參加了美新杯MEMS應(yīng)用大賽,之前剛學(xué)過STM32,就用它來練習(xí)練習(xí)。我用的是2.0的固件庫
1.模擬IIC文件
iic_driver.h文件
宏定義模擬IIC要用到的管腳和說明模擬IIC函數(shù)
PB0模擬IIC SCL管腳,PB1模擬IIC SDA管腳
#ifndef __I2C_Driver_H
#define __I2C_Driver_H
#include "stm32f10x_lib.h"
#defineSCL_H GPIOB->BSRR =GPIO_Pin_0 //模擬IIC時鐘線置高
#defineSCL_L GPIOB->BRR = GPIO_Pin_0 //模擬IIC時鐘線置低
#defineSDA_H GPIOB->BSRR = GPIO_Pin_1 //模擬IIC數(shù)據(jù)線置高
#defineSDA_L GPIOB->BRR =GPIO_Pin_1 //模擬IIC數(shù)據(jù)線置低
#defineSCL_read GPIOB->IDR &GPIO_Pin_0 //讀到模擬IIC時鐘線上電平
#defineSDA_read GPIOB->IDR &GPIO_Pin_1 //讀到模擬IIC時數(shù)據(jù)上電平
void I2C_GPIO_Config(void); //模擬IIC的端口配置
bool iic_write(void); //IIC寫命令函數(shù)
void iic_read(void); //IIC讀數(shù)據(jù)函數(shù)
voidgetdata(void); //提取加速度值函數(shù)
void I2C_delay(void); //模擬IIC時的延時函數(shù)
void Delay_nms(u16 n);
#endif
iic_driver.c文件
模擬IIC時序文件
#include "iic_driver.h"
u8 table[4],datax,datay;
u16 datamx,datamy;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_OD;
GPIO_Init(GPIOB,&GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
u8 i=5;//這里可以優(yōu)化速度 ,經(jīng)測試最低到5還能寫入
while(i)
i--;
bool I2C_Start(void)
SDA_H;
SCL_H;
I2C_delay();
if(!SDA_read)returnFALSE; //SDA線為低電平則總線忙,退出
SDA_L;
I2C_delay();
if(SDA_read) returnFALSE; //SDA線為高電平則總線出錯,退出
SDA_L;
I2C_delay();
return TRUE;
void I2C_Stop(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SDA_H;
I2C_delay();
void I2C_Ack(void)
SCL_L;
I2C_delay();
SDA_L;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
void I2C_NoAck(void)
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
I2C_delay();
bool I2C_WaitAck(void) //返回為:=1有ACK,=0無ACK
SCL_L;
I2C_delay();
SDA_H;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
SCL_L;
return FALSE;
SCL_L;
return TRUE;
void I2C_SendByte(u8 SendByte) //數(shù)據(jù)從高位到低位//
u8i=8;
while(i--)
SCL_L;
I2C_delay();
if(SendByte&0x80)
SDA_H;
SDA_L;
SendByte<<=1;
I2C_delay();
SCL_H;
I2C_delay();
SCL_L;
u8 I2C_RadeByte(void) //數(shù)據(jù)從高位到低位//
u8i=8;
u8ReceiveByte=0;
SDA_H;
while(i--)
ReceiveByte<<=1;
SCL_L;
I2C_delay();
SCL_H;
I2C_delay();
if(SDA_read)
ReceiveByte|=0x01;
SCL_L;
returnReceiveByte;
I2C_Start();//開始
I2C_SendByte(0x20);//寫入從寫設(shè)備MXC62022地址
if(I2C_WaitAck()) I2C_SendByte(0x00);//寫入從設(shè)備寄叢器首地址
if(I2C_WaitAck()) I2C_SendByte(0x00);//將從設(shè)備從低功耗模式喚醒
if(I2C_WaitAck()) I2C_Stop();//停止
Delay_nms(80);
I2C_Start();//開始
I2C_SendByte(0x20);//寫入寫從設(shè)備MXC62022地址
if(I2C_WaitAck()) I2C_SendByte(0x01);//寫入讀設(shè)備寄叢器首地址
I2C_Start();//開始
I2C_SendByte(0x21);//寫入讀從設(shè)備MXC62022地址
if(I2C_WaitAck()==0);returnTRUE;
void iic_read(void)
table[0]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[1]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[2]=I2C_RadeByte();I2C_delay();I2C_Ack();//X高八位
table[3]=I2C_RadeByte();I2C_delay();I2C_NoAck();//X高八位
I2C_Stop();//停止
void getdata(void)
datamx=(table[0]<<8)+table[1];
datamx&=0x0fff;
datax=datamx>>4;
datamy=(table[2]<<8)+table[3];
datamy&=0x0fff;
datay=datamy>>4;
2,數(shù)碼管顯示文件
led.h文件
用8個數(shù)碼管顯示讀到的加速度X,Y軸值
段選和位選由同一個引腳輸出,通過鎖存器協(xié)調(diào)顯示
#ifndef __LED_H
#define __LED_H
段選和位選鎖存器鎖存管腳定義
#define D_LE0 GPIO_ResetBits(GPIOA,GPIO_Pin_6); //數(shù)碼管段控制位為0
#define D_LE1 GPIO_SetBits(GPIOA,GPIO_Pin_6); //數(shù)碼管段控制位為1
#define W_LE0 GPIO_ResetBits(GPIOA,GPIO_Pin_7); //數(shù)碼管位控制位為0
#define W_LE1 GPIO_SetBits(GPIOA,GPIO_Pin_7); //數(shù)碼管位控制位為1
void Delay_nus(u16 m); //延時函數(shù)
void INIT_LedGpio(void);
void LED(void); //LED閃爍
void display(u8 datax,u8 datay); //數(shù)碼管顯示加速度計(jì)數(shù)據(jù)
#endif
led.c文件
#include"led.h"
extern u8 datax,datay;
u8tabledate[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰數(shù)碼管數(shù)據(jù)碼值0..9
u8tablecs[10]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//數(shù)碼管段選
u8 datas[8];//個、十、百、千位值
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOF,ENABLE);//打開用到的gpioF時鐘
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6;//選擇要配置的端口
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;//配置為推免輸出
GPIO_InitStructure.GPIO_Speed =GPIO_Speed_50MHz;//轉(zhuǎn)換速度
GPIO_Init(GPIOF,&GPIO_InitStructure);//初始化gpio
GPIO_ResetBits(GPIOF,GPIO_Pin_6); //先復(fù)位
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_All;//選擇要配置的端口
GPIO_Init(GPIOC,&GPIO_InitStructure);//初始化gpio
GPIO_ResetBits(GPIOC,GPIO_Pin_All); //先復(fù)位
鎖存器595控制端口配置
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//打開用到的gpioA時鐘
GPIO_InitStructure.GPIO_Pin =GPIO_Pin_6|GPIO_Pin_7;//選擇要配置的端口
GPIO_Init(GPIOA,&GPIO_InitStructure);//初始化gpio
GPIO_ResetBits(GPIOA,GPIO_Pin_6|GPIO_Pin_7); //先復(fù)位
void LED(void)
if(datax<135)
GPIO_ResetBits(GPIOF, GPIO_Pin_6 );//點(diǎn)亮led
//Delay_nms(60);
GPIO_SetBits(GPIOF, GPIO_Pin_6);//熄滅led
//Delay_nms(60);
void display(u8 x,u8 y)
u8 i;
datas[0]=datax/1000;
datas[1]=datax%1000/100;
datas[2]=datax%100/10;
datas[3]=datax%1000;
datas[4]=datay/1000;
datas[5]=datay%1000/100;
datas[6]=datay%100/10;
datas[7]=datay%1000;
for(i=0;i<8;i++)
D_LE1; //控制數(shù)碼管段數(shù)據(jù)的74HC573的LE管腳置高
W_LE1; //控制數(shù)碼管位的74HC573的LE管腳置高
GPIOC->ODR=tablecs[ i]; //設(shè)置要顯示的位,也就是哪一個數(shù)碼管亮
W_LE0; //鎖存位數(shù)據(jù),下面送上段數(shù)據(jù)以后,就顯示出來了
GPIOC->ODR=tabledate[datas[ i]]; //送要顯示的數(shù)據(jù),就是段數(shù)據(jù),如顯示0送的是0x3f
D_LE0; //鎖存段數(shù)據(jù),數(shù)碼管亮一個時間片刻
Delay_nus(150); //顯示一個時間片刻,會影響亮度和閃爍性
Delay_nms(100);
u16 i,j;
for(i=0; i< m; i++)
for(j=0;j< 72; j++);
void Delay_nms(u16n)
u16 i;
for(i=0; i< n; i++)
Delay_nus(1000);
3,主函數(shù)
main.h文件
#include"iic_driver.h"
#include"led.h"
void RCC_Configuration(void);
void NVIC_Configuration(void);//中斷和向量表
#endif
main.c文件
#include "main.h"
ErrorStatus HSEStartUpStatus;
int main(void)
//GPIO_InitTypeDef GPIO_InitStructure;
RCC_Configuration(); //配置時鐘
NVIC_Configuration();
I2C_GPIO_Config();
INIT_LedGpio();
while (1)
if(iic_write());
iic_read();
getdata();
display(datax,datay);
LED();
RCC_DeInit();//復(fù)位rcc寄存器
RCC_HSEConfig(RCC_HSE_ON);//使能外部晶振
HSEStartUpStatus =RCC_WaitForHSEStartUp();//等待外部晶振ok
if(HSEStartUpStatus == SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
FLASH_SetLatency(FLASH_Latency_2);//設(shè)定flash等待周期
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
RCC_PLLCmd(ENABLE);//使能倍頻模塊
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC,ENABLE);//打開用到的gpioc時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//打開用到的gpioc時鐘
#ifdef VECT_TAB_RAM
NVIC_SetVectorTable(NVIC_VectTab_RAM,0x0);
#else
NVIC_SetVectorTable(NVIC_VectTab_FLASH,0x0);
#endif
