        GPS_latitude[GPSDATA_count]=UART_data;
        break;
        case 3:        //緯度方向處理
        if(GPSDATA_count<1)
        GPS_latitude_dir=UART_data;
        break;
        case 4:        //經度處理
        if(GPSDATA_count<10)
        GPS_longitude[GPSDATA_count]=UART_data;
        break;
        case 5:        //經度方向處理
        if(GPSDATA_count<1)
        GPS_longitude_dir=UART_data;
        break;
        case 6:        //定位判斷
        if(GPSDATA_count<1)
        GPS_lock=UART_data;
        break;
        case 7:        //GPS使用衛星個數
        if(GPSDATA_count<2)
        GPSUSE_satellite[GPSDATA_count]=UART_data;
        break;
        case 9:        //海拔高度處理
        if(GPSDATA_count<6)
        GPS_altitude[GPSDATA_count]=UART_data;
        break;
                                                        break;
                                                case 2:        //類型2數據接收。GPGSV
        case 3:        //GPS可見衛星個數
        if(GPSDATA_count<2)
        GPSVISIBLE_satellite[GPSDATA_count]=UART_data;
        break;
                                                break;
                                                case 3:        //類型3數據接收。GPRMC
        case 1:        //時間處理
        if(GPSDATA_count<6)
        GPS_time[GPSDATA_count]=UART_data;
        break;
        case 2:        //定位判斷
        if(GPSDATA_count<1)
        if(UART_data=='A')
        GPS_lock=1;
        if(UART_data=='V')
        GPS_lock=0;
        break;
        case 3:        //緯度處理
        if(GPSDATA_count<9)
        break;
        case 4:        //緯度方向處理
        if(GPSDATA_count<1)
        break;
        case 5:        //經度處理
        break;
        case 6:        //經度方向處理
        if(GPSDATA_count<1)
        break;
        case 7:        //速度處理
        if(GPSDATA_count<5)
        GPS_speed[GPSDATA_count]=UART_data;
        break;
        case 8:        //方位角處理
        if(GPSDATA_count<5)
        GPS_Angle[GPSDATA_count]=UART_data;
        break;
        case 9:        //日期
        if(GPSDATA_count<6)
        GPS_date[GPSDATA_count]=UART_data;
        break;
                                                        break;
                                GPSDATA_count++;                //接收數位加1
                                break;
#define LCD1602_DB0_DB7  P0   //1602液晶數據端口
sbit LCD1602_RS = P1^0;  //1602液晶指令/數據選擇引腳
sbit LCD1602_RW = P1^1;  //1602液晶讀寫引腳
sbit LCD1602_E  = P1^5;  //1602液晶使能引腳
定義LCD1602指令集 (詳細請見查看1602指令集手冊)
#define                        CMD_clear                0x01            // 清除屏幕
#define                        CMD_back                0x02            // DDRAM回零位
#define                        CMD_ac                        0x06            // 讀入后AC(指針)加1,向右寫
#define                        CMD_display                0x0c            // 開顯示_關光標_關光標閃爍
#define                        CMD_set                        0x38            // 8位總線_2行顯示
#define                        line_one                0x80            // 第一行寫入地址
#define                        line_two                0xc0            // 第二行寫入地址
LCD1602測忙,若LCD1602處于忙狀態,本函數將等待至非忙狀態
void LCD1602_TestBusy(void)
           LCD1602_DB0_DB7 = 0xff;                            //設備讀狀態
           LCD1602_RS = 0;
           LCD1602_RW = 1;
           LCD1602_E = 1;
           while(LCD1602_DB0_DB7&0x80);                //等待LCD空閑
           LCD1602_E = 0;
寫指令程序
void LCD1602_WriteCMD(unsigned char LCD1602_command)
          LCD1602_TestBusy();
          LCD1602_DB0_DB7 = LCD1602_command;
          LCD1602_RS = 0;
          LCD1602_RW = 0;
          LCD1602_E = 1;
          LCD1602_E = 0;
向LCD1602寫數據
void LCD1602_WriteData(unsigned char  LCD1602_data)
        LCD1602_TestBusy();
        LCD1602_DB0_DB7 = LCD1602_data;
          LCD1602_RS = 1;
          LCD1602_RW = 0;
          LCD1602_E = 1;
          LCD1602_E = 0;
打印字符串程序(本函數調用指針函數)
向LCD發送一個字符串,長度48字符之內
在第一行第一位處從左向右打印字符串
void Print_String(unsigned char  line,unsigned char  *str)
        LCD1602_WriteCMD(line);
        while(*str != '\0')
                LCD1602_WriteData(*str++);
        *str = 0;
打印字符程序
向LCD發送一個字符,
line為行數(使用line_one,line_two定義使用),num為位置,data為打印字符
void Print_Char (unsigned char line,unsigned char num,unsigned char date)
                LCD1602_WriteCMD(line+num);
                LCD1602_WriteData(date);
LCD1602初始化
void LCD1602_Init(void)
          LCD1602_WriteCMD(CMD_set);        // 顯示模式設置:顯示2行,每個字符為5*7個像素
          LCD1602_WriteCMD(CMD_clear);        // 顯示清屏
          LCD1602_WriteCMD(CMD_back);            // 數據指針指向第1行第1個字符位置
          LCD1602_WriteCMD(CMD_ac);            // 顯示光標移動設置:文字不動,光標右移
          LCD1602_WriteCMD(CMD_display);         // 顯示開及光標設置:顯示開,光標開,閃爍開
void Uart_Init(void)
        EA=1;
        ES=1;
        SCON = 0x50;
        TMOD = 0x20;
        PCON=0x00;
        TH1 = 0xFD;
        TL1 = 0xfd;
        TR1 = 1;
        RI = 0;
接收數據是否完整
1有效
0無效
unsigned char Data_legitimate=0;
GPS是否定位
1有效
0無效
unsigned char GPS_lock;
GPS使用衛星個數
unsigned char GPSUSE_satellite[2];
GPS可見衛星個數
unsigned char GPSVISIBLE_satellite[2];
GPS數據類型
1GPGGA
2GPGSV
3GPRMC
unsigned char GPSDATA_number;
GPS數據模式
0結束模式
1類型模式
2數據模式
unsigned char GPSDATA_mode;
逗號計數器
unsigned char GPSDOT_count;
位數計數器
unsigned char GPSDATA_count;
類型模式存儲數組
unsigned char GPSDATA_cmd[5];
緯度
unsigned char GPS_latitude[9];
緯度方向
unsigned char GPS_latitude_dir;
經度
unsigned char GPS_longitude[10];
經度方向
unsigned char GPS_longitude_dir;
GPS速度
unsigned char GPS_speed[5]={'0','0','0','.','0'};
海拔高度
unsigned char GPS_altitude[6];
日期
unsigned char GPS_date[6];
時間
unsigned char GPS_time[6];
方位角
unsigned char GPS_Angle[5]={'0','0','0','0','0'};
方位角
unsigned char OUT_speed[5];
void Delay_Ms (unsigned int a)
        unsigned int i;
        while( a-- != 0)
                for(i = 0; i < 600; i++);
收藏收藏2 分享淘帖 頂 踩
ID:105648 發表于 2016-4-12 00:50 | 只看該作者
我也在搞這個, 手里也是顯示不出。。。
聽說前期調試可以直接用電腦的串口助手之類的仿佛發假的gps格式的信息,方便定位和debug
ID:84495 發表于 2016-4-12 09:28 | 只看該作者
如果你的  Print_String(line_one,"  RTrobot GPS");
這兩行可以顯示的話,就是gps波特率不對,,,
先確定你的gps模塊的波特率,一般有4800和9600兩種,可以先在電腦上調試一下,主要是確定gps模塊是好的,
還有很重要的一點晶振,晶振誤差大可能就跑偏了
ID:110866 發表于 2016-4-12 15:24 | 只看該作者
改下那個就行的
ID:130538 發表于 2016-8-19 10:24 | 只看該作者
不錯學習一下
ID:185537 發表于 2017-4-2 16:07 | 只看該作者
你現在好了嗎
ID:82765 發表于 2017-4-3 14:12 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
ID:185829 發表于 2017-4-3 19:34 | 只看該作者
字符格式轉換
ID:185537 發表于 2017-4-4 17:02 | 只看該作者
cjjcjj1 發表于 2017-4-3 14:12
你好!你的GPS出現的什么問題呢
我的也是出現了1602顯示不出來,調試了調試了lcd的驅動程序還是不可以顯示
你的現在可以顯示了嗎,可以的話加我qq:975319430 我們一起學習一下
ID:253599 發表于 2019-3-9 11:12 | 只看該作者
把P改成N
ID:253599 發表于 2019-3-9 11:29 | 只看該作者
if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='N'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='G'&&GPSDATA_c
ID:253599 發表于 2019-3-9 11:33 | 只看該作者
我剛剛發了一個和你的差不多的,但是可以顯示就是改了兩個字母,你可以看一下
