查看: 3232|回復(fù): 1
基于89S52的16312VFD顯示程序
ID:104835 發(fā)表于 2016-2-3 23:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1.                              #include "reg51.h"
  2.                              #include "stdio.h"
  3.                               sbit  STB = P1^2;
  4.                               sbit  CLK = P1^0;
  5.                               sbit  DIN = P1^1;
  6.                               void vfd_cmd (unsigned char vfd_cmd0);
  7.                                    /* 寫命令*/
  8.                               void vfd_wrdata (unsigned char vfd_wrdata0);
  9.                                    /*  寫數(shù)據(jù) */
  10.                               void vfd_init (void);
  11.                                   /* PT6311初始化 */
  12.                               unsigned char vfdbuf[]={0,0,0,0,21,8};
  13.                               code unsigned char vfdmap[]={0xf7, 0xa4, 0xeb,
  14.                               0xed, 0xbc, 0xdd, 0xdf, 0xe4, 0xff, 0xfd};
  15.                               unsigned char
  16.                               g11[]={0x64,0x89,0x32,0x64,0xa9,0x32,0x64,0xa9,0x32};
  17.                               unsigned char
  18.                               g12[]={0x26,0x48,0x91,0x26,0x48,0x01,0x02,0x00,0x91};
  19.                               //unsigned char
  20.                               g21[]={0xff,0x13,0x13,0x13,0x13,0x13,0x13,0x13,0x00};
  21.                               //unsigned char
  22.                               g22[]={0xff,0x40,0x00,0x00,0x80,0x00,0x00,0x00,0x00};
  23.                               //unsigned char
  24.                               g31[]={0xff,0x77,0x77,0x77,0x77,0x77,0x77,0x77,0x00};
  25.                               //unsigned char
  26.                               g32[]={0xff,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x10};
  27.                               //unsigned char
  28.                               g41[]={0xff,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x7e,0x00};
  29.                               //unsigned char
  30.                               g42[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  31.                               //unsigned char
  32.                               g51[]={0xff,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x2f,0x00};
  33.                               //unsigned char
  34.                               g52[]={0xff,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  35.                               unsigned char
  36.                               g61[]={0xff,0x02,0x04,0x08,0x10,0x00,0x00,0x00,0x00};
  37.                               unsigned char
  38.                               g62[]={0xff,0x00,0x00,0x00,0x00,0x10,0x20,0x40,0x80};
  39.                               void delay(unsigned char cnt)
  40.                               {
  41.                                 unsigned char i;
  42.                                 while(cnt--!=0)
  43.                                  for(i=100;i!=0;i--);
  44.                               }
  45.                               #define tick 7554
  46.                               #define T100us (256-134)
  47.                               unsigned char hour, minute, second;
  48.                               unsigned int c100us;
  49.
  50.
  51.                               void  vfd_cmd ( unsigned char vfd_cmd0 )
  52.                                       /*   寫控制命令子程序   */
  53.                               {
  54.                                 unsigned char i;
  55.                                 STB=1;
  56.                                 CLK=1;
  57.                                  for ( i=0;i<8;i++ )
  58.                                 {
  59.                                  STB=0;
  60.                                  CLK=0;
  61.                                  DIN = vfd_cmd0&0x01;
  62.                                  CLK=1;
  63.                                  vfd_cmd0>>=1;
  64.                                 }
  65.                                  STB=1;
  66.                                  CLK=1;
  67.                               }
  68.                               void vfd_wrdata (  unsigned char vfd_wrdata0 )
  69.                                         /*   寫數(shù)據(jù)子程序  */
  70.                               {
  71.                                  unsigned char i;
  72.                                  for(i=0;i<8;i++)
  73.                               {
  74.                                  CLK=1;
  75.                                  STB=0;
  76.                                  CLK=0;
  77.                                  DIN=vfd_wrdata0&0x01;
  78.                                  CLK=1;
  79.                                  vfd_wrdata0>>=1;
  80.                               }
  81.                                  STB=0;
  82.                                  CLK=1;
  83.                               }
  84.                               void vfd_init(void)
  85.                               {
  86.                                   vfd_cmd ( 0x3a );
  87.                                       /*  6digits,16segments顯示模式  */
  88.                                   vfd_cmd ( 0x70 );
  89.                                        /* 顯示正常模式,數(shù)據(jù)地址遞增  */
  90.
  91.                                   vfd_wrdata ( 0xc0 );
  92.                                        /*    設(shè)置地址從00H開始    */
  93.                                 }
  94.                               void timer0() interrupt 1
  95.                               {
  96.                                  c100us--;
  97.                                  if(c100us==0)
  98.                                  {
  99.                                   c100us=tick;
  100.                                second++;
  101.                                if(second==60)
  102.                                {
  103.                                  second=0;
  104.                                  minute++;
  105.                                  if(minute==60);
  106.                                   {
  107.                                     minute=0;
  108.                                  hour++;
  109.                                  if(hour==24)
  110.                                   {hour=0;}
  111.                                   }
  112.                                   }
  113.                                 }
  114.                               }
  115.                               void vfd_wrtime ()
  116.                               {unsigned int i;
  117.                                vfdbuf[0]=vfdmap[hour/10];
  118.                                vfdbuf[1]=vfdmap[hour%10];
  119.                                vfdbuf[2]=vfdmap[minute/10];
  120.                                vfdbuf[3]=vfdmap[minute%10];
  121.                                vfdbuf[4]=vfdmap[second/10];
  122.                                vfdbuf[5]=vfdmap[second%10];
  123.                                  vfd_init( );
  124.                                   i=0;
  125.                                    vfd_wrdata ( g11[i] );
  126.
  127.                                    vfd_wrdata ( g12[i] );
  128.
  129.
  130.                                   vfd_wrdata ( vfdbuf[0] );   //2G  分的十位
  131.                                   vfd_wrdata ( 0x00 );
  132.
  133.
  134.                                   vfd_wrdata ( vfdbuf[1] );          //3G  分的個位
  135.                                   vfd_wrdata ( 0x00 );
  136.
  137.
  138.                                   vfd_wrdata ( vfdbuf[4] );   //4G  秒的十位
  139.                                   vfd_wrdata ( 0x00 );
  140.
  141.                                   vfd_wrdata ( vfdbuf[5] );   //5G 秒的個位
  142.                                   vfd_wrdata ( 0x00 );
  143.
  144.                                   vfd_wrdata ( g61[i] );    //6G
  145.                                   vfd_wrdata ( g62[i] );
  146.
  147.                                i++;
  148.
  149.                                STB=1;
  150.                                 delay(1000);
  151.                                  vfd_cmd ( 0x8f );              /*  顯示開,14/16脈寬
  152.                               */
  153.                               }
  154.
  155.                               void  main()
  156.                                 {
  157.                                 EA=1;ET0=1;
  158.                                 TMOD=0x02;
  159.                                 TH0=T100us;
  160.                                 TL0=T100us;
  161.                                 hour=0;
  162.                                 second=0;
  163.                                 c100us=tick;
  164.                                 TR0=1;
  165.
  166.                                while(1)
  167.                                 {vfd_wrtime();
  168.                                 delay(1);
  169.                                 }
  170.
  171.                                    }
ID:149451 發(fā)表于 2020-2-8 16:55 | 只看該作者
老大,怎沒見寫
的數(shù)據(jù)語句呢,實際運行效果不好
