查看: 2560|回復: 1
8x8滾動顯示溫度
ID:103224 發表于 2016-1-15 10:54 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//LED8*8滾動顯示
//列掃描,低電平有效
//包含頭文件
#include <reg52.h>
#include "74HC595.H"
#include<intrins.h>  //包含_nop_()函數定義的頭文件
//全局變量定義
unsigned char  i,flag,t,w,t;
unsigned int  m,n;
unsigned char  t1,t2,t3,t4;
//代碼庫
#define  num  sizeof(buff)        //代碼長度
unsigned char code aa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code table2[]={
0x60,0x60,0x00,0x3E,0x7F,0x41,0x7F,0x3E,/*"0",0*/
0x60,0x60,0x00,0x42,0x7F,0x7F,0x40,0x00,/*"1",1*/
0x60,0x60,0x00,0x62,0x73,0x59,0x4F,0x46,/*"2",2*/
0x60,0x60,0x00,0x22,0x6B,0x49,0x7F,0x36,/*"3",3*/
0x60,0x60,0x00,0x38,0x3E,0x7F,0x7F,0x20,/*"4",4*/
0x60,0x60,0x00,0x4F,0x4F,0x49,0x79,0x31,/*"5",5*/
0x60,0x60,0x00,0x3E,0x7F,0x49,0x7B,0x32,/*"6",6*/
0x60,0x60,0x00,0x03,0x73,0x79,0x0F,0x07,/*"7",7*/
0x60,0x60,0x00,0x36,0x7F,0x49,0x7F,0x36,/*"8",8*/
0x60,0x60,0x00,0x26,0x6F,0x49,0x7F,0x3E,/*"9",9*/
unsigned char code table1[]= {
//取模方式 陰碼 列掃描 逆向
0x00,0x3E,0x7F,0x41,0x7F,0x3E,0x00,0x00,/*"0",0*/
0x00,0x42,0x7F,0x7F,0x40,0x00,0x00,0x00,/*"1",1*/
0x00,0x62,0x73,0x59,0x4F,0x46,0x00,0x00,/*"2",2*/
0x00,0x22,0x6B,0x49,0x7F,0x36,0x00,0x00,/*"3",3*/
0x00,0x38,0x3E,0x7F,0x7F,0x20,0x00,0x00,/*"4",4*/
0x00,0x4F,0x4F,0x49,0x79,0x31,0x00,0x00,/*"5",5*/
0x00,0x3E,0x7F,0x49,0x7B,0x32,0x00,0x00,/*"6",6*/
0x00,0x03,0x73,0x79,0x0F,0x07,0x00,0x00,/*"7",7*/
0x00,0x36,0x7F,0x49,0x7F,0x36,0x00,0x00,/*"8",8*/
0x00,0x26,0x6F,0x49,0x7F,0x3E,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/
unsigned char buff[]={
0x00,0x03,0x03,0x3E,0x7F,0x41,0x63,0x22,/*"C",0*/
以下是DS18B20的操作程序
sbit DQ=P3^3;
unsigned char time;   //設置全局變量,專門用于嚴格延時
函數功能:將DS18B20傳感器初始化,讀取應答信號
出口參數:flag
bit Init_DS18B20(void)
bit flag;         //儲存DS18B20是否存在的標志,flag=0,表示存在;flag=1,表示不存在
DQ = 1;           //先將數據線拉高
for(time=0;time<2;time++) //略微延時約6微秒
DQ = 0;           //再將數據線從高拉低,要求保持480~960us
for(time=0;time<200;time++)  //略微延時約600微秒
     ;         //以向DS18B20發出一持續480~960us的低電平復位脈沖
DQ = 1;           //釋放數據線(將數據線拉高)
  for(time=0;time<10;time++)
     ;  //延時約30us(釋放總線后需等待15~60us讓DS18B20輸出存在脈沖)
flag=DQ;          //讓單片機檢測是否輸出了存在脈沖(DQ=0表示存在)
for(time=0;time<200;time++)  //延時足夠長時間,等待存在脈沖輸出完畢
return (flag);    //返回檢測成功標志
函數功能:從DS18B20讀取一個字節數據
出口參數:dat
unsigned char ReadOneChar(void)
                unsigned char i=0;
                unsigned char dat;  //儲存讀出的一個字節數據
                for (i=0;i<8;i++)
                   DQ =1;       // 先將數據線拉高
                   _nop_();            //等待一個機器周期
                   DQ = 0;      //單片機從DS18B20讀書據時,將數據線從高拉低即啟動讀時序
                        dat>>=1;
                   _nop_();     //等待一個機器周期
                   DQ = 1;     //將數據線"人為"拉高,為單片機檢測DS18B20的輸出電平作準備
             ;      //延時約6us,使主機在15us內采樣
                   if(DQ==1)
                      dat|=0x80;  //如果讀到的數據是1,則將1存入dat
                                dat|=0x00;//如果讀到的數據是0,則將0存入dat
                     //將單片機檢測到的電平信號DQ存入r[i]
                   for(time=0;time<8;time++)
                              ;              //延時3us,兩個讀時序之間必須有大于1us的恢復期
         return(dat);    //返回讀出的十進制數據
函數功能:向DS18B20寫入一個字節數據
入口參數:dat
WriteOneChar(unsigned char dat)
        unsigned char i=0;
        for (i=0; i<8; i++)
                  DQ =1;         // 先將數據線拉高
                  _nop_();             //等待一個機器周期
                  DQ=0;          //將數據線從高拉低時即啟動寫時序
                  DQ=dat&0x01;   //利用與運算取出要寫的某位二進制數據,
                       //并將其送到數據線上等待DS18B20采樣
                     ;//延時約30us,DS18B20在拉低后的約15~60us期間從數據線上采樣
                  DQ=1;          //釋放數據線
                  for(time=0;time<1;time++)
                          ;//延時3us,兩個寫時序間至少需要1us的恢復期
                  dat>>=1;       //將dat中的各二進制位數據右移1位
          for(time=0;time<4;time++)
                      ; //稍作延時,給硬件一點反應時間
void ReadyReadTemp(void)
      Init_DS18B20();     //將DS18B20初始化
                WriteOneChar(0xCC); // 跳過讀序號列號的操作
                WriteOneChar(0x44); // 啟動溫度轉換
           for(time=0;time<100;time++)
                    ;         //溫度轉換需要一點時間
                WriteOneChar(0xCC); //跳過讀序號列號的操作
                WriteOneChar(0xBE); //讀取溫度寄存器,前兩個分別是溫度的低位和高位
//顯示函數
void Display(void)
if(flag==2){
Ser_IN((aa[i])); //列掃描數據
Ser_IN(buff[i + n]);                                //查表取出行掃描數據
        Par_OUT();                                                        //輸出顯示
        i++; if(i == 8) i = 0;                                //循環掃描
        m++; if(m == 100) {m = 0; n++;}                //滾動速度控制
        if(n == num-7)
         n = 0;                                //循環顯示
         flag=1;
//定時器初始化
void T_init(void)
    TMOD = 0x11;
    TH0  = 0xfc; //1MS
    TL0  = 0x66;
    EA = 1;                                        //允許CPU中斷
        ET0 = 1;                                 //定時器0中斷打開
    TR0  = 1;
//定時器中斷服務
void T0_intservice(void) interrupt 1 using 0
    TH0 = 0xfc;
    TL0 = 0x66;
Display();
//主函數
void main (void)
         unsigned char TL;     //儲存暫存器的溫度低位
     unsigned char TH;    //儲存暫存器的溫度高位
     unsigned char TN;      //儲存溫度的整數部分
          unsigned char TD;       //儲存溫度的小數部分
          flag=1;
        T_init();
        while(1){
          if(flag==1){
        ReadyReadTemp();     //讀溫度準備
           TL=ReadOneChar();    //先讀的是溫度值低位
                TH=ReadOneChar();    //接著讀的是溫度值高位
                TN=TH*16+TL/16;      //實際溫度值=(TH*256+TL)/16,即:TH*16+TL/16
                                          //這樣得出的是溫度的整數部分,小數部分被丟棄了
           TD=(TL%16)*10/16;    //計算溫度的小數部分,將余數乘以10再除以16取整,
           t1=TN/100;              //取百位
        t2=(TN%100)/10;    //取十位
        t3=TN%10;             //取個位
        t4=TD;
          flag=0;
        if(flag==0){
        for(w=1;w<6;w++){
        if(w==5){
        flag=2;
        for(t=0;t<8;t++){
        switch(w){
        case 1:
        buff[t+(8*w)]=table1[(8*t1)+t];
        break;
         case 2:
        buff[t+(8*w)]=table1[(8*t2)+t];
        break;
        case 3:
        buff[t+(8*w)]=table1[(8*t3)+t];
        break;
        case 4:
        buff[t+(8*w)]=table2[(8*t4)+t];
        break;
ID:1 發表于 2016-1-15 17:54 | 只看該作者
樓主能共享以下你發的這幾個程序的電路圖嗎?(可+200黑幣)
