查看: 4335|回復: 4
stm32串口通信程序-中斷方式
ID:99624 發表于 2015-12-27 02:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
經過調試在stm32F101CBT6中實現通信。注意還要配一個TTL轉usb接口,才能進行通信。實現字符串回發
#include"stm32f10x_it.h"
#include "stm32f10x_conf.h"
void RCC_Configuration(void); //時鐘配置
void USART_Configuration(void); //定義串口初始化函數
void NVIC_Configuration( void);
void Uart1_PutChar(u8 ch);
void Uart1_PutString(u8* buf , u8 len);
void GPIO1_Configuration(void);
void GPIO_Configuration(void);
int USART_RX_BUF[64]=0;
int USART_RX_STA=0;
    ErrorStatusHSEStartUpStatus;
    //使能外部晶振
   RCC_HSEConfig(RCC_HSE_ON);
    //等待外部晶振穩定
    HSEStartUpStatus =RCC_WaitForHSEStartUp();
   //如果外部晶振啟動成功,則進行下一步操作
   if(HSEStartUpStatus==SUCCESS)
       //設置HCLK(AHB時鐘)=SYSCLK
       RCC_HCLKConfig(RCC_SYSCLK_Div1);
       //PCLK1(APB1) = HCLK/2
       RCC_PCLK1Config(RCC_HCLK_Div2);
       //PCLK2(APB2) = HCLK
       RCC_PCLK2Config(RCC_HCLK_Div1);
       RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_4);
       //啟動PLL
       RCC_PLLCmd(ENABLE);
       //等待PLL穩定
       while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) ==RESET);
       //系統時鐘SYSCLK來自PLL輸出
       RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
       //切換時鐘后等待系統時鐘穩定
       while(RCC_GetSYSCLKSource()!=0x08);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
//RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2 ,ENABLE);
int main(void)
  int i;
u8 len;
RCC_Configuration();
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA |
                       RCC_APB2Periph_AFIO, ENABLE);//使能各部分時鐘
//NVIC_Configuration(); //串口中斷配置
//RCC中打開相應串口
GPIO_Configuration();
//串口1的管腳初始化
       GPIO1_Configuration();
USART_Configuration();
while (1)
  GPIO_SetBits(GPIOA,GPIO_Pin_8) ;
  GPIO_SetBits(GPIOA,GPIO_Pin_11) ;
  GPIO_SetBits(GPIOA,GPIO_Pin_15) ;
if(USART_RX_STA&0x80)
len=USART_RX_STA&0x3f;//得到此次接收到的數據長度
USART2->DR=len;
  while(USART_GetFlagStatus(USART2,USART_FLAG_TC) == RESET);
for(i=0;i
{USART2->DR=USART_RX_BUF[i];
  while(USART_GetFlagStatus(USART2,USART_FLAG_TC) == RESET);//等待發送結束}
USART_RX_STA=0;
  for(i=0;i<1000000;i++);
  GPIO_ResetBits(GPIOA,GPIO_Pin_11);
  GPIO_ResetBits(GPIOA,GPIO_Pin_15);
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_8|GPIO_Pin_11|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
GPIO_Init(GPIOA,&GPIO_InitStructure);
   voidGPIO1_Configuration(void)
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;          //管腳2
  GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_AF_PP;      //復用推挽輸出
  GPIO_Init(GPIOA,&GPIO_InitStructure);             //TX初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;          //管腳3
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING; //浮空輸入
  GPIO_Init(GPIOA,&GPIO_InitStructure);             //RX初始化
void USART_Configuration(void)//串口初始化函數
   USART_ClockInitTypeDefUSART_ClockInitStructure;
  //串口參數初始化
  USART_InitTypeDef USART_InitStructure;//串口設置恢復默認參數
//初始化參數設置
  USART_InitStructure.USART_BaudRate = 9600;//波特率9600
  USART_InitStructure.USART_WordLength =USART_WordLength_8b; //字長8位
  USART_InitStructure.USART_StopBits =USART_StopBits_1; //1位停止字節
  USART_InitStructure.USART_Parity =USART_Parity_No; //無奇偶校驗
USART_InitStructure.USART_HardwareFlowControl =USART_HardwareFlowControl_None;//無流控制
  USART_InitStructure.USART_Mode =USART_Mode_Rx | USART_Mode_Tx;//打開Rx接收和Tx發送功能
  USART_Init(USART2,&USART_InitStructure); //初始化
//USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//使能接受中斷,在接受移位 寄存器中有數據是產生
  USART_ClockInitStructure.USART_Clock =USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL =USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA =USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit =USART_LastBit_Disable;
   USART_ClockInit(USART2,&USART_ClockInitStructure);
   USART_Cmd(USART2,ENABLE); //啟動串口
   USART_ITConfig(USART2,USART_IT_RXNE, ENABLE);
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//選擇分組方式0
  NVIC_InitStructure.NVIC_IRQChannel =USART2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd =ENABLE;
NVIC_Init(&NVIC_InitStructure);
在stm32f10x_it.c
void USART2_IRQHandler(void); //放在頭文件里面也可以
extern  intUSART_RX_BUF[64];//聲明全局變量,此處不能夠賦值
extern  int USART_RX_STA;//聲明全局變量,此處不能夠賦值
    unsigned intres;
   if(USART_GetFlagStatus(USART2,USART_IT_RXNE)==SET)
       res =USART_ReceiveData(USART2);
if((USART_RX_STA&0x80)==0)//接收未完成
USART_RX_BUF[USART_RX_STA]=res;
USART_RX_STA++;
if(USART_RX_STA>63)
USART_RX_STA=0;
if(res=='#')
USART_RX_STA|=0x80;
   if(USART_GetITStatus(USART2, USART_IT_RXNE) !=RESET)
       USART_ClearITPendingBit(USART2,USART_IT_RXNE);
ID:67175 發表于 2016-3-21 22:43 | 只看該作者
分析的簡單易懂,贊一個;
ID:370386 發表于 2018-7-17 11:55 | 只看該作者
支持一個
ID:367948 發表于 2023-11-18 16:51 | 只看該作者
程序可以下載碼
ID:59738 發表于 2023-11-21 10:57 | 只看該作者
分析的簡單易懂,贊一個; 能夠幫我開拓思路
