樓主的程序我發(fā)出來(lái),給大家省點(diǎn)黑幣
- // BMP180 IIC測(cè)試程序
- // 使用單片機(jī)STC90C52RC
- // 晶振:11.0592M
- // 顯示:LCD1602
- // 編譯環(huán)境 Keil uVision3
- // 參考宏晶網(wǎng)站24c04通信程序
- #include <REG52.H>
- #include <math.h> //Keil library
- #include <stdlib.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H> //Keil library
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602數(shù)據(jù)端口
- sbit SCL=P1^0; //IIC時(shí)鐘引腳定義
- sbit SDA=P1^1; //IIC數(shù)據(jù)引腳定義
- sbit LCM_RS=P2^0; //LCD1602命令端口
- sbit LCM_RW=P2^1; //LCD1602命令端口
- sbit LCM_EN=P2^2; //LCD1602命令端口
- #define BMP180_SlaveAddress 0xee //定義器件在IIC總線(xiàn)中的從地址
- #define OSS 0 // Oversampling Setting (note: code is not set up to use other OSS values)
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- uchar ge,shi,bai,qian,wan,shiwan; //顯示變量
- int dis_data; //變量
- short ac1;
- short ac2;
- short ac3;
- unsigned short ac4;
- unsigned short ac5;
- unsigned short ac6;
- short b1;
- short b2;
- short mb;
- short mc;
- short md;
- void delay(unsigned int k);
- void InitLcd(); //初始化lcd1602
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(long temp_data);
- void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data); //單個(gè)寫(xiě)入數(shù)據(jù)
- uchar Single_Read(uchar REG_Address); //單個(gè)讀取內(nèi)部寄存器數(shù)據(jù)
- void Multiple_Read(uchar,uchar); //連續(xù)的讀取內(nèi)部寄存器數(shù)據(jù)
- void Delay5us();
- void Delay5ms();
- void BMP180_Start();
- void BMP180_Stop();
- void BMP180_SendACK(bit ack);
- bit BMP180_RecvACK();
- void BMP180_SendByte(BYTE dat);
- BYTE BMP180_RecvByte();
- void BMP180_ReadPage();
- void BMP180_WritePage();
- shiwan=temp_data/100000+0x30 ;
- temp_data=temp_data%100000; //取余運(yùn)算
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余運(yùn)算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余運(yùn)算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余運(yùn)算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余運(yùn)算
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 延時(shí)5微秒(STC90C52RC@12M)
- 不同的工作環(huán)境,需要調(diào)整此函數(shù),注意時(shí)鐘過(guò)快時(shí)需要修改
- 當(dāng)改用1T的MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延時(shí)5毫秒(STC90C52RC@12M)
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信號(hào)
- SDA = 1; //拉高數(shù)據(jù)線(xiàn)
- SCL = 1; //拉高時(shí)鐘線(xiàn)
- Delay5us(); //延時(shí)
- SDA = 0; //產(chǎn)生下降沿
- SCL = 0; //拉低時(shí)鐘線(xiàn)
- 停止信號(hào)
- SDA = 0; //拉低數(shù)據(jù)線(xiàn)
- SDA = 1; //產(chǎn)生上升沿
- 發(fā)送應(yīng)答信號(hào)
- 入口參數(shù):ack (0:ACK 1:NAK)
- SDA = ack; //寫(xiě)應(yīng)答信號(hào)
- 接收應(yīng)答信號(hào)
- CY = SDA; //讀應(yīng)答信號(hào)
- return CY;
- 向IIC總線(xiàn)發(fā)送一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- for (i=0; i<8; i++) //8位計(jì)數(shù)器
- dat <<= 1; //移出數(shù)據(jù)的最高位
- SDA = CY; //送數(shù)據(jù)口
- BMP180_RecvACK();
- 從IIC總線(xiàn)接收一個(gè)字節(jié)數(shù)據(jù)
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
- dat <<= 1;
- dat |= SDA; //讀數(shù)據(jù)
- return dat;
- //單字節(jié)寫(xiě)入BMP180內(nèi)部數(shù)據(jù)*******************************
- BMP180_Start(); //起始信號(hào)
- BMP180_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- BMP180_SendByte(REG_Address); //內(nèi)部寄存器地址
- BMP180_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù)
- BMP180_Stop(); //發(fā)送停止信號(hào)
- //單字節(jié)讀取BMP180內(nèi)部數(shù)據(jù)********************************
- { uchar REG_data;
- BMP180_SendByte(BMP180_SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
- BMP180_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址
- BMP180_SendByte(BMP180_SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
- REG_data=BMP180_RecvByte(); //讀出寄存器數(shù)據(jù)
- BMP180_SendACK(1);
- BMP180_Stop(); //停止信號(hào)
- return REG_data;
- //讀出BMP180內(nèi)部數(shù)據(jù),連續(xù)兩個(gè)
- short Multiple_read(uchar ST_Address)
- uchar msb, lsb;
- short _data;
- BMP180_SendByte(ST_Address); //發(fā)送存儲(chǔ)單元地址
- msb = BMP180_RecvByte(); //BUF[0]存儲(chǔ)
- BMP180_SendACK(0); //回應(yīng)ACK
- lsb = BMP180_RecvByte();
- BMP180_SendACK(1); //最后一個(gè)數(shù)據(jù)需要回NOACK
- Delay5ms();
- _data = msb << 8;
- _data |= lsb;
- return _data;
- long bmp180ReadTemp(void)
- BMP180_SendByte(0xF4); // write register address
- BMP180_SendByte(0x2E); // write register data for temp
- delay(10); // max time is 4.5ms
- return (long) Multiple_read(0xF6);
- long bmp180ReadPressure(void)
- long pressure = 0;
- BMP180_SendByte(0x34); // write register data for pressure
- pressure = Multiple_read(0xF6);
- pressure &= 0x0000FFFF;
- return pressure;
- //return (long) bmp085ReadShort(0xF6);
- //初始化BMP180,根據(jù)需要請(qǐng)參考pdf進(jìn)行修改**************
- void Init_BMP180()
- ac1 = Multiple_read(0xAA);
- ac2 = Multiple_read(0xAC);
- ac3 = Multiple_read(0xAE);
- ac4 = Multiple_read(0xB0);
- ac5 = Multiple_read(0xB2);
- ac6 = Multiple_read(0xB4);
- b1 = Multiple_read(0xB6);
- b2 = Multiple_read(0xB8);
- mb = Multiple_read(0xBA);
- mc = Multiple_read(0xBC);
- md = Multiple_read(0xBE);
- void bmp180Convert()
- long ut;
- long up;
- long x1, x2, b5, b6, x3, b3, p;
- unsigned long b4, b7;
- long temperature;
- long pressure;
- ut = bmp180ReadTemp();
- ut = bmp180ReadTemp(); // 讀取溫度
- up = bmp180ReadPressure();
- up = bmp180ReadPressure(); // 讀取壓強(qiáng)
- x1 = ((long)ut - ac6) * ac5 >> 15;
- x2 = ((long) mc << 11) / (x1 + md);
- b5 = x1 + x2;
- temperature = (b5 + 8) >> 4;
- conversion(temperature);
- DisplayOneChar(0,0,'W'); //溫度顯示
- DisplayOneChar(1,0,'e');
- DisplayOneChar(2,0,'n');
- DisplayOneChar(3,0,'D');
- DisplayOneChar(4,0,'u');
- DisplayOneChar(5,0,':');
- DisplayOneChar(7,0,bai);
- DisplayOneChar(8,0,shi);
- DisplayOneChar(9,0,'.');
- DisplayOneChar(10,0,ge);
- DisplayOneChar(11,0,0XDF); //溫度單位
- DisplayOneChar(12,0,'C');
- b6 = b5 - 4000;
- x1 = (b2 * (b6 * b6 >> 12)) >> 11;
- x2 = ac2 * b6 >> 11;
- x3 = x1 + x2;
- b3 = (((long)ac1 * 4 + x3) + 2)/4;
- x1 = ac3 * b6 >> 13;
- x2 = (b1 * (b6 * b6 >> 12)) >> 16;
- x3 = ((x1 + x2) + 2) >> 2;
- b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
- b7 = ((unsigned long) up - b3) * (50000 >> OSS);
- if( b7 < 0x80000000)
- p = (b7 * 2) / b4 ;
- else
- p = (b7 / b4) * 2;
- x1 = (p >> 8) * (p >> 8);
- x1 = (x1 * 3038) >> 16;
- x2 = (-7357 * p) >> 16;
- pressure = p + ((x1 + x2 + 3791) >> 4);
- conversion(pressure);
- DisplayOneChar(0,1,'Q'); //顯示壓強(qiáng)
- DisplayOneChar(1,1,'i');
- DisplayOneChar(2,1,'Y');
- DisplayOneChar(3,1,'a');
- DisplayOneChar(5,1,':');
- DisplayOneChar(6,1,shiwan);
- DisplayOneChar(7,1,wan);
- DisplayOneChar(8,1,qian);
- DisplayOneChar(9,1,'.');
- DisplayOneChar(10,1,bai);
- DisplayOneChar(11,1,shi);
- DisplayOneChar(12,1,'K'); //氣壓?jiǎn)挝?br />
- DisplayOneChar(13,1,'p');
- DisplayOneChar(14,1,'a');
- //******主程序********
- void main()
- delay(50); //上電延時(shí)
- InitLcd(); //液晶初始化
- Init_BMP180(); //初始化BMP085
- while(1) //循環(huán)
- bmp180Convert();
- delay(1000);
復(fù)制代碼 |
