查看: 14459|回復: 3
89C52矩陣鍵盤的識別(掃描法和線反轉法程序)
ID:105323 發表于 2016-2-13 02:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
我所見過的矩陣鍵盤一般有兩種識別方法:掃描法和線反轉法。以4X4矩陣鍵盤為例,掃描法是依次將每一行置為0,然后讀取列的狀態,這樣就可以通過四次掃描將整個矩陣鍵盤的按鍵狀況辨別出來,這個方法所需的代碼量比較長;而線反轉法則顯得比較簡潔,它通過先將4行全部置0(0xf0),然后讀列的狀態,接著,將列全部置0(0x0f),讀行的狀態,通過(行|列)就能確定整個行列的狀態了。掃描法比線反轉法占用更多的程序儲存空間(ProgramSpace),但占用的更少的數據儲存空間(Data Space)。
程序如下
掃描法:
#include<reg52.h>
uchar num,c;
uchar codeSSEG[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay1ms(uint z)
uint x;
uchar y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void keyscan()
uchar temp;
P2=0xfe;
temp=P2&0xf0;
if(temp!=0xf0)
  delay1ms(10);
  temp=P2&0xf0;
  if(temp!=0xf0)
   temp=P2;
   switch(temp)
    case0xee:num=0;break;
    case0xde:num=1;break;
    case0xbe:num=2;break;
    case0x7e:num=3;break;
   while(temp!=0xf0)//松手檢測
    temp=P2;
    temp=temp&0xf0;
P2=0xfd;
temp=P2&0xf0;
if(temp!=0xf0)
  delay1ms(10);
  temp=P2&0xf0;
  if(temp!=0xf0)
   temp=P2;
   switch(temp)
    case0xed:num=4;break;
    case0xdd:num=5;break;
    case0xbd:num=6;break;
    case0x7d:num=7;break;
   while(temp!=0xf0)
    temp=P2;
    temp=temp&0xf0;
P2=0xfb;
temp=P2&0xf0;
if(temp!=0xf0)
  delay1ms(10);
  temp=P2&0xf0;
  if(temp!=0xf0)
   temp=P2;
   switch(temp)
    case0xeb:num=8;break;
    case0xdb:num=9;break;
    case0xbb:num=10;break;
    case0x7b:num=11;break;
   while(temp!=0xf0)
    temp=P2;
    temp=temp&0xf0;
P2=0xf7;
temp=P2&0xf0;
if(temp!=0xf0)
  delay1ms(10);
  temp=P2&0xf0;
  if(temp!=0xf0)
   temp=P2;
   switch(temp)
    case0xe7:num=12;break;
    case0xd7:num=13;break;
    case0xb7:num=14;break;
    case0x77:num=15;break;
   while(temp!=0xf0)
    temp=P2;
    temp=temp&0xf0;
num=0xff;
  keyscan();
  P1=~SSEG[num];
線反轉法:
#include<reg52.h>
uchar num;
uint x;
uchar y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void keyscan()
uchar temp,z;
P2=0xf0;
if(P2!=0xf0)
  delay1ms(10);
  if(P2!=0xf0)
   temp=P2;
   P2=0x0f;
   z=temp|P2;
   temp=P2&0x0f;
   while(temp!=0x0f)//松手檢測
    temp=P2&0x0f;
   switch(z)
    case0xee: num =0; break;
         case 0xde: num =1; break;
         case 0xbe: num =2; break;
         case 0x7e: num =3; break;
         case 0xed: num =4; break;
         case 0xdd: num =5; break;
         case 0xbd: num =6; break;
         case 0x7d: num =7; break;
         case 0xeb: num =8; break;
         case 0xdb: num =9;break;
         case 0xbb: num =10;break;
         case 0x7b: num =11;break;
         case 0xe7: num =12;break;
         case 0xd7: num =13;break;
         case 0xb7: num =14;break;
         case 0x77: num =15;break;
num=0xff;
P2=0xff;
  keyscan();
  P1=~SSEG[num];
ID:192187 發表于 2017-4-21 22:55 | 只看該作者
這是錯的
ID:186804 發表于 2017-4-22 08:48 來自觸屏版 | 只看該作者
用了不對
ID:183159 發表于 2017-4-22 15:02 | 只看該作者
用狀態機掃描行不行?
