Nios II 嵌入式系統驅動設計(一)
最近一直在做SOPC自定義元件的設計及其驅動的編寫,今天先分享一些關于自定義元件端口設置的內容。
在版本8.0中,SOPC Builder已經集成了七十多個IP,用戶可以非常方便的應用這些元件,不過在實際應用的時候,有些元件并沒有包含在SOPC中,需要用戶自己編寫元件代碼,并集成進SOPC Builder里面,自定義元件的集成過程其實就是將元件通過Avalon總線兼容的端口掛載到Avalon總線上,因此最重要的一步就是設置元件的端口,使其能掛載到Avalon總線上。
在7.2版本之后,Quartus II在自定義元件端口設置方面做了很大的修改,下面是變更的內容。
Table 1. Current Avalon Interfaces Supported by the Component Editor | Interface Type | Default Name | Description | New Interface in v7.2 | Master | avalon_master or m0 | Defines an Avalon master port interface. | - | Slave | avalon_slave or s0 | Defines an Avalon slave port interface. | - | Tri-State Slave | avalon_tristate_slave | Defines an Avalon tri-state port interface. | - | Clock Input | clock or clock_sink | Defines a clock and reset input interface for a component. | Y | Clock Output | clock_source | Defines a clock and reset output interface for components that generate clocks for SOPC Builder systems. | Y | Conduit Output or Input | conduit_start or conduit_end | Used for exporting signals to the top level of SOPC Builder systems. Conduit output and input interfaces are identical and imply no signal direction for the conduit interface. Conduits can contain input, output, and bidirectional signals. | Y | | interrupt_sender | Defines an interrupt output signal and the Avalon slave interface that is associated with generating the interrupt signal. | Y | Interrupt Receiver | interrupt_receiver | Defines an interrupt input signal and the Avalon master interface that is associated with receiving interrupt signals. | Y | Streaming Source | avalon_streaming_source | Defines an Avalon streaming source port interface. | Y | Streaming Sink | avalon_streaming_sink | Defines an Avalon streaming sink port interface. | Y |
我們可以發現除了已有的Master,slave以及tri-state slave以外,還新增了流處理端口,中斷收發端口,時鐘及輸出端口。因為在7.2版本以后,除了Avalom-MM總線外,SOPC又新增了Avalon-ST總線,因此端口也相應的增加了。
下面列出在7.2版本后主端口和從端口所需的端口信號,表中還列出了和以前版本的端口比較。
Table 1. Avalon-MM Slave with Global Clock, Reset, Interrupt Output, and Export Signals | Signal Type | Direction | v7.1 and Earlier Interface | v7.2 and Later Interface | clk | Input | Global | | reset | Input | Global | | address | Input | Avalon Slave | Avalon Slave | read | Input | Avalon Slave | Avalon Slave | readdata | Output | Avalon Slave | Avalon Slave | write | Input | Avalon Slave | Avalon Slave | writedata | Input | Avalon Slave | Avalon Slave | waitrequest | Output | Avalon Slave | Avalon Slave | irq | Output | Avalon Slave | Interrupt Sender | my_export_signals | Input, Output, or Bidir | Global | Conduit |
Table 2. Avalon-MM Multi-Port Slave with Global Clock, Reset, and Export Signals | Signal Type | Direction | v7.1 and Earlier Interface | v7.2 and Later Interface |
clk | Input | Global | Clock Input (1) | reset | Input | Global | Clock Input (1) | s1_address | Input | Avalon S1 Slave | Avalon S1 Slave |
s1_read | Input | Avalon S1 Slave | Avalon S1 Slave | s1_readdata | Output | Avalon S1 Slave | Avalon S1 Slave | s1_write | Input | Avalon S1 Slave | Avalon S1 Slave | s1_writedata | Input | Avalon S1 Slave | Avalon S1 Slave | s1_waitrequest | Output | Avalon S1 Slave | Avalon S1 Slave | s1_export_signals | Input, Output, or Bidir | Avalon S1 Slave | S1 Conduit | s2_address | Input | Avalon S2 Slave | Avalon S2 Slave | s2_read | Input | Avalon S2 Slave | Avalon S2 Slave | s2_readdata | Output | Avalon S2 Slave | Avalon S2 Slave |
s2_write | Input | Avalon S2 Slave | Avalon S2 Slave |
s2_writedata | Input | Avalon S2 Slave | Avalon S2 Slave |
s2_waitrequest | Output | Avalon S2 Slave | Avalon S2 Slave |
s2_export_signals | Input, Output, or Bidir | Avalon S2 Slave | S2 Conduit |
Table 3. Avalon-MM Master with Global Clock, Reset, Interrupt Input, and Export Signals | Signal Type | Direction | v7.1 and Earlier Interface | v7.2 and Later Interface |
address | Output | Avalon Master | Avalon Master |
read | Output | Avalon Master | Avalon Master |
readdata | Input | Avalon Master | Avalon Master |
write | Output | Avalon Master | Avalon Master |
writedata | Output | Avalon Master | Avalon Master |
waitrequest | Input | Avalon Master | Avalon Master |
irq | Input | Avalon Master | Interrupt Receiver |
Table 4. Avalon-MM Multi-Port Slave with Interface-Specific Clocks and Export Signals | Signal Type | Direction | v7.1 and Earlier Interface | v7.2 and Later Interface |
s1_clk | Input | Avalon S1 Slave | S1 Clock Input (1) |
s1_reset | Input | Avalon S1 Slave | S1 Clock Input (1) |
s2_clk | Input | Avalon S2 Slave | S2 Clock Input (1) |
s2_reset | Input | Avalon S2 Slave | S2 Clock Input (1) |
Table 5. Avalon-MM Multi-Port Master and Slave with Interface-Specific Clocks | Signal Type | Direction | v7.1 and Earlier Interface | v7.2 and Later Interface |
slave_clk | Input | Avalon Slave | Slave Clock Input (1) |
save_reset | Input | Avalon Slave | Slave Clock Input (1) |
slave_address | Input | Avalon Slave | Avalon Slave |
slave_read | Input | Avalon Slave | Avalon Slave |
slave_readdata | Output | Avalon Slave | Avalon Slave |
slave_write | Input | Avalon Slave | Avalon Slave |
slave_writedata | Input | Avalon Slave | Avalon Slave |
slave_waitrequest | Output | Avalon Slave | Avalon Slave |
master_clk | Input | Avalon Master | Master Clock Input (1) |
master_reset | Input | Avalon Master | Master Clock Input (1) |
master_address | Output | Avalon Master | Avalon Master |
master_read | Output | Avalon Master | Avalon Master |
master_readdata | Input | Avalon Master | Avalon Master |
master_write | Output | Avalon Master | Avalon Master |
master_writedata | Output | Avalon Master | Avalon Master |
master_waitrequest | Input | Avalon Master | Avalon Master |
確定了需要哪些端口后,需要編寫元件代碼(Verilog或VHDL),在端口命名中,Altera推薦用如下命名方式,以便在導入component editor之后能自動識別成相應的interface type。
__[_n]
interface type如下表所示:
2016-3-4 20:53 上傳
比如下面的端口定義:
module my_slave_irq_component (
// Signals for Avalon-MM slave port “s1” with irq
csi_clockreset_clk; //clockreset clock interface
csi_clockreset_reset_n;//clockreset clock interface
avs_s1_address;//s1 slave interface
avs_s1_read; //s1 slave interface
avs_s1_write; //s1 slave interface
avs_s1_writedata; //s1 slave interface
avs_s1_readdata; //s1 slave interface
ins_irq0_irq; //irq0 interrupt sender interface
input csi_clockreset_clk;
input csi_clockreset_reset_n;
input [7:0]avs_s1_address;
input avs_s1_read;
input avs_s1_write;
input [31:0]avs_s1_writedata;
output [31:0]avs_s1_readdata;
output ins_irq0_irq;
/* Insert your logic here */
endmodule
當元件設置好端口,并編寫完相應的Verilog或VHDL代碼之后,并可以通過SOPC Builder中的Component editor集成進SOPC Builder中,用戶并可以非常方便的調用。關于這部分內容請參考SOPC自定義元件的添加及運行。
