查看: 3666|回復: 0
iOS開發之使用UIimage+ImageEffects實現圖片模糊效果
ID:85764 發表于 2015-7-18 00:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
效果圖
代碼
//  ViewController.m
//  UImage+ImageEffects-Demo
//  Created by 寒竹子 on 15/6/14.
//  Copyright (c) 2015年 寒竹子. All rights reserved.
#import "ViewController.h"
#import "GCD.h"
#import "UIImage+ImageEffects.h"
@interface ViewController ()
@property (nonatomic, strong) UIImageView * imageView;
@property (nonatomic)         UIViewContentMode contentMode; // 圖片顯示的模式
@end
@implementation ViewController
- (instancetype)init
    if (self = [super init]) {
        // Initial code
    return self;
@synthesize contentMode = _contentMode;
#pragma mark - getter and setter
- (void)setContentMode:(UIViewContentMode)contentMode
    _contentMode = contentMode;
    self.imageView.contentMode = contentMode;
- (UIViewContentMode)contentMode
    return _contentMode;
- (void)viewDidLoad {
    [super viewDidLoad];
    self.view.backgroundColor = [UIColor whiteColor];
    self.imageView          = [[UIImageView alloc] initWithFrame:CGRectMake(0, 0, self.view.frame.size.width, self.view.frame.size.height)];
    self.imageView.alpha    = .0f;
    self.imageView.center   = self.view.center;
    self.contentMode        = UIViewContentModeScaleAspectFill;
    [self.view addSubview:self.imageView];
    // 異步下載圖片
    [GCDQueue executeInGlobalQueue:^{
        NSString * imageURL       = @"/uploadfile/2014/1229/20141229033638152.jpg";
        NSURLRequest * urlRequest = [NSURLRequest requestWithURL:[NSURL URLWithString:imageURL]];
        // 下載圖片
        NSData * imageData        = [NSURLConnection sendSynchronousRequest:urlRequest returningResponse:nil error:nil];
        UIImage * image           = [UIImage imageWithData:imageData];
        // 模糊圖片  并設置模糊程度
        UIImage * blurImage       = [image blurImageWithRadius:10.0f];
        // 主線程 更新UI
        [GCDQueue executeInMainQueue:^{
            self.imageView.image     = blurImage;
            [UIView animateWithDuration:1.0f animations:^{
                self.imageView.alpha = 1.0f;
            } completion:nil];
@end
