查看: 4022|回復: 3
12864溫度顯示,并行 帶字庫 亂碼
ID:95263 發表于 2015-11-10 11:28 | 顯示全部樓層 |閱讀模式
#include <12864.h>
#include "delay.h"
sbit RS = P2^2;
sbit RW = P2^3;
sbit E  = P2^4;
sbit RES = P2^7;
sbit PSB = P2^5;
#define DataPort P0        //MCU P0<------> LCM
unsigned char code user16x16[]={ //笑臉圖片
0x0F,0xF0,0x10,0x08,0x20,0x04,0x40,0x02,0x9C,0x39,0xBE,0x7D,0x80,0x01,0x80,0x01,
0x80,0x01,0x88,0x11,0x84,0x21,0x43,0xC2,0x20,0x04,0x10,0x08,0x0F,0xF0,0x00,0x00,
                    檢測忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙則等待
    E=0;
                   寫命令
void Write_Cmd(unsigned char Cmd)
Check_Busy();
RS=0;
RW=0;
E=1;
DataPort=Cmd;
DelayUs2x(5);
E=0;
DelayUs2x(5);
                    寫數據
void Write_Data(unsigned char Data)
Check_Busy();
RS=1;
RW=0;
E=1;
DataPort=Data;
DelayUs2x(5);
E=0;
DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延時程序
   PSB=1;                 //設置為8BIT并口工作模式
   DelayMs(1);            //延時
   RES=0;                 //復位
   DelayMs(1);            //延時
   RES=1;                 //復位置高
   DelayMs(10);
   Write_Cmd(0x30);       //選擇基本指令集
   DelayUs2x(50);         //延時大于100us
   Write_Cmd(0x30);       //選擇8bit數據流
   DelayUs2x(20);         //延時大于37us
   Write_Cmd(0x0c);       //開顯示(無游標、不反白)
   Write_Cmd(0x01);       //清除顯示,并且設定地址指針為00H
   DelayMs(15);           //延時大于10ms
   Write_Cmd(0x06);       //指定在資料的讀取及寫入時,設定游標的移動方向及指定顯示的移位,光標從右向左加1位移動
                   用戶自定義字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
     for(i=0;i<16;i++)
     Write_Data(user16x16[i*2]);
        Write_Data(user16x16[i*2+1]);
                   顯示用戶自定義字符
void DisplayCGRAM(unsigned char x,unsigned char y)
switch(y)
   case 1: Write_Cmd(0x80+x);break;
   case 2: Write_Cmd(0x90+x);break;
   case 3: Write_Cmd(0x88+x);break;
   case 4: Write_Cmd(0x98+x);break;
      default:break;
    Write_Data(00);
    Write_Data(00);
                   顯示字符串
x:橫坐標值,范圍0~8
y:縱坐標值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
main()
  unsigned char i, num=0,j;
  unsigned char temp[7;//定義顯示區域臨時存儲數組
  float Voltage;        //定義浮點變量
  CGRAM();     //寫入自定義字符
  Init_ST7920();   //初始化
  ClrScreen();
       for(j=0;j<5;j++)
       num=ReadADC(0);
       Voltage=(float)num*5/256;
       sprintf(temp,"%d",Voltage);
     LCD_PutString(0,3,"顯示:");
       LCD_PutString(4,3,temp);
       DisplayCGRAM(7,1); //在第一行第一個位置和
     DisplayCGRAM(0,1); //最后一個位置寫入自定義圖片笑臉
   for(i=0;i<30;i++)  //延時30x200ms
       DelayMs(200);
       ClrScreen();
ID:1 發表于 2015-11-10 11:48 來自觸屏版 | 顯示全部樓層
有沒有安裝漢字補丁?
ID:95263 發表于 2015-11-11 14:09 | 顯示全部樓層
admin 發表于 2015-11-10 11:48
有沒有安裝漢字補?
那個需要嗎
ID:7485 發表于 2015-11-11 19:55 | 顯示全部樓層
程序不完整,看不出來。
