用單片機定時中斷完成矩陣鍵盤的掃描,但是總是不對。下面是我的程序。求,高手指證!!!!
(鍵盤我只用了前四個)
#include<reg52.h>
uchar code table[]={
0xfe,0xfd,0xfb,0xf7,0xef,
0xdf,0xbf,0x7f};
sbit dula=P2^6;
sbit wela=P2^7;
void delay(uint z) //延時函數(shù)
uint x,y;
for(x=z;x>0;x--)
for(y=114;y>0;y--);
void display(uchar num)
dula=1;
P0=table[num];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
delay(5);
uchar num;
TMOD=0x01;
TH0=(65536-1000)/256;
TL0=(65536-1000)%256;
EA=1;
ET0=1;
TR0=1;
display(num);
void IT_0()interrupt 1
if((P1&0xf0)!=0xf0)
uchar temp,key;
P3=0xfe;
temp=P3;
temp=temp&0xf0;
if(temp!=0xf0)
delay(5);
if(temp!=0xf0)
temp=P3;
switch(temp)
case 0xee:
key=0;
break;
case 0xde:
key=1;
break;
case 0xbe:
key=2;
break;
case 0x7e:
key=3;
break;
while(temp!=0xf0)
temp=P3;
temp=temp&0xf0;
display(key);
