;******************** (C) COPYRIGHT 2011 STMicroelectronics
;* File Name
startup_stm32f10x_hd.s
;* Author
: MCD Application Team
;* Version
: V3.5.0
;* Date
: 11-March-2011
;* Description
: STM32F10x High Density
Devices vector table for MDK-ARM
toolchain.
This module performs:
- Set the initial SP
- Set the initial PC ==
Reset_Handler
- Set the vector table entries
with the exceptions ISR address
- Configure the clock system
and also configure the external
SRAM
mounted on STM3210E-EVAL board to be used as
data
memory
(optional, to be enabled by user)
- Branches to __main in the C
library (which eventually
calls
main()).
After Reset the CortexM3
processor is in Thread mode,
priority is Privileged, and
the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu
; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT
PROVIDING CUSTOMERS
; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER
FOR THEM TO SAVE TIME.
; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR
ANY DIRECT,
; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS
ARISING FROM THE
; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF
THE CODING
; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR
PRODUCTS.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; Stack Configuration
; Stack Size (in Bytes)
<0x0-0xFFFFFFFF:8>
Stack_Size
EQU
0x00000400 EQU是代碼替換指令,是使0x00000400變的有意義易讀
AREA
STACK, NOINIT, READWRITE,
ALIGN=3 //定義一個數據段 按8字節對齊
;AREA 偽指令用于定義一個代碼段或數據段
NOINIT:指定此數據段僅僅保留了內存單元,而沒有將各初始值寫入內存單元,或者將各個內存單元值初始化為0
Stack_Mem
SPACE Stack_Size
為Stack_Mem 分配連續的0x00000400
字節空間,并且初始化為0
__initial_sp
_initial_sp
是個標簽,代表當前指令的地址,由匯編器計算出的,代碼里使用space分配了Stack_Size個內存單元后再在之后加上_initial_sp,后面會用DCD __initial_sp
在向量表0初始化棧頂地址,使用堆棧時棧頂地址減1恰好是分配的棧區間
; Heap Configuration
; Heap Size (in Bytes)
<0x0-0xFFFFFFFF:8>
Heap_Size
EQU
0x00000200
AREA
HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem
SPACE
Heap_Size
__heap_limit
PRESERVE8
THUMB
; Vector Table Mapped to Address 0 at Reset
AREA
RESET, DATA,
READONLY 定義一塊數據段,只可讀,段名字是RESET
EXPORT
__Vectors
EXPORT:在程序中聲明一個全局的標號__Vectors,該標號可在其他的文件中引用
EXPORT
__Vectors_End
EXPORT
__Vectors_Size
__Vectors
DCD
__initial_sp
; Top of Stack
__Vectors是個標號
;該處物理地址值即為 __Vetors 標號所表示的值,
;該地址中存儲__initial_sp所表示的地址值,
DCD (或 DCDU )偽指令用于分配一片連續的字存儲單元并用偽指令中指定的表達式初始化。其中,表達式可以為程序標號或數字表達式。
DCD
Reset_Handler
; Reset
Handler
DCD
NMI_Handler
; NMI Handler
DCD
HardFault_Handler
; Hard Fault Handler
DCD
MemManage_Handler
; MPU Fault Handler
DCD
BusFault_Handler
; Bus Fault Handler
DCD
UsageFault_Handler
; Usage
Fault Handler
DCD
0
; Reserved
DCD
0
; Reserved
DCD
0
; Reserved
DCD
0
; Reserved
DCD
SVC_Handler
; SVCall Handler
DCD
DebugMon_Handler
; Debug Monitor Handler
DCD
0
; Reserved
DCD
PendSV_Handler
; PendSV Handler
DCD
SysTick_Handler
; SysTick Handler
; External Interrupts
DCD
WWDG_IRQHandler
; Window Watchdog
DCD
PVD_IRQHandler
; PVD through EXTI Line
detect
DCD
TAMPER_IRQHandler
; Tamper
DCD
RTC_IRQHandler
; RTC
DCD
FLASH_IRQHandler
; Flash
DCD
RCC_IRQHandler
; RCC
DCD
EXTI0_IRQHandler
; EXTI Line 0
DCD
EXTI1_IRQHandler
; EXTI Line 1
DCD
EXTI2_IRQHandler
; EXTI Line 2
DCD
EXTI3_IRQHandler
; EXTI Line 3
DCD
EXTI4_IRQHandler
; EXTI Line 4
DCD
DMA1_Channel1_IRQHandler ;
DMA1 Channel 1
DCD
DMA1_Channel2_IRQHandler ;
DMA1 Channel 2
DCD
DMA1_Channel3_IRQHandler ;
DMA1 Channel 3
DCD
DMA1_Channel4_IRQHandler ;
DMA1 Channel 4
DCD
DMA1_Channel5_IRQHandler ;
DMA1 Channel 5
DCD
DMA1_Channel6_IRQHandler ;
DMA1 Channel 6
DCD
DMA1_Channel7_IRQHandler ;
DMA1 Channel 7
DCD
ADC1_2_IRQHandler
; ADC1 & ADC2
DCD
USB_HP_CAN1_TX_IRQHandler ;
USB High Priority or CAN1 TX
DCD
USB_LP_CAN1_RX0_IRQHandler ; USB Low
Priority or CAN1 RX0
DCD
CAN1_RX1_IRQHandler
; CAN1
RX1
DCD
CAN1_SCE_IRQHandler
; CAN1
SCE
DCD
EXTI9_5_IRQHandler
; EXTI
Line 9..5
DCD
TIM1_BRK_IRQHandler
; TIM1
Break
DCD
TIM1_UP_IRQHandler
; TIM1
Update
DCD
TIM1_TRG_COM_IRQHandler
; TIM1 Trigger and Commutation
DCD
TIM1_CC_IRQHandler
; TIM1
Capture Compare
DCD
TIM2_IRQHandler
; TIM2
DCD
TIM3_IRQHandler
; TIM3
DCD
TIM4_IRQHandler
; TIM4
DCD
I2C1_EV_IRQHandler
; I2C1
Event
DCD
I2C1_ER_IRQHandler
; I2C1
Error
DCD
I2C2_EV_IRQHandler
; I2C2
Event
DCD
I2C2_ER_IRQHandler
; I2C2
Error
DCD
SPI1_IRQHandler
; SPI1
DCD
SPI2_IRQHandler
; SPI2
DCD
USART1_IRQHandler
; USART1
DCD
USART2_IRQHandler
; USART2
DCD
USART3_IRQHandler
; USART3
DCD
EXTI15_10_IRQHandler
; EXTI Line 15..10
DCD
RTCAlarm_IRQHandler
; RTC Alarm
through EXTI Line
DCD
USBWakeUp_IRQHandler
; USB Wakeup from
suspend
DCD
TIM8_BRK_IRQHandler
; TIM8
Break
DCD
TIM8_UP_IRQHandler
; TIM8
Update
DCD
TIM8_TRG_COM_IRQHandler
; TIM8 Trigger and Commutation
DCD
TIM8_CC_IRQHandler
; TIM8
Capture Compare
DCD
ADC3_IRQHandler
; ADC3
DCD
FSMC_IRQHandler
; FSMC
DCD
SDIO_IRQHandler
; SDIO
DCD
TIM5_IRQHandler
; TIM5
DCD
SPI3_IRQHandler
; SPI3
DCD
UART4_IRQHandler
; UART4
DCD
UART5_IRQHandler
; UART5
DCD
TIM6_IRQHandler
; TIM6
DCD
TIM7_IRQHandler
; TIM7
DCD
DMA2_Channel1_IRQHandler ;
DMA2 Channel1
DCD
DMA2_Channel2_IRQHandler ;
DMA2 Channel2
DCD
DMA2_Channel3_IRQHandler ;
DMA2 Channel3
DCD
DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 &
Channel5
__Vectors_End
__Vectors_Size EQU
__Vectors_End - __Vectors 計算出向量表的大小
AREA
|.text|, CODE, READONLY
//定義一個代碼段,可讀,段名字是.text 段名若以數字開頭,則該段名需用"|"括起來,如|1_test|。
;定義只讀數據段,實際上是在CODE區,如果在FLASH區起動,則 中斷向量起始地址為0X8000000
;;CODE屬性:用于定義代碼段,默認為READONLY
; Reset handler
Reset_Handler
是一個標號,相當于一個函數名,
標記一個函數的開始;利用PROC、ENDP這一對偽指令把程序段分為若干個過程,使程序的結構加清晰
Reset_Handler PROC
EXPORT
Reset_Handler
[WEAK]
IMPORT
__main偽指令用于通知編譯器要使用的標號在其他的源文件中定義
IMPORT
SystemInit
LDR
R0, =SystemInit
BLX
R0
LDR
R0, =__main
BX
R0
ENDP
; Dummy Exception Handlers (infinite loops which can be
modified)
上面這句英語的意思是空的中斷處理函數,他們是無線循環,這些空的中斷處理函數和在it.c里面的中斷處理函數有什么區別呢????????????????????????
NMI_Handler PROC
EXPORT
NMI_Handler
[WEAK]
B
ENDP
HardFault_Handler\
PROC
EXPORT
HardFault_Handler
[WEAK]
B
ENDP
MemManage_Handler\
PROC
EXPORT
MemManage_Handler
[WEAK]
B
ENDP
BusFault_Handler\
PROC
EXPORT
BusFault_Handler
[WEAK]
B
ENDP
UsageFault_Handler\
PROC
EXPORT
UsageFault_Handler
[WEAK]
B
ENDP
SVC_Handler PROC
EXPORT
SVC_Handler
[WEAK]
B
ENDP
DebugMon_Handler\
PROC
EXPORT
DebugMon_Handler
[WEAK]
B
ENDP
PendSV_Handler PROC
EXPORT
PendSV_Handler
[WEAK]
B
ENDP
SysTick_Handler PROC
EXPORT
SysTick_Handler
[WEAK]
B
ENDP
Default_Handler PROC
EXPORT
WWDG_IRQHandler
[WEAK]
EXPORT
PVD_IRQHandler
[WEAK]
EXPORT
TAMPER_IRQHandler
[WEAK]
EXPORT
RTC_IRQHandler
[WEAK]
EXPORT
FLASH_IRQHandler
[WEAK]
EXPORT
RCC_IRQHandler
[WEAK]
EXPORT
EXTI0_IRQHandler
[WEAK]
EXPORT
EXTI1_IRQHandler
[WEAK]
EXPORT
EXTI2_IRQHandler
[WEAK]
EXPORT
EXTI3_IRQHandler
[WEAK]
EXPORT
EXTI4_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
ADC1_2_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
USB_LP_CAN1_RX0_IRQHandler [WEAK]
EXPORT
CAN1_RX1_IRQHandler
[WEAK]
EXPORT
CAN1_SCE_IRQHandler
[WEAK]
EXPORT
EXTI9_5_IRQHandler
[WEAK]
EXPORT
TIM1_BRK_IRQHandler
[WEAK]
EXPORT
TIM1_UP_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM1_CC_IRQHandler
[WEAK]
EXPORT
TIM2_IRQHandler
[WEAK]
EXPORT
TIM3_IRQHandler
[WEAK]
EXPORT
TIM4_IRQHandler
[WEAK]
EXPORT
I2C1_EV_IRQHandler
[WEAK]
EXPORT
I2C1_ER_IRQHandler
[WEAK]
EXPORT
I2C2_EV_IRQHandler
[WEAK]
EXPORT
I2C2_ER_IRQHandler
[WEAK]
EXPORT
SPI1_IRQHandler
[WEAK]
EXPORT
SPI2_IRQHandler
[WEAK]
EXPORT
USART1_IRQHandler
[WEAK]
EXPORT
USART2_IRQHandler
[WEAK]
EXPORT
USART3_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
RTCAlarm_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM8_BRK_IRQHandler
[WEAK]
EXPORT
TIM8_UP_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
TIM8_CC_IRQHandler
[WEAK]
EXPORT
ADC3_IRQHandler
[WEAK]
EXPORT
FSMC_IRQHandler
[WEAK]
EXPORT
SDIO_IRQHandler
[WEAK]
EXPORT
TIM5_IRQHandler
[WEAK]
EXPORT
SPI3_IRQHandler
[WEAK]
EXPORT
UART4_IRQHandler
[WEAK]
EXPORT
UART5_IRQHandler
[WEAK]
EXPORT
TIM6_IRQHandler
[WEAK]
EXPORT
TIM7_IRQHandler
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
[WEAK]
EXPORT
DMA2_Channel4_5_IRQHandler [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
TAMPER_IRQHandler
RTC_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC1_2_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_BRK_IRQHandler
TIM1_UP_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
RTCAlarm_IRQHandler
TIM8_BRK_IRQHandler
TIM8_UP_IRQHandler
TIM8_CC_IRQHandler
ADC3_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_IRQHandler
TIM7_IRQHandler
B
ENDP
ALIGN
; User Stack and Heap initialization
IF
:DEF:__MICROLIB 判斷是否使用DEF:__MICROLIB(micro lib)
EXPORT
__initial_sp
EXPORT
__heap_base
EXPORT
__heap_limit
ELSE
IMPORT
__use_two_region_memory 定義全局標號__use_two_region_memory
EXPORT
__user_initial_stackheap聲明全局標號__user_initial_stackheap,這樣外程序也可調用此標號
LDR
R0, =
Heap_Mem
LDR
R1, =(Stack_Mem +
Stack_Size)
LDR
R2, = (Heap_Mem +
Heap_Size)
LDR
R3, = Stack_Mem
BX
LR
ALIGN
ENDIF
END
;******************* (C) COPYRIGHT 2011 STMicroelectronics
*****END OF FILE***** |
