- #include <stdio.h>
- #include <stdlib.h>
- #include "stdarg.h"
- void PrintInt(unsigned int Num);//輸出正整數
- void PrintString(char *str);//輸出字符串
- void PrintInt_2(int Num);//輸出整數
- void PrintBit(int Bit);//輸出二進制數
- void PrintFloat(float Num);//輸出浮點數
- void PrintFamt(const char *Format,...);//自己寫的printf
- int main()
- int x=12;
- float y=12.5;
- char *p="123";
- PrintFamt("x=%d\ty=%f\t*p=%s\n",x,y,p);
- return 0;
- char bit;
- for(bit=31;bit>=0;bit--)
- if(Bit&(1<<31))
- PrintChar('1');
- else
- PrintChar('0');
- Bit<<=1;
- PrintChar(' ');
- void PrintChar(char ch)
- fprintf(stdout,"%c",ch);
- while(*str)
- PrintChar(*str++);
- int Ex(char num)
- int Temp=1;
- while(num--)
- Temp*=10;
- return Temp;
- unsigned char bit;
- unsigned char number;
- unsigned int Temp=Num;
- unsigned char Length=0;
- if(Num==0)
- PrintChar('0');
- return;
- while(Temp)
- Length++;
- Temp/=10;
- Temp=Num;
- for(bit=0;bit<Length;bit++)
- number=Temp/Ex(Length-bit-1);
- PrintChar(number+'0');
- Temp%=Ex(Length-bit-1);
- if(Num&(1<<31))
- PrintChar('-');
- // Num=Num&(1<<31);
- PrintInt(~(Num-1));
- else
- PrintInt(Num);
- int Temp=(int)Num;
- int fTemp=Ex(6)*(Num-(int)Num);
- PrintInt_2(Temp);
- PrintChar('.');
- if(fTemp&(1<<31))
- PrintInt_2(~(fTemp-1));
- else
- PrintInt_2(fTemp);
- va_list ap;
- va_start(ap,Format);
- while(*Format)
- switch(*Format)
- case '%':{
- switch(*(Format+1))
- case 'd':PrintInt_2(va_arg(ap,int));Format++;break;
- case 'f':PrintFloat(va_arg(ap,double));Format++;break;
- case 's':PrintString(va_arg(ap,char*));Format++;break;
- default:PrintChar('%');break;
- };break;
- case '\n':PrintChar('\n');break;
- case '\t':PrintChar('\t');break;
- default :PrintChar(*Format);
- Format++;
- va_end(ap);
