經常在筆試的時候出現這樣的題:檢測序列為11001101,輸出為1,否則輸出為0。抽空寫了下代碼,僅供參考。
FSM1:一段式
module machine_test1(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
st0=1,
st1=2,
st2=3,
st3=4,
st4=5,
st5=6,
st6=7;
reg [3:0] next_state;
reg dout;
always @ (posedge clk or negedge rst)
begin
if(!rst)
begin
next_state=idle;
dout=0;
end
begin
case(next_state)
idle:
if(din)
begin
next_state=st0;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st0:
if(din)
begin
next_state=st1;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st1:
if(!din)
begin
next_state=st2;
dout=0;
end
begin
next_state=st1;
dout=0;
end
st2:
if(!din)
begin
next_state=st3;
dout=0;
end
begin
next_state=st0;
dout=0;
end
st3:
if(din)
begin
next_state=st4;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st4:
if(din)
begin
next_state=st5;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st5:
if(!din)
begin
next_state=st6;
dout=0;
end
begin
next_state=st1;
dout=0;
end
st6:
if(din)
begin
next_state=idle;
dout=1;
end
begin
next_state=idle;
dout=0;
end
default:
begin
next_state=idle;
dout=0;
end
endcase
end
end
endmodule
FSM2:兩段式
module machine_test(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
st0=1,
st1=2,
st2=3,
st3=4,
st4=5,
st5=6,
st6=7;
reg [3:0] current_state,next_state;
reg dout;
begin
if(!rst)
current_state<=idle;
current_state<=next_state;
end
always @ (next_state or current_state or din or dout)
begin
case(current_state)
idle:
if(din)
begin
next_state=st0;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st0:
if(din)
begin
next_state=st1;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st1:
if(!din)
begin
next_state=st2;
dout=0;
end
begin
next_state=st1;
dout=0;
end
st2:
if(!din)
begin
next_state=st3;
dout=0;
end
begin
next_state=st0;
dout=0;
end
st3:
if(din)
begin
next_state=st4;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st4:
if(din)
begin
next_state=st5;
dout=0;
end
begin
next_state=idle;
dout=0;
end
st5:
if(!din)
begin
next_state=st6;
dout=0;
end
begin
next_state=st1;
dout=0;
end
st6:
if(din)
begin
next_state=idle;
dout=1;
end
begin
next_state=idle;
dout=0;
end
default:
begin
next_state=idle;
dout=0;
end
endcase
end
endmodule
FSM3:三段式
module machine_test2(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
st0=1,
st1=2,
st2=3,
st3=4,
st4=5,
st5=6,
st6=7,
st7=8;
reg dout;
begin
if(!rst)
end
begin
case(current_state)
idle:
if(din)
next_state=st0;
next_state=idle;
st0:
if(din)
next_state=st1;
next_state=idle;
st1:
if(!din)
next_state=st2;
next_state=st1;
st2:
if(!din)
next_state=st3;
next_state=st0;
st3:
if(din)
next_state=st4;
next_state=idle;
st4:
if(din)
next_state=st5;
next_state=idle;
st5:
if(!din)
next_state=st6;
next_state=st1;
st6:
if(din)
next_state=st7;
next_state=idle;
st7:
if(din)
next_state=st1;
next_state=idle;
default:
next_state=idle;
endcase
end
always @ (posedge clk)
begin
if(next_state==st7)
dout<=1'd1;
dout<=1'd0;
end
endmodule
仿真結果:
