各位大哥,T0為按鍵,在51hei-5實驗板上,按鍵達到10以上后,十位沒有顯示,但有隱約的1顯示,不知程序是否出現了問題,請大哥們幫忙看下,程序如下:
#include<reg52.h> #define uchar unsigned char #define uint unsigned int sbit dula=P2^6; sbit wela=P2^7; sbit s1=P3^4; uchar code table[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; uchar num,bai,shi,ge; void init(); void display(uchar bai,uchar shi,uchar ge); void delay(uint z) { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--);
} void main() { init(); while(1) { if(s1==0) { delay(2); if(s1==0) { num++; if(num==100) num=0; bai=num/100; shi=num%100/10; ge=num%10; while(!s1); delay(2); while(!s1);
} display(bai,shi,ge);
} void init() { num=0; bai=0; shi=0; ge=0; dula=1; P0=0; dula=0;
wela=0; } void display(uchar bai,uchar shi,uchar ge) { bai=num/100; shi=num%100/10; ge=num%10;
dula=1; P0=table[bai]; dula=0; P0=0xff;
wela=1; P0=0xfb; wela=0; delay(1);
dula=1; P0=table[shi]; dula=0; P0=0xff; wela=1; P0=0xfd; wela=0; delay(1);
dula=1; P0=table[ge]; dula=0; P0=0xff; wela=1; P0=0xfe; wela=0; delay(1);
