查看: 41378|回復: 64
51單片機電子密碼鎖Proteus仿真+程序+原理圖
ID:100983 發表于 2015-12-29 09:33 | 顯示全部樓層 |閱讀模式
51單片機電子密碼鎖 仿真和程序源代碼都有電路原理圖可以下載附件打開仿真文件即可看到
51單片機源程序:
  1. //-----------------------------------------------------------------
  2. //原始程序中相鄰兩位密碼不能相同.
  3. //本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
  4. //-----------------------------------------------------------------
  5. //實訓100例中本例內的main函數可用以下代碼替換.
  6. //改動的主要是main函數中while循環內的代碼.
  7. //-----------------------------------------------------------------
  8. // 主程序
  9. //-----------------------------------------------------------------
  10. void main()
  11. {
  12.    uchar i = 0;
  13.    uchar IIC_Password[10];
  14.    uchar IS_Valid_User = 0;
  15.    P0 = 0xFF;
  16.    P1 = 0xFF;
  17.    P2 = 0xFF;
  18.    TMOD = 0x02;                     //T0設置為8位自動重裝模式
  19.    TH0 = 175;
  20.    TL0 = 175;
  21.    TR0 = 1;                         //啟動T0
  22.    DelayMS(10);
  23.    LCD_Init();                      //初始化LCD
  24.
  25.    IIC_24C04_Init();                //初始化24C04
  26.
  27.    Display_String(Title_Text,0x00); //在第1行顯示標題
  28.
  29.    //24C04的內容已由初始化BIN文件導入
  30.    //將24C04中預先寫入的密碼讀入pass
  31.    RecString(0xa0, 0 , IIC_Password, 6);
  32.    IIC_Password[6] = '\0';
  33.    while(1)
  34.    {
  35.       P1 = 0xF0;
  36.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
  37.       switch ( KeyNo )
  38.       {
  39.            case 0:  case 1: case 2: case 3: case 4:
  40.            case 5:  case 6: case 7: case 8: case 9:
  41.
  42.                    if ( i<= 5 )             //密碼限制在6位以內
  43.                    {
  44.                         //如果i為0則執行一次清屏
  45.                         if (i ==0) Display_String("                ",0x40);
  46.
  47.                         UserPassword[i] = KeyNo + '0';
  48.                         UserPassword[i+1] = '\0';
  49.
  50.                         DSY_BUFFER[i] = '*';
  51.                         DSY_BUFFER[i+1] = '\0';
  52.
  53.                         Display_String(DSY_BUFFER,0x40);
  54.
  55.                         i++;
  56.                     }
  57.                     break;
  58.
  59.            case 10: //按A鍵開鎖
  60.                     if (strcmp(UserPassword,IIC_Password) == 0)
  61.                     {
  62.                        LED_OPEN = 0;  //點亮LED
  63.                        Clear_Password();
  64.                        Display_String("Unlock OK!      ",0x40);
  65.                        IS_Valid_User = 1;
  66.                     }
  67.                     else
  68.                     {
  69.                        LED_OPEN =1;   //關閉LED
  70.                        Clear_Password();
  71.                        Display_String("ERROR !         ",0x40);
  72.                        IS_Valid_User = 0;
  73.                     }
  74.                     i = 0;
  75.                     break;
  76.
  77.            case 11: //按B鍵上鎖
  78.                     LED_OPEN =1;
  79.                     Clear_Password();
  80.                     Display_String(Title_Text,0x00);
  81.                     Display_String("                ",0x40);
  82.                     i = 0;
  83.                     IS_Valid_User = 0;
  84.                     break;
  85.
  86.            case 12: //按C鍵設置新密碼
  87.                     //如果是合法用戶則提示輸入新密碼
  88.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  89.                     else
  90.                     {
  91.                        i = 0;
  92.                        Display_String("New Password:   ",0x00);
  93.                        Display_String("                ",0x40);
  94.                      }
  95.
  96.                     break;
  97.
  98.            case 13: //按D鍵保存新密碼
  99.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  100.                     else
  101.                     {
  102.                        SendString(0xa0, 0 , UserPassword, 6);
  103.
  104.                        //重新讀入剛寫的密碼
  105.                        RecString(0xa0, 0 , IIC_Password, 6);
  106.                        IIC_Password[6] = '\0';
  107.
  108.                        i = 0;
  109.                        Display_String(Title_Text,0x00);
  110.                        Display_String("Password Saved! ",0x40);
  111.                      }
  112.
  113.                     break;
  114.
  115.            case 14: //按E鍵消除所有輸入
  116.                     i = 0;
  117.                     Clear_Password();
  118.                     Display_String("                ",0x40);
  119.        }
  120.        Beep();
  121.        DelayMS(100);
  122.        P1= 0xF0;
  123.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  124.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  125.    }
  126. }
34 用24C04與1602LCD設計電子密碼鎖.rar
23.71 KB, 下載次數: 1032
參與人數 3黑幣 +61 收起 理由
千葉北辰 + 6 很給力!
waitc + 5 贊一個!
admin + 50 共享資料的積分獎勵!
ID:99972 發表于 2016-1-8 15:50 | 顯示全部樓層
不錯哦 謝謝樓主的分享
ID:105654 發表于 2016-2-21 11:27 | 顯示全部樓層
修改密碼后,顯示密碼是錯誤的
ID:114304 發表于 2016-4-15 22:14 | 顯示全部樓層
非常好 感謝樓主
ID:122526 發表于 2016-5-22 11:26 | 顯示全部樓層
很有用,謝大神。
ID:126435 發表于 2016-6-12 22:25 | 顯示全部樓層
很詳細,很好
ID:74143 發表于 2016-6-18 13:06 | 顯示全部樓層
不錯,很好的資料
ID:128277 發表于 2016-6-27 13:14 | 顯示全部樓層
謝謝樓主分享
ID:128277 發表于 2016-6-27 13:15 | 顯示全部樓層
不錯很不錯的資料能解決燃煤直接!謝謝樓主
ID:128495 發表于 2016-6-28 23:30 | 顯示全部樓層
ID:130020 發表于 2016-10-14 18:55 | 顯示全部樓層
請問樓主有源程序嗎
ID:142802 發表于 2016-10-15 10:02 | 顯示全部樓層
謝謝樓主分享
ID:142802 發表于 2016-10-15 10:03 | 顯示全部樓層
謝謝樓主分享
ID:142813 發表于 2016-10-15 11:55 | 顯示全部樓層
非常棒的分享
ID:142417 發表于 2016-10-15 13:55 | 顯示全部樓層
代碼生成hex文件不能仿真啊
ID:108662 發表于 2016-10-30 14:13 | 顯示全部樓層
代碼不完整
ID:146723 發表于 2016-11-7 22:28 | 顯示全部樓層
不錯 下來看看
ID:149843 發表于 2016-11-23 23:10 | 顯示全部樓層
感謝樓主分享
ID:151309 發表于 2016-11-30 20:21 | 顯示全部樓層
感謝樓主 學習了
ID:151309 發表于 2016-11-30 20:22 | 顯示全部樓層
學習密碼鎖了
ID:153281 發表于 2016-12-13 08:53 | 顯示全部樓層
正在學習,感謝lz
ID:147823 發表于 2016-12-14 09:32 | 顯示全部樓層
我要下載 可是沒有黑幣
ID:147666 發表于 2016-12-22 11:22 | 顯示全部樓層
程序有錯誤
ID:147666 發表于 2016-12-22 11:23 | 顯示全部樓層
對,有錯誤
ID:157782 發表于 2017-1-1 14:25 | 顯示全部樓層
加112356778
ID:205103 發表于 2017-5-26 21:17 | 顯示全部樓層
太棒啦
ID:207209 發表于 2017-6-2 20:54 | 顯示全部樓層
讓我試試
ID:90419 發表于 2017-7-25 19:49 | 顯示全部樓層
不錯 ,謝謝樓主的分享
ID:230498 發表于 2017-9-2 00:27 | 顯示全部樓層
如何獲取黑比
ID:246147 發表于 2017-11-5 01:17 | 顯示全部樓層
好。。。。。。。
ID:248216 發表于 2017-11-10 22:07 | 顯示全部樓層
好東西
ID:247623 發表于 2017-11-11 16:47 | 顯示全部樓層
設置新密碼功能無法實現;
原始密碼123456,設置新密碼后,保存新密碼,但最后開鎖還是要用123456,這個BUG要修復
ID:263751 發表于 2017-12-19 16:07 | 顯示全部樓層
我想要
ID:170442 發表于 2018-3-28 23:16 | 顯示全部樓層
謝謝樓主
ID:96011 發表于 2018-4-3 12:30 | 顯示全部樓層
謝謝樓主的無私分享
ID:330674 發表于 2018-5-15 20:34 | 顯示全部樓層
能發給我一份看看不
ID:336735 發表于 2018-5-23 19:22 | 顯示全部樓層
挺不錯的,有說明就更好了
ID:393450 發表于 2018-9-4 16:28 來自觸屏版 | 顯示全部樓層
可以密碼改成8位嗎
ID:435728 發表于 2018-11-29 15:42 | 顯示全部樓層
非常用心,寫的很精準
ID:434173 發表于 2018-11-30 10:35 | 顯示全部樓層
不錯哦 謝謝樓主的分享
