只需一步,快速開(kāi)始
查看: 6629|回復(fù): 0
system_stm32f10x.c文件內(nèi)容分析
ID:91350 發(fā)表于 2015-9-30 13:22 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這個(gè)文件完成了寫(xiě)聲明配置,他和對(duì)應(yīng)的頭文件的關(guān)系,頭文件里做了些什么工作,為什么要這樣
完成系統(tǒng)時(shí)鐘的配置。
  1. #include "stm32f10x.h"
  2. #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  3. #define SYSCLK_FREQ_24MHz  24000000
  4. #else
  5.    #define SYSCLK_FREQ_72MHz  72000000
  6. #endif
  7. #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  8. #endif
  9. #define VECT_TAB_OFFSET  0x0
  10. #ifdef SYSCLK_FREQ_HSE
  11.   uint32_t SystemCoreClock         = SYSCLK_FREQ_HSE;
  12. #elif defined SYSCLK_FREQ_24MHz
  13.   uint32_t SystemCoreClock         = SYSCLK_FREQ_24MHz;
  14. #elif defined SYSCLK_FREQ_36MHz
  15.   uint32_t SystemCoreClock         = SYSCLK_FREQ_36MHz;
  16. #elif defined SYSCLK_FREQ_48MHz
  17.   uint32_t SystemCoreClock         = SYSCLK_FREQ_48MHz;
  18. #elif defined SYSCLK_FREQ_56MHz
  19.   uint32_t SystemCoreClock         = SYSCLK_FREQ_56MHz;
  20. #elif defined SYSCLK_FREQ_72MHz
  21.   uint32_t SystemCoreClock         = SYSCLK_FREQ_72MHz;
  22. #else
  23.   uint32_t SystemCoreClock         = HSI_VALUE;
  24. #endif
  25. __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
  26. static void SetSysClock(void);
  27. #ifdef SYSCLK_FREQ_HSE
  28.   static void SetSysClockToHSE(void);
  29. #elif defined SYSCLK_FREQ_24MHz
  30.   static void SetSysClockTo24(void);
  31. #elif defined SYSCLK_FREQ_36MHz
  32.   static void SetSysClockTo36(void);
  33. #elif defined SYSCLK_FREQ_48MHz
  34.   static void SetSysClockTo48(void);
  35. #elif defined SYSCLK_FREQ_56MHz
  36.   static void SetSysClockTo56(void);
  37. #elif defined SYSCLK_FREQ_72MHz
  38.   static void SetSysClockTo72(void);
  39. #endif
  40. #ifdef DATA_IN_ExtSRAM
  41.   static void SystemInit_ExtMemCtl(void);
  42. #endif
  43. void SystemInit (void)
  44. {
  45.   RCC->CR |= (uint32_t)0x00000001;
  46. #ifndef STM32F10X_CL
  47.   RCC->CFGR &= (uint32_t)0xF8FF0000;
  48. #else
  49.   RCC->CFGR &= (uint32_t)0xF0FF0000;
  50. #endif
  51.
  52.   RCC->CR &= (uint32_t)0xFEF6FFFF;
  53.   RCC->CR &= (uint32_t)0xFFFBFFFF;
  54.   RCC->CFGR &= (uint32_t)0xFF80FFFF;
  55. #ifdef STM32F10X_CL
  56.   RCC->CR &= (uint32_t)0xEBFFFFFF;
  57.   RCC->CIR = 0x00FF0000;
  58.   RCC->CFGR2 = 0x00000000;
  59. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  60.   RCC->CIR = 0x009F0000;
  61.   RCC->CFGR2 = 0x00000000;
  62. #else
  63.   RCC->CIR = 0x009F0000;
  64. #endif
  65.
  66. #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
  67.   #ifdef DATA_IN_ExtSRAM
  68.     SystemInit_ExtMemCtl();
  69.   #endif
  70. #endif
  71.   SetSysClock();
  72. #ifdef VECT_TAB_SRAM
  73.   SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET;
  74. #else
  75.   SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET;
  76. #endif
  77. }
  78. void SystemCoreClockUpdate (void)
  79. {
  80.   uint32_t tmp = 0, pllmull = 0, pllsource = 0;
  81. #ifdef  STM32F10X_CL
  82.   uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
  83. #endif
  84. #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  85.   uint32_t prediv1factor = 0;
  86. #endif
  87.
  88.   tmp = RCC->CFGR & RCC_CFGR_SWS;
  89.
  90.   switch (tmp)
  91.   {
  92.     case 0x00:
  93.       SystemCoreClock = HSI_VALUE;
  94.       break;
  95.     case 0x04:
  96.       SystemCoreClock = HSE_VALUE;
  97.       break;
  98.     case 0x08:
  99.
  100.       pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
  101.       pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
  102.
  103. #ifndef STM32F10X_CL
  104.       pllmull = ( pllmull >> 18) + 2;
  105.
  106.       if (pllsource == 0x00)
  107.       {
  108.
  109.         SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
  110.       }
  111.       else
  112.       {
  113. #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
  114.        prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
  115.
  116.        SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
  117. #else
  118.
  119.         if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
  120.         {
  121.           SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
  122.         }
  123.         else
  124.         {
  125.           SystemCoreClock = HSE_VALUE * pllmull;
  126.         }
  127. #endif
  128.       }
  129. #else
  130.       pllmull = pllmull >> 18;
  131.
  132.       if (pllmull != 0x0D)
  133.       {
  134.          pllmull += 2;
  135.       }
  136.       else
  137.       {
  138.         pllmull = 13 / 2;
  139.       }
  140.
  141.       if (pllsource == 0x00)
  142.       {
  143.
  144.         SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
  145.       }
  146.       else
  147.       {
  148.
  149.
  150.         prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
  151.         prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
  152.
  153.         if (prediv1source == 0)
  154.         {
  155.
  156.           SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
  157.         }
  158.         else
  159.         {
  160.
  161.
  162.           prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
  163.           pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
  164.           SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
  165.         }
  166.       }
  167. #endif
  168.       break;
  169.     default:
  170.       SystemCoreClock = HSI_VALUE;
  171.       break;
  172.   }
  173.
  174.   tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
  175.   SystemCoreClock >>= tmp;
  176. }
  177. static void SetSysClock(void)
  178. {
  179. #ifdef SYSCLK_FREQ_HSE
  180.   SetSysClockToHSE();
  181. #elif defined SYSCLK_FREQ_24MHz
  182.   SetSysClockTo24();
  183. #elif defined SYSCLK_FREQ_36MHz
  184.   SetSysClockTo36();
  185. #elif defined SYSCLK_FREQ_48MHz
  186.   SetSysClockTo48();
  187. #elif defined SYSCLK_FREQ_56MHz
  188.   SetSysClockTo56();
  189. #elif defined SYSCLK_FREQ_72MHz
  190.   SetSysClockTo72();
  191. #endif
  192.
  193. }
  194. #ifdef DATA_IN_ExtSRAM
  195. void SystemInit_ExtMemCtl(void)
  196. {
  197.   RCC->AHBENR = 0x00000114;
  198.
  199.
  200.   RCC->APB2ENR = 0x000001E0;
  201.
  202.
  203.   GPIOD->CRL = 0x44BB44BB;
  204.   GPIOD->CRH = 0xBBBBBBBB;
  205.   GPIOE->CRL = 0xB44444BB;
  206.   GPIOE->CRH = 0xBBBBBBBB;
  207.   GPIOF->CRL = 0x44BBBBBB;
  208.   GPIOF->CRH = 0xBBBB4444;
  209.   GPIOG->CRL = 0x44BBBBBB;
  210.   GPIOG->CRH = 0x44444B44;
  211.
  212.
  213.   FSMC_Bank1->BTCR[4] = 0x00001011;
  214.   FSMC_Bank1->BTCR[5] = 0x00000200;
  215. }
  216. #endif
  217. #ifdef SYSCLK_FREQ_HSE
  218. static void SetSysClockToHSE(void)
  219. {
  220.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  221.
  222.
  223.
  224.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  225.   do
  226.   {
  227.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  228.     StartUpCounter++;
  229.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  230.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  231.   {
  232.     HSEStatus = (uint32_t)0x01;
  233.   }
  234.   else
  235.   {
  236.     HSEStatus = (uint32_t)0x00;
  237.   }
  238.   if (HSEStatus == (uint32_t)0x01)
  239.   {
  240. #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
  241.
  242.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  243.
  244.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  245. #ifndef STM32F10X_CL
  246.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  247. #else
  248.     if (HSE_VALUE <= 24000000)
  249. {
  250.       FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  251. }
  252. else
  253. {
  254.       FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  255. }
  256. #endif
  257. #endif
  258.
  259.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  260.
  261.
  262.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  263.
  264.
  265.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  266.
  267.
  268.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  269.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_HSE;
  270.
  271.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x04)
  272.     {
  273.     }
  274.   }
  275.   else
  276.   {
  277.   }
  278. }
  279. #elif defined SYSCLK_FREQ_24MHz
  280. static void SetSysClockTo24(void)
  281. {
  282.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  283.
  284.
  285.
  286.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  287.   do
  288.   {
  289.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  290.     StartUpCounter++;
  291.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  292.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  293.   {
  294.     HSEStatus = (uint32_t)0x01;
  295.   }
  296.   else
  297.   {
  298.     HSEStatus = (uint32_t)0x00;
  299.   }
  300.   if (HSEStatus == (uint32_t)0x01)
  301.   {
  302. #if !defined STM32F10X_LD_VL && !defined STM32F10X_MD_VL && !defined STM32F10X_HD_VL
  303.
  304.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  305.
  306.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  307.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_0;
  308. #endif
  309.
  310.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  311.
  312.
  313.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  314.
  315.
  316.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  317.
  318. #ifdef STM32F10X_CL
  319.
  320.
  321.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  322.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  323.                             RCC_CFGR_PLLMULL6);
  324.
  325.
  326.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  327.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  328.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  329.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
  330.
  331.
  332.     RCC->CR |= RCC_CR_PLL2ON;
  333.
  334.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  335.     {
  336.     }
  337. #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
  338.
  339.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  340.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL6);
  341. #else
  342.
  343.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  344.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL6);
  345. #endif
  346.
  347.     RCC->CR |= RCC_CR_PLLON;
  348.
  349.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  350.     {
  351.     }
  352.
  353.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  354.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  355.
  356.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  357.     {
  358.     }
  359.   }
  360.   else
  361.   {
  362.   }
  363. }
  364. #elif defined SYSCLK_FREQ_36MHz
  365. static void SetSysClockTo36(void)
  366. {
  367.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  368.
  369.
  370.
  371.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  372.   do
  373.   {
  374.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  375.     StartUpCounter++;
  376.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  377.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  378.   {
  379.     HSEStatus = (uint32_t)0x01;
  380.   }
  381.   else
  382.   {
  383.     HSEStatus = (uint32_t)0x00;
  384.   }
  385.   if (HSEStatus == (uint32_t)0x01)
  386.   {
  387.
  388.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  389.
  390.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  391.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  392.
  393.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  394.
  395.
  396.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  397.
  398.
  399.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV1;
  400.
  401. #ifdef STM32F10X_CL
  402.
  403.
  404.
  405.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  406.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  407.                             RCC_CFGR_PLLMULL9);
  408.
  409.
  410.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  411.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  412.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  413.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV10);
  414.
  415.
  416.     RCC->CR |= RCC_CR_PLL2ON;
  417.
  418.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  419.     {
  420.     }
  421.
  422. #else
  423.
  424.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  425.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLXTPRE_HSE_Div2 | RCC_CFGR_PLLMULL9);
  426. #endif
  427.
  428.     RCC->CR |= RCC_CR_PLLON;
  429.
  430.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  431.     {
  432.     }
  433.
  434.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  435.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  436.
  437.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  438.     {
  439.     }
  440.   }
  441.   else
  442.   {
  443.   }
  444. }
  445. #elif defined SYSCLK_FREQ_48MHz
  446. static void SetSysClockTo48(void)
  447. {
  448.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  449.
  450.
  451.
  452.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  453.   do
  454.   {
  455.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  456.     StartUpCounter++;
  457.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  458.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  459.   {
  460.     HSEStatus = (uint32_t)0x01;
  461.   }
  462.   else
  463.   {
  464.     HSEStatus = (uint32_t)0x00;
  465.   }
  466.   if (HSEStatus == (uint32_t)0x01)
  467.   {
  468.
  469.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  470.
  471.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  472.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
  473.
  474.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  475.
  476.
  477.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  478.
  479.
  480.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  481.
  482. #ifdef STM32F10X_CL
  483.
  484.
  485.
  486.
  487.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  488.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  489.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  490.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  491.
  492.
  493.     RCC->CR |= RCC_CR_PLL2ON;
  494.
  495.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  496.     {
  497.     }
  498.
  499.
  500.
  501.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  502.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  503.                             RCC_CFGR_PLLMULL6);
  504. #else
  505.
  506.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  507.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL6);
  508. #endif
  509.
  510.     RCC->CR |= RCC_CR_PLLON;
  511.
  512.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  513.     {
  514.     }
  515.
  516.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  517.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  518.
  519.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  520.     {
  521.     }
  522.   }
  523.   else
  524.   {
  525.   }
  526. }
  527. #elif defined SYSCLK_FREQ_56MHz
  528. static void SetSysClockTo56(void)
  529. {
  530.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  531.
  532.
  533.
  534.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  535.   do
  536.   {
  537.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  538.     StartUpCounter++;
  539.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  540.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  541.   {
  542.     HSEStatus = (uint32_t)0x01;
  543.   }
  544.   else
  545.   {
  546.     HSEStatus = (uint32_t)0x00;
  547.   }
  548.   if (HSEStatus == (uint32_t)0x01)
  549.   {
  550.
  551.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  552.
  553.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  554.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
  555.
  556.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  557.
  558.
  559.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  560.
  561.
  562.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  563. #ifdef STM32F10X_CL
  564.
  565.
  566.
  567.
  568.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  569.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  570.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  571.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  572.
  573.
  574.     RCC->CR |= RCC_CR_PLL2ON;
  575.
  576.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  577.     {
  578.     }
  579.
  580.
  581.
  582.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  583.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  584.                             RCC_CFGR_PLLMULL7);
  585. #else
  586.
  587.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
  588.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL7);
  589. #endif
  590.
  591.     RCC->CR |= RCC_CR_PLLON;
  592.
  593.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  594.     {
  595.     }
  596.
  597.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  598.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  599.
  600.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  601.     {
  602.     }
  603.   }
  604.   else
  605.   {
  606.   }
  607. }
  608. #elif defined SYSCLK_FREQ_72MHz
  609. static void SetSysClockTo72(void)
  610. {
  611.   __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  612.
  613.
  614.
  615.   RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  616.   do
  617.   {
  618.     HSEStatus = RCC->CR & RCC_CR_HSERDY;
  619.     StartUpCounter++;
  620.   } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  621.   if ((RCC->CR & RCC_CR_HSERDY) != RESET)
  622.   {
  623.     HSEStatus = (uint32_t)0x01;
  624.   }
  625.   else
  626.   {
  627.     HSEStatus = (uint32_t)0x00;
  628.   }
  629.   if (HSEStatus == (uint32_t)0x01)
  630.   {
  631.
  632.     FLASH->ACR |= FLASH_ACR_PRFTBE;
  633.
  634.     FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
  635.     FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
  636.
  637.     RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
  638.
  639.
  640.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
  641.
  642.
  643.     RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
  644. #ifdef STM32F10X_CL
  645.
  646.
  647.
  648.
  649.     RCC->CFGR2 &= (uint32_t)~(RCC_CFGR2_PREDIV2 | RCC_CFGR2_PLL2MUL |
  650.                               RCC_CFGR2_PREDIV1 | RCC_CFGR2_PREDIV1SRC);
  651.     RCC->CFGR2 |= (uint32_t)(RCC_CFGR2_PREDIV2_DIV5 | RCC_CFGR2_PLL2MUL8 |
  652.                              RCC_CFGR2_PREDIV1SRC_PLL2 | RCC_CFGR2_PREDIV1_DIV5);
  653.
  654.
  655.     RCC->CR |= RCC_CR_PLL2ON;
  656.
  657.     while((RCC->CR & RCC_CR_PLL2RDY) == 0)
  658.     {
  659.     }
  660.
  661.
  662.
  663.     RCC->CFGR &= (uint32_t)~(RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLSRC | RCC_CFGR_PLLMULL);
  664.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLSRC_PREDIV1 |
  665.                             RCC_CFGR_PLLMULL9);
  666. #else
  667.
  668.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
  669.                                         RCC_CFGR_PLLMULL));
  670.     RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL9);
  671. #endif
  672.
  673.     RCC->CR |= RCC_CR_PLLON;
  674.
  675.     while((RCC->CR & RCC_CR_PLLRDY) == 0)
  676.     {
  677.     }
  678.
  679.
  680.     RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
  681.     RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
  682.
  683.     while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  684.     {
  685.     }
  686.   }
  687.   else
  688.   {
  689.   }
  690. }
  691. #endif
