#include<reg51.h> //頭文件
#define uchar unsigned char //數(shù)據(jù)格式宏定義
#define uint unsigned int //數(shù)據(jù)格式宏定義
sbit rs=P3^5; //lcd寄存器選擇
sbit lcden=P3^4; //lcd使能端
sbit s1=P1^0; //開(kāi)關(guān)s1
sbit s2=P1^1; //開(kāi)關(guān)s2
sbit s3=P1^2; //開(kāi)關(guān)s3
sbit beep=P1^3; //蜂鳴器
sbit dscs=P1^4; //ds12c887片選
sbit dsas=P1^5; // ds12c887地址選通輸入腳
sbit dsrw=P1^6; // ds12c887讀/寫(xiě)輸入端
sbit dsds=P1^7; // ds12c887數(shù)據(jù)選擇或讀輸入腳
sbit dsirq=P3^3; // ds12c887中斷請(qǐng)求輸入
uchar count,s1num,flag,flag1; //狀態(tài)變量
char miao,shi,fen,nian,yue,ri,xingqi,amiao,afen,ashi; //數(shù)據(jù)變量
uchar code table[]=" 20 - - "; //年月日顯示格式
uchar code table1[]=" : : "; //時(shí)間顯示格式
uchar code table2[]="MONTHUWENTHRFRISTASUN"; //星期表,每3位為一個(gè)
uchar code table3[]=" ALARM ON "; //開(kāi)鬧鐘提示
uchar code table4[]=" ALARM OFF "; //關(guān)鬧鐘提示
uchar code table5[]="SET ALARM PUSH "; //鬧鐘狀態(tài)選擇提示
void write_ds(uchar,uchar); //函數(shù)聲明
void set_alarm(uchar,uchar,uchar);
uchar read_ds(uchar);
void delay(uint z) //延時(shí)子函數(shù)
{ uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void beezzer() //蜂鳴器發(fā)聲控制函數(shù)(鬧鐘響鈴),beep=0發(fā)聲
beep=0;
delay(50);
beep=1;
delay(100);
beep=0;
delay(50);
beep=1;
void write_com(uchar com) //向lcd寫(xiě)入控制字com,根據(jù)lcd1602時(shí)序圖進(jìn)行操作,rs為寄存器選擇
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date) //向lcd寫(xiě)入數(shù)據(jù)date,根據(jù)lcd1602時(shí)序圖進(jìn)行操作
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init() //初始化單片機(jī)
uchar num;
EA=1; //開(kāi)總中斷
EX1=1; //允許外部中斷1
IT1=1; //低電平觸發(fā)
beep=1;
flag1=0;
lcden=0;
write_ds(0x0A,0x20); //向ds12c887控制寄存器A發(fā)送初始化控制字,啟動(dòng)振蕩器
write_ds(0x0B,0x26); //向ds12c887控制寄存器B發(fā)送初始化控制字,設(shè)定工作模式bcd,24小時(shí)制
read_ds(0x0c); //讀芯片時(shí)間數(shù)據(jù)
write_com(0x38);
write_com(0x0c); //初始化lcd
write_com(0x06);
write_com(0x01);
write_com(0x80); //在第一行顯示數(shù)據(jù)
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40); //在第二行顯示數(shù)據(jù)
for(num=0;num<12;num++)
write_date(table1[num]);
delay(5);
void write_sfm(uchar add,uchar date) //向lcd寫(xiě)入時(shí)分秒數(shù)據(jù)
uchar shi,ge; //shi:待發(fā)數(shù)據(jù)十位;ge:待發(fā)數(shù)據(jù)個(gè)位
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void write_nyr(uchar add,uchar date) //向lcd寫(xiě)入年月日數(shù)據(jù)
shi=date/10;
ge=date%10;
write_com(0x80+add);
void write_xingqi(uchar add,uchar date) //向lcd寫(xiě)入星期數(shù)據(jù)
date=(date-1)*3; //如星期一讀表123個(gè)字母MON顯示,星期二讀456字母THU等等
write_date(table2[date]);
write_date(table2[++date]);
void keyscan() //鍵盤(pán)掃描子程序
if(flag1==1)
if(s2==0) //“加”鍵
delay(5);
if(s2==0)
while(!s2);
flag1=0;
if(s3==0) //“減”鍵
delay(5);
if(s3==0)
while(!s3);
flag1=0;
if(s1==0) //功能選擇鍵,統(tǒng)計(jì)按下次數(shù)在s1num中
delay(5);
if(s1==0)
s1num++;
flag=1;
flag1=0;
while(!s1);
if(s1num==1)
TR0=0;
write_com(0x80+0x40+11);
write_com(0x0f);
if(s1num==2) //以下if語(yǔ)句是使光標(biāo)在對(duì)應(yīng)位置閃爍
write_com(0x80+0x40+8);
if(s1num==3)
write_com(0x80+0x40+5);
if(s1num==4)
write_com(0x80+14);
if(s1num==5)
write_com(0x80+10);
if(s1num==6)
write_com(0x80+7);
if(s1num==7)
write_com(0x80+4);
if(s1num==8) //此判斷語(yǔ)句顯示table5表內(nèi)容,鬧鐘狀態(tài)顯示
uchar n;
write_com(0x80);
for(n=0;n<15;n++)
write_date(table5[n]);
write_com(0x80+14);
if(s1num==9)
if(s1num==10)
if(s1num==11)
if(s1num==12) //執(zhí)行時(shí)間寫(xiě)入ds12c887芯片操作
uchar num;
s1num=0;
write_com(0x0c); //設(shè)置控制寄存器,狀態(tài)設(shè)置為寫(xiě)
flag=0;
write_ds(0,miao);
write_ds(2,fen);
write_ds(4,shi);
write_ds(6,xingqi);
write_ds(7,ri);
write_ds(8,yue);
write_ds(9,nian);
set_alarm(ashi,afen,amiao);
write_com(0x80);
delay(5);
delay(5);
if(s1num!=0) //根據(jù)s1num按下次數(shù)執(zhí)行相應(yīng)的數(shù)據(jù)設(shè)置
if(s2==0) //當(dāng)s2按下時(shí),如果
delay(1);
if(s2==0)
while(!s2);
if(s1num==1) //按s1按鍵1次改秒
miao++;
if(miao==60)
miao=0;
write_sfm(10,miao);
if(s1num==2) //按s1按鍵2次改分
fen++;
if(fen==60)
fen=0;
write_sfm(7,fen);
if(s1num==3) //按s1按鍵3次改時(shí)
shi++;
if(shi==24)
shi=0;
write_sfm(4,shi);
if(s1num==4) //按s1按鍵4次改星期
xingqi++;
if(xingqi==8)
xingqi=1;
write_xingqi(12,xingqi);
write_com(0x80+14);
if(s1num==5) //按s1按鍵5次改日期
ri++;
if(ri==32)
ri=1;
write_nyr(9,ri);
write_com(0x80+10);
if(s1num==6) //按s1按鍵6次改月
yue++;
if(yue==13)
yue=1;
write_nyr(6,yue);
write_com(0x80+7);
if(s1num==7) //按s1按鍵7次改年
nian++;
if(nian==100)
nian=0;
write_nyr(3,nian);
write_com(0x80+4);
if(s1num==8) //按s1按鍵8次改鬧鐘狀態(tài)開(kāi)還是關(guān)
uchar n;
write_ds(0x0B,0x26); //向B控制寄存器寫(xiě)入控制字
write_com(0x80);
for(n=0;n<15;n++)
write_date(table3[n]);
write_com(0x80+14);
if(s1num==9) //按s1按鍵9次改鬧鐘時(shí)間秒
amiao++;
if(amiao==60)
amiao=0;
write_sfm(10,amiao);
if(s1num==10) //按s1按鍵10次改鬧鐘時(shí)間分
afen++;
if(afen==60)
afen=0;
write_sfm(7,afen);
if(s1num==11) //按s1按鍵11次改鬧鐘時(shí)間時(shí)
ashi++;
if(ashi==24)
ashi=0;
write_sfm(4,ashi);
if(s3==0)
delay(1);
if(s3==0) //當(dāng)s3按下時(shí),如果:
while(!s3);
miao--;
if(miao==-1)
miao=59;
write_sfm(10,miao);
fen--;
if(fen==-1)
fen=59;
write_sfm(7,fen);
shi--;
if(shi==-1)
shi=23;
write_sfm(4,shi);
xingqi--;
if(xingqi==0)
xingqi=7;
write_com(0x80+14);
ri--;
if(ri==0)
ri=31;
write_nyr(9,ri);
write_com(0x80+10);
yue--;
if(yue==0)
yue=12;
write_nyr(6,yue);
write_com(0x80+7);
nian--;
if(nian==-1)
nian=99;
write_nyr(3,nian);
write_com(0x80+4);
uchar n;
write_ds(0x0B,0x06);
write_com(0x80);
for(n=0;n<15;n++)
write_date(table4[n]);
write_com(0x80+14);
if(s1num==9) //按s1按鍵9次改鬧鐘秒
amiao--;
if(amiao==-1)
amiao=59;
if(s1num==10) //按s1按鍵10次改鬧鐘分
afen--;
if(afen==-1)
afen=59;
write_sfm(7,afen);
ashi--;
if(ashi==-1)
ashi=23;
write_sfm(4,ashi);
void write_ds(uchar add,uchar date) //向DS12c887寫(xiě)入數(shù)據(jù)子函數(shù)
dscs=0;
dsas=1;
dsds=1;
dsrw=1;
P0=add; //寫(xiě)地址
dsas=0;
dsrw=0;
P0=date; //寫(xiě)數(shù)據(jù)
dsrw=1;
dsas=1;
dscs=1;
uchar read_ds(uchar add) //讀DS12C887芯片數(shù)據(jù),add為寄存器地址,詳見(jiàn)表格
uchar ds_date;
dsas=1;
dsds=1;
dsrw=1;
dscs=0;
P0=add;
dsas=0;
dsds=0;
// P0=0xff;
ds_date=P0;
dsds=1;
dsas=1;
dscs=1;
return ds_date;
void set_alarm(uchar ashi,uchar afen,uchar amiao) //向ds12c887寫(xiě)入設(shè)置鬧鐘定時(shí)時(shí)間子函數(shù)
write_ds(1,amiao);
write_ds(3,afen);
write_ds(5,ashi);
void main() //主函數(shù)
init(); //初始化函數(shù)
keyscan();
if(flag1==1)
beezzer();
if(flag==0&flag1==0)
amiao=read_ds(0);
afen=read_ds(2);
ashi=read_ds(4);
miao=read_ds(0);
fen=read_ds(2);
shi=read_ds(4);
xingqi=read_ds(6);
ri=read_ds(7);
yue=read_ds(8);
nian=read_ds(9);
write_sfm(10,miao);
write_sfm(7,fen);
write_sfm(4,shi);
write_nyr(9,ri);
write_nyr(6,yue);
write_nyr(3,nian);
void exter() interrupt 2 //外部中斷1響應(yīng)處理函數(shù)(改變flag值使蜂鳴器發(fā)聲)
{ uchar c;
flag1=1;
c=read_ds(0x0c);
