查看: 3721|回復: 0
51控制pcf8591測溫并發給PC
ID:95068 發表于 2015-11-21 18:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
功能: 先向單片機發送01,單片機回AD  is  working,然后利用PCF8591上的熱敏電阻,一秒鐘測溫一百次,取平均值,一秒發送一次到PC,想單片機發送00,單片機回AD is stop,測溫停止
#include<reg52.h>
#include<intrins.h>
#include<stdio.h>
sbit  SCL=P2^6;
sbit  SDA=P2^7;
uchar flag1,a,b,c;
float m,S;
void delay()
void init()
{  SCL=1;
   delay();
   SDA=1;
   delay();
void start()
{   init();
          SDA=0;
          delay();
void stop()
        SDA=0;
        delay();
        SCL=1;
        delay();
        SDA=1;
        delay();
void write(uchar date)
{         uchar i,temp;
     temp=date;
         for(i=0;i<8;i++)
          { temp=temp<<1;
            SCL=0;
            delay();
            SDA=CY;
            delay();
            SCL=1;
            delay();
         SCL=0;
         delay();
         SDA=1;
         delay();
void respons()
{         uchar i;
     SCL=1;
         delay();
         while((SDA==1)&&(i<250))
           i++;
         SCL=0;
         delay();
uchar read()
{    uchar i,k;
           SCL=0;
           delay();
           SDA=1;
           delay();
           for(i=0;i<8;i++)
        SCL=1;
                         delay();
                         k=(k<<1)|SDA;
                         SCL=0;
                         delay();
                 return k;
void  writeadd(uchar add,uchar date)
{   start();
          write(0x90);
          respons();
          write(add);
          respons();
          write(date);
          respons();
          stop();
uchar  readadd(uchar add)
{   uchar date;
          start();
          write(0x90);
          respons();
          write(0x40|add);
          respons();
          start();
          write(0x91);
          respons();
          date=read();
          respons();
          stop();
          return date;
void  inits()
         TMOD=0x21;
         SCON=0x50;
     TH0=(65536-10000)/256;
     TL0=(65536-10000)%256;
         TH1=0xfd;
         TL1=0xfd;
         TR1=1;
         ET0=1;
         EA=1;
         ES=1;
                         inits();
                         if(flag1==1)
                                 flag1=0;
                                 ES=0;
                                 TI=1;
                                        if(c==1)
                                        {printf("AD is working\n");TR0=1;}
                                        {  printf("AD is stop\n"); TR0=0;}
                                        while(!TI);
                                        TI=0;
                                        ES=1;
                                 if(a>=100)
                                        a=0;
                                        S=S/100.0;
                        ES=0;
                                    TI=1;
                                    printf("T= %f ℃",S);
                                    while(!TI);
                                    TI=0;
                                    ES=1;
void T0_time() interrupt 1
     b=readadd(0);
         m=(float)b*30.0/256.0;
         S=S+m;
         a++;
void ser() interrupt 4
          RI=0;
          c=SBUF;
          flag1=1;
admin + 50 共享資料的積分獎勵!
