查看: 8542|回復: 1
[求助]請教PCB問題
ID:3392 發表于 2008-7-17 10:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我在PROTEL 99SE 里邊畫完原理圖編譯后出現了下面的一堆錯誤,請問是什么原因?謝謝!
C1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
C1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
C1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
C2 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
C2 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
C2 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
C3 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
C3 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
C3 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
Q1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
Q1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
Q1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R2 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R2 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R2 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R3 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R3 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R3 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R4 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R4 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R4 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R5 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R5 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R5 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
R11 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name.
R11 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>)
R11 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data>
Setup Error: GND Spice Reference Net (specified in Analog Options) is not in the schematic.
[此貼子已經被作者于2008-7-17 10:14:06編輯過]
ID:66501 發表于 2014-10-27 12:59 | 只看該作者
掘墓高手,專挖古墓,一挖一個坑,坑坑見墓。。
