2,關(guān)于波特率的設(shè)置 在設(shè)置波特率的時候,通過寫寄存器USART_BRR來實現(xiàn)。USART_BRR的11:4這8位為USARTDIV的整數(shù)部分,USART_BRR的3:0這4位為USARTDIV的小數(shù)部分。如: 設(shè)置USART_BRR=0x01BC,則有,USARTDIV的整數(shù)部分為0x1B=27,USARTDIV的小數(shù)部分為0x0C=12,轉(zhuǎn)換成十進制為12/16=0.75。綜上,USARTDIV=27.75。 同理,如果要設(shè)置USARTDIV=25.7,則USART_BRR的11:4為0x19,其3:0為0.7*16=11.2,取11,即為0x0B。綜上,若要設(shè)置USART_DIV=25.7,則只需設(shè)置USART_BRR=0x19B即可。 在初始化USART之后,發(fā)現(xiàn)串口并沒有數(shù)據(jù)輸出。初始化代碼如下: #include"stm32f10x.h" #include"io_control.h" void GPIO_Config(void); void USART_Config(void); int main() { GPIO_Config(); USART_Config(); while(1) { USART_SendData(USART1,0x41); LED4_OFF(); delay(800000); LED4_ON(); delay(800000); } } void GPIO_Config(void) { GPIO_InitTypeDef GPIO_Structure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,ENABLE); //LED-->>PC6 U1_TX-->PA9 U1_RX-->>PA10 U2_TX-->>PA2 U2_RX-->>PA3 GPIO_Structure.GPIO_Pin= GPIO_Pin_2|GPIO_Pin_9; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_PP; GPIO_Init(GPIOA,&GPIO_Structure); //USART_AFIO_Config GPIO_Structure.GPIO_Pin= GPIO_Pin_3|GPIO_Pin_10; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_OD; GPIO_Init(GPIOA,&GPIO_Structure); GPIO_Structure.GPIO_Pin= GPIO_Pin_6; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_Out_PP; GPIO_Init(GPIOC,&GPIO_Structure); //LED4 Config } void USART_Config(void) { USART_InitTypeDef USART_Structure; RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1,ENABLE); USART_Structure.USART_BaudRate=115200; USART_Structure.USART_WordLength=USART_WordLength_8b; USART_Structure.USART_StopBits=USART_StopBits_1; USART_Structure.USART_Parity=USART_Parity_No; USART_Structure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx; USART_Structure.USART_HardwareFlowControl=USART_HardwareFlowControl_None; USART_Init(USART1,&USART_Structure); USART_Cmd(USART1,ENABLE); } 對比官方代碼,并沒有大的區(qū)別。因此,推斷是否需要配置時鐘。 問題出現(xiàn)在void USART_Config(void)里面的時鐘使能函數(shù):RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1,ENABLE);應(yīng)該更改為 RCC_APB2periphClockCmd(RCC_APB2Periph_USART1,ENABLE); 在使用USART_SendData()發(fā)送數(shù)組時, void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen) { // Check the parameters uint16_t i; // Transmit Data for(i=0;i<strlen;i++) { USART_SendData(USARTx, (*point)); //USART_ClearFlag(USARTx,USART_FLAG_TC); point++; } } 當(dāng)USART_DR數(shù)據(jù)發(fā)送完成時,TC被置位。此時,需要讀一次USART_SR狀態(tài)寄存器后,再次寫入USART_DR數(shù)據(jù)時,TC被自動清零。在上面的數(shù)組發(fā)送函數(shù)里面,由于沒有讀USART_SR的操作,所以,如果發(fā)送數(shù)組數(shù)據(jù)時,有可能因為發(fā)送時間過快,而TC沒有被清零,所以,導(dǎo)致數(shù)組數(shù)據(jù)發(fā)送不正確。 對其修正后如下: void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen) { // Check the parameters uint16_t i; // Transmit Data for(i=0;i<strlen;i++) { USART_SendData(USARTx, (*point)); while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==0); //USART_ClearFlag(USARTx,USART_FLAG_TC); point++; } } 事實上,因為讀一次USART_SR然后再寫USART_DR時,TC會自動清零,所以,USART_ClearFlag(USARTx,USART_FLAG_TC) 該語句可以不要。 由于在FW3.5的固件庫里,USART_SendData()函數(shù)里面沒有讀USART_SR的函數(shù):while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==0); 所以,在連續(xù)調(diào)用USART_SENDDATA(USART1,'A')發(fā)送字符A時,同樣會出現(xiàn)數(shù)據(jù)丟失。如: USART_SendData(USART1,'A'); delay(1000); USART_SendData(USART1,'B'); delay(1000); USART_SendData(USART1,'C'); delay(1000); 加入delay(1000)是為了證明數(shù)據(jù)丟失并非因為沒有延時而引起的。當(dāng)連續(xù)調(diào)用發(fā)送單個字符函數(shù)改成: USART_SendData(USART1,'A'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'B'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'C'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); 數(shù)據(jù)沒有丟失。因此可以推斷,如果使用USART_SENDDATA()時,必須讀一次USART_SR狀態(tài)寄存器。這里,不適合用USART_ClearFlag(USARTx,USART_FLAG_TC)人為清零。 存在一個問題: USART_SendData(USART1,'A'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'B'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'C'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'D'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'E'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); i=sizeof(tab); for(k=0;k<i;k++) { USART_SendData(USART1, tab[k]); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); } //USART_SendString(USART1,tab,sizeof(tab)); //delay(2000000); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'F'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'G'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); USART_SendData(USART1,'H'); while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0); LED4_OFF(); delay(2000000); LED4_ON(); delay(2000000); 在發(fā)送完數(shù)組里面的數(shù)據(jù)后,后面的單個發(fā)送不能正確發(fā)送。必須在發(fā)送完數(shù)組后加入一個足夠大的延時,后面的數(shù)據(jù)才能正常發(fā)送。 2012年5月12日 18:26:40 經(jīng)反復(fù)查詢,問題出在sizeof()這個語句中。例如:uchar tab[]="nihao",正常定義是5個字符,但是,在使用sizeof的時候,需要加上一個結(jié)束符,相當(dāng)于sizeof(tab)返回的不是5,而是6.所以,在實際運行的時候,由于發(fā)送字符串多發(fā)了一個空字符0x00,這個與后面的字符一起發(fā)送的時候,會被認(rèn)為是漢字組合,結(jié)果就導(dǎo)致后面發(fā)送的FGH不能正常發(fā)送。 修改后如下:(將while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0);放到USART_SENDDATA()函數(shù)里面,從而在USART_SENDSTRING()里面可以不要;另外,將sizeof返回的數(shù)值減1.) #include"stm32f10x.h" #include"io_control.h" uint8_t tab[]="你現(xiàn)在還好嗎?是否過著你想要的生活?周華健"; void GPIO_Config(void); void USART_Config(void); void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen); int main() { //uint16_t i,k; GPIO_Config(); USART_Config(); while(1) { USART_SendData(USART1,'A'); USART_SendData(USART1,'B'); USART_SendData(USART1,'C'); USART_SendData(USART1,'D'); USART_SendData(USART1,'E'); USART_SendString(USART1,tab,sizeof(tab)-1); USART_SendData(USART1,'F'); USART_SendData(USART1,'G'); USART_SendData(USART1,'H'); LED4_OFF(); delay(2000000); LED4_ON(); delay(2000000); } } void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen) { // Check the parameters uint16_t i; // Transmit Data for(i=0;i<strlen;i++) { USART_SendData(USARTx, (*point)); point++; } } void GPIO_Config(void) { GPIO_InitTypeDef GPIO_Structure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO,ENABLE); //LED-->>PC6 U1_TX-->PA9 U1_RX-->>PA10 U2_TX-->>PA2 U2_RX-->>PA3 GPIO_Structure.GPIO_Pin= GPIO_Pin_2|GPIO_Pin_9; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_PP; GPIO_Init(GPIOA,&GPIO_Structure); //USART_AFIO_Config GPIO_Structure.GPIO_Pin= GPIO_Pin_3|GPIO_Pin_10; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_OD; GPIO_Init(GPIOA,&GPIO_Structure); GPIO_Structure.GPIO_Pin= GPIO_Pin_6; GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz; GPIO_Structure.GPIO_Mode= GPIO_Mode_Out_PP; GPIO_Init(GPIOC,&GPIO_Structure); //LED4 Config } void USART_Config(void) { USART_InitTypeDef USART_Structure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE); USART_Structure.USART_BaudRate=115200; USART_Structure.USART_WordLength=USART_WordLength_8b; USART_Structure.USART_StopBits=USART_StopBits_1; USART_Structure.USART_Parity=USART_Parity_No; USART_Structure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx; USART_Structure.USART_HardwareFlowControl=USART_HardwareFlowControl_None; USART_Init(USART1,&USART_Structure); USART_Cmd(USART1,ENABLE); USART_Structure.USART_BaudRate=115200; USART_Structure.USART_WordLength=USART_WordLength_8b; USART_Structure.USART_StopBits=USART_StopBits_1; USART_Structure.USART_Parity=USART_Parity_No; USART_Structure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx; USART_Structure.USART_HardwareFlowControl=USART_HardwareFlowControl_None; USART_Init(USART2,&USART_Structure); USART_Cmd(USART2,ENABLE); }
