查看: 2967|回復: 0
DS1302時鐘時間芯片單片機程序
ID:100029 發表于 2015-12-22 20:17 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<INTRINS.H>
#define write_second          0x80      //秒開始數存儲,修改用(下同)
#define write_minute           0x82      //分開始數存儲
#define write_hour              0x84      //時開始數存儲,12小時計時,從0開始要寫入0x80(12小時要判斷上下午)。
#define read_second          0x81      //秒,顯示要讀這個存儲器
#define read_minute           0x83      //分,顯示要讀這個存儲器
#define read_hour              0x85       //時,顯示要讀這個存儲器
#define write_day              0x86
#define read_day               0x87
#define write_month          0x88
#define read_month          0x89
#define write_week           0x8A
#define read_week           0x8B
#define write_year            0x8C
#define read_year            0x8D
#define write_protect 0x8E
sbit ACC_7=ACC^7;
sbit SCLK =P1^2;
sbit DIO  =P1^3;
sbit CE   =P1^4;      //protus軟件中的RST腳
uchar dd[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
void delay(char us)
     char m,n;
     while(us--)
           for(m=0;m<40;m++)
               for(n=0;n<50;n++);
void write1302(unsigned char addr,dat)
   unsigned char i,temp;
   CE=0;
   SCLK=0;
   CE=1;
   for(i=0;i<8;i++)  //寫入地址
         SCLK=0;
         temp=addr;
         if(temp&0x01==0x01)
               DIO=1;
               DIO=0;
        addr>>=1;
        SCLK=1;
   for(i=0;i<8;i++)  //寫入數據
        SCLK=0;
        temp=dat;
        if(temp&0x01==0x01)
             DIO=1;
             DIO=0;
        dat>>=1;
        SCLK=1;
unsigned char read1302(unsigned char addr)
   unsigned char i,temp,dat1,dat2;
   CE=0;
   SCLK=0;
   CE=1;
   for(i=8;i>0;i--)//寫入讀存儲單元地址
       SCLK =0;
       temp =addr;
       if(temp&0x01==0x01)
            DIO=1;
           DIO=0;
      addr>>=1;
      SCLK=1;
for(i=8;i>0;i--)//讀數據
       ACC_7=DIO;
       SCLK=1;
       ACC>>=1;
       SCLK=0;        //下降沿讀出數據
CE=0;
dat1=ACC;
dat2=dat1/16;
dat1=dat1%16;
dat1=dat1+dat2*10;
return(ACC);
void Initial(void)
        write1302(write_protect,0x00);
        write1302(write_second,0x56);
        write1302(write_minute,0x34);
        write1302(write_hour,0x12);
        write1302(write_protect,0x80);
void main(void)
    unsigned char tt1,tt2,hour;
    Initial();
    write1302(write_second,0x55);  //秒從55開始
    write1302(write_minute,0x59);  //分從59開始
    write1302(write_hour,0x8B); //賦值0x80,為12小時計時,但低五位為計時為,所以,顯示只顯示低五位,小時從11開始
    write1302(write_year,0x0f);  //15年
    write1302(write_week,0x03);//周三
    write1302(write_month,0x0a);//10月
          tt1=read1302(read_second);
          tt2=read1302(read_hour) & 0x1f;   //取出低五位
          if(read1302(read_hour) & 0x20==0x20) //12小時計時判斷上下午
               hour="pm "; // afternoon
               hour="am ";//morning
          P0=dd[tt1/10];
          P2=0xfe;
          delay(2);
          P2=0xff;
          P0=dd[tt1%10];
          P2=0xfd;
          delay(2);
          P2=0xff;
          P0=dd[tt2/10];
          P2=0xf7;
          delay(2);
          P2=0xff;
         P0=dd[tt2%10];
         P2=0xfb;
         delay(2);
         P2=0xff;
