#include<reg52.h>
sbit dula=P2^7; #define uchar unsigned char #define uint unsigned int
unsigned char const dofly[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f, 0x77,0x7c,0x39,0x5e,0x79,0x71};//0-F uchar keyscan(void);//鍵盤掃描 void delay(uint i); //演示程序 void main() { uchar key; P2=0x00; //1數碼管亮 按相應的按鍵,會顯示按鍵上的字符 while(1) { dula=1; key=keyscan(); //調用鍵盤掃描, switch(key) { case 0x7e:P0=dofly[0];break;//0 按下相應的鍵顯示相對應的碼值 case 0x7d:P0=dofly[1];break;//1 case 0x7b:P0=dofly[2];break;//2 case 0x77:P0=dofly[3];break;//3 case 0xbe:P0=dofly[4];break;//4 case 0xbd:P0=dofly[5];break;//5 case 0xbb:P0=dofly[6];break;//6 case 0xb7:P0=dofly[7];break;//7 case 0xde:P0=dofly[8];break;//8 case 0xdd:P0=dofly[9];break;//9 case 0xdb:P0=dofly[10];break;//a case 0xd7:P0=dofly[11];break;//b case 0xee:P0=dofly[12];break;//c case 0xed:P0=dofly[13];break;//d case 0xeb:P0=dofly[14];break;//e case 0xe7:P0=dofly[15];break;//f } } } uchar keyscan(void) //鍵盤掃描函數,使用行列反轉掃描法 { uchar cord_h,cord_l;//行列值中間變量 P3=0x0f; //行線輸出全為0 cord_h=P3&0x0f; //讀入列線值 if(cord_h!=0x0f) //先檢測有無按鍵按下 { delay(100); //去抖 if(cord_h!=0x0f) { cord_h=P3&0x0f; //讀入列線值 P3=cord_h|0xf0; //輸出當前列線值 cord_l=P3&0xf0; //讀入行線值 return(cord_h+cord_l);//鍵盤最后組合碼值 } }return(0xff); //返回該值 } void delay(uint i) //延時函數 { while(i--); } |
