#include<reg51.h> //包含51單片機(jī)寄存器定義的頭文件
sbit S1=P1^4; //將S1位定義為P1.4引腳
sbit S2=P1^5; //將S2位定義為P1.5引腳
sbit S3=P1^6; //將S3位定義為P1.6引腳
unsigned char keyval; //儲(chǔ)存按鍵值
unsigned char ID; //儲(chǔ)存功能標(biāo)號(hào)
軟件消抖延時(shí)(約50ms)
void delay(void)
unsigned char i,j;
for(i=0;i<150;i++)
for(j=0;j<100;j++)
步進(jìn)電機(jī)轉(zhuǎn)動(dòng)延時(shí),延時(shí)越長(zhǎng),轉(zhuǎn)速越慢
void motor_delay(void)
unsigned int i;
for(i=0;i<8000;i++)
步進(jìn)電機(jī)正轉(zhuǎn)
void forward( )
P0=0xfc; //P0口低四位脈沖1100
motor_delay();
P0=0xf6; //P0口低四位脈沖0110
motor_delay();
P0=0xf3; //P0口低四位脈沖0011
motor_delay();
P0=0xf9; //P0口低四位脈沖1001
motor_delay();
步進(jìn)電機(jī)反轉(zhuǎn)
void backward()
motor_delay();
motor_delay();
motor_delay();
motor_delay();
步進(jìn)電機(jī)停轉(zhuǎn)
void stop(void)
P0=0xff ; //停止輸出脈沖
主函數(shù)
void main(void)
TMOD=0x01; //使用定時(shí)器T0的模式1
EA=1; //開(kāi)總中斷
ET0=1; //定時(shí)器T0中斷允許
TR0=1; //啟動(dòng)定時(shí)器T0
TH0=(65536-500)/256; //定時(shí)器T0賦初值,每計(jì)數(shù)200次(217微秒)發(fā)送一次中斷請(qǐng)求
TL0=(65536-500)%256; //定時(shí)器T0賦初值
keyval=0; //按鍵值初始化為0,什么也不做
ID=0;
switch(keyval) //根據(jù)按鍵值keyval選擇待執(zhí)行的功能
case 1:forward(); //按鍵S1按下,正轉(zhuǎn)
break;
case 2:backward(); //按鍵S2按下 ,反轉(zhuǎn)
break;
case 3:stop(); //按鍵S3按下,停轉(zhuǎn)
break;
定時(shí)器T0的中斷服務(wù)子程序
void Time0_serve(void) interrupt 1 using 1
TR0=0; //關(guān)閉定時(shí)器T0
if((P1&0xf0)!=0xf0) //第一次檢測(cè)到有鍵按下
delay(); //延時(shí)一段時(shí)間再去檢測(cè)
if((P1&0xf0)!=0xf0) //確實(shí)有鍵按下
if(S1==0) //按鍵S1被按下
keyval=1;
if(S2==0) //按鍵S2被按下
keyval=2;
if(S3==0) //按鍵S3被按下
keyval=3;
TH0=(65536-200)/256; //定時(shí)器T0的高8位賦初值
TL0=(65536-200)%256; //定時(shí)器T0的低8位賦初值
用L298N做驅(qū)動(dòng)
L298N
