6位共陰數(shù)碼管,可作時(shí)鐘也可作秒表(估計(jì)沒(méi)人用這么多位的秒表喲)
時(shí)、分和秒可分別調(diào)整,有開(kāi)始、暫停和清零鍵。
程序清單: ;12M晶振 2010 01 14 調(diào)試完成 03 15 修改 2011 03 03 注釋 STRT EQU P2.6
STP EQU P2.7
CLRR EQU P3.0
SEC EQU P3.5
MIN EQU P3.6
HOUR EQU P3.7 ORG 00H
SJMP MAIN
ORG 0BH
AJMP T0INT0
ORG 30H MAIN: MOV SP,#60H
MOV R4,#20
MOV TMOD,#01H
MOV TH0,#03CH ;#9EH 12M晶振時(shí)定時(shí)初值取#3CB0H,還可細(xì)調(diào),如 TL=#0B7H,可以更準(zhǔn)
MOV TL0,#0B0H ;#58H
SETB ET0
SETB EA
;MOV 28H,#12 kS: LCALL DISP ;秒調(diào)整按鍵
JB SEC,KM
LCALL DISP
JNB SEC,$-3
AJMP SINC kM: JB MIN,KH ;分調(diào)整按鍵
LCALL DISP
JNB MIN,$-3
AJMP MINC KH: JB HOUR,K1 ;時(shí)調(diào)整按鍵
LCALL DISP
JNB HOUR,$-3
AJMP HINC SINC: INC 26H ;秒調(diào)整
MOV A,26H
CJNE A,#60,SINC0
MOV 26H,#0
SINC0: AJMP KS MINC: INC 27H ;分調(diào)整
MOV A,27H
CJNE A,#60,MINC0
MOV 27H,#0
MINC0: AJMP KM HINC: INC 28H ;時(shí)調(diào)整
MOV A,28H
CJNE A,#24,HINC0
MOV 28H,#0
HINC0: AJMP KH
k1: LCALL DISP ;開(kāi)始鍵
JB STRT,K2
LCALL DISP
JNB STRT,$-3
AJMP START k2: JB STP,K3 ;暫停鍵
LCALL DISP
JNB STP,STOP
K3: JB CLRR,KS
LCALL DISP
JNB CLRR,CLEAR ;清零鍵
AJMP KS START: SETB TR0 ;開(kāi)始
AJMP K1
STOP: CLR TR0 ;暫停
AJMP K2 CLEAR: CLR TR0 ;清零
MOV A,#0
MOV 26H,A
MOV 27H,A
MOV 28H,A
AJMP KS DISP:
MOV A,26H
MOV B,#10
DIV AB
MOV 20H,B ;余數(shù)(秒個(gè)位數(shù))
MOV 21H,A ;商(秒十位數(shù))
MOV A,27H
MOV B,#10
DIV AB
MOV 22H,B ;余數(shù)(分個(gè)位數(shù))
MOV 23H,A ;商(分十位數(shù))
MOV A,28H
MOV B,#10
DIV AB
MOV 24H,B ;余數(shù)(時(shí)個(gè)位數(shù))
MOV 25H,A ;商(時(shí)十位數(shù))
MOV A,20H ;秒個(gè)位
ACALL SEG7
MOV P0,A
CLR P2.0
ACALL DLY
SETB P2.0
MOV A,21H ;秒十位
ACALL SEG7
MOV P0,A
CLR P2.1
ACALL DLY
SETB P2.1
MOV A,22H ;分個(gè)位
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.2
ACALL DLY
SETB P2.2
MOV A,23H ;分十位
ACALL SEG7
MOV P0,A
CLR P2.3
ACALL DLY
SETB P2.3
MOV A,24H ;時(shí)個(gè)位
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.4
ACALL DLY
SETB P2.4
MOV A,25H ;時(shí)十位
ACALL SEG7
MOV P0,A
CLR P2.5
ACALL DLY
SETB P2.5
RET
T0INT0: MOV TH0,#03CH;#9EH ;定時(shí)中斷子程序。重裝定時(shí)常數(shù)
MOV TL0,#0B0H;#58H
DJNZ R4,T0INTR ;50msX20=1S,未滿20次,跳出中斷子程序
MOV R4,#20
INC 26H ;1S,秒存儲(chǔ)單元內(nèi)數(shù)+1
MOV A,26H
CJNE A,#60,T0INTR ;未滿60S,跳出中斷。
MOV 26H,#0 ;滿60S,秒單元清零
INC 27H ;分+1
MOV A,27H
CJNE A,#60,T0INTR
MOV 27H,#0
INC 28H
MOV A,28H
CJNE A,#24,T0INTR
MOV 28H,#0
T0INTR: RETI
DLY10: MOV R3,#30
D0: ACALL DLY
DJNZ R3,D0
RET
DLY: MOV R7,#2
D1: MOV R6,#40
DJNZ R6,$
DJNZ R7,D1
RET SEG7: INC A
MOVC A,@A+PC
RET DB 03FH ;0 共陰
DB 006H ;1
DB 05BH ;2
DB 04FH ;3
DB 066H ;4
DB 06DH ;5
DB 07DH ;6
DB 007H ;7
DB 07FH ;8
DB 06FH ;9 END
;2011 11 25 更新。加上鬧鈴 ,按鍵功能稍作改動(dòng) E:\DPJ\CLOCK\CLOCK-MX\CLOCKADJCC-MX.ASM STRT EQU P2.6
STP EQU P2.7
CLRR EQU P3.0
SEC EQU P3.5
MIN EQU P3.6
AJMP MAIN
ORG 0BH
AJMP T0INT
ORG 1BH
AJMP T1INT
ORG 30H MAIN:
MOV SP,#60H
MOV R4,#20
MOV TMOD,#11H
MOV TH0,#03CH;#9EH 12M晶振時(shí)定時(shí)初值取#3CB0H,還可細(xì)調(diào)如 TL=#0B7H,可以更準(zhǔn)
MOV TL0,#0B0H;#58H
MOV TH1,#0FEH
MOV TL1,#0CH
SETB EA
SETB ET0
SETB ET1 kS:
ACALL DISP
ACALL ALARM JB SEC,KM ;秒調(diào)整按鍵
ACALL DISP
JNB SEC,$-2
AJMP SINC kM:
ACALL DISP
JNB MIN,$-2
AJMP MINC KH:
ACALL DISP
JNB HOUR,$-2
AJMP HINC SINC:
JB 7FH,SINC_A
INC 26H ;秒調(diào)整
MOV A,26H
CJNE A,#60,SINC0
MOV 26H,#0
AJMP SINC0
SINC_A:
INC 36H ;鬧秒調(diào)整
MOV A,36H
CJNE A,#60,SINC0
MOV 36H,#0
JB 7FH,MINC_A
INC 27H ;分調(diào)整
MOV A,27H
CJNE A,#60,MINC0
MOV 27H,#0
MINC_A:
INC 37H ;鬧分調(diào)整
MOV A,37H
CJNE A,#60,MINC0
MOV 37H,#0
MINC0:
AJMP KM HINC:
JB 7FH,HINC_A
MOV A,28H
CJNE A,#24,HINC0
MOV 28H,#0
HINC_A:
INC 38H ;鬧時(shí)調(diào)整
MOV A,38H
CJNE A,#24,HINC0
MOV 38H,#0
HINC0:
AJMP KH
k1:
ACALL DISP ;開(kāi)始鍵
JB STRT,K2
ACALL DISP
JNB STRT,$-2
AJMP START k2:
JB STP,K3 ;暫停鍵
ACALL DISP
JNB STP,$-2
AJMP CL_AL
K3:
JB CLRR,KS0
ACALL DISP
JNB CLRR,CLEAR ;清零鍵
KS0:
AJMP KS START:
CPL TR0 ;開(kāi)始/暫停
CPL 7DH ;7DH為開(kāi)始鍵按下標(biāo)志,此作為允許鬧鈴標(biāo)志
AJMP K1
CL_AL:
CPL 7FH ;7FH作時(shí)鐘和鬧鈴標(biāo)志位?
AJMP K2 CLEAR:
CLR TR0 ;清零
MOV A,#0
MOV 26H,A
MOV 27H,A
MOV 28H,A
MOV 36H,A
MOV 37H,A
MOV 38H,A
AJMP KS DISP:
JB 7FH,DISP_A
MOV 29H,26H ;秒送秒顯示緩存
MOV 2AH,27H
MOV 2BH,28H
AJMP DISP1
DISP_A:
MOV 29H,36H
MOV 2AH,37H
MOV 2BH,38H
DISP1:
MOV A,29H
MOV B,#10
DIV AB
MOV A,2AH
MOV B,#10
DIV AB
MOV A,2BH
MOV B,#10
DIV AB
MOV A,20H ;秒個(gè)位
ACALL SEG7
MOV P0,A
CLR P2.0
ACALL DLY
SETB P2.0
MOV A,21H ;秒十位
ACALL SEG7
MOV P0,A
CLR P2.1
ACALL DLY
SETB P2.1
MOV A,22H ;分個(gè)位
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.2
ACALL DLY
SETB P2.2
MOV A,23H ;分十位
ACALL SEG7
MOV P0,A
CLR P2.3
ACALL DLY
SETB P2.3
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.4
ACALL DLY
SETB P2.4
MOV A,25H ;時(shí)十位
ACALL SEG7
MOV P0,A
CLR P2.5
ACALL DLY
SETB P2.5
RET
ALARM:
JNB 7DH,ALRT
MOV A,28H ;比較小時(shí)
CJNE A,38H,RT ;不等返回。 相等,轉(zhuǎn)分鐘比較
MOV A,27H ;比較分鐘
CJNE A,37H,RT
MOV A,26H ;比較秒
CJNE A,36H,RT
SETB TR1
MOV R0,#0 ;鬧鈴時(shí)間到,鬧鈴計(jì)時(shí)清零
ALRT:
RET RT:
RET T0INT: MOV TH0,#03CH;#9EH ;定時(shí)中斷子程序。重裝定時(shí)常數(shù)
MOV TL0,#0B0H #58H
MOV R4,#20
INC R0 ;響鈴時(shí)間
MOV A,26H
INC 27H ;分+1
MOV A,27H
CJNE A,#60,T0INTR
MOV 27H,#0
INC 28H
MOV A,28H
CJNE A,#24,T0INTR
MOV 28H,#0
T0INTR:
RETI T1INT:
MOV TH1,#0FEH
MOV TL1,#0CH
CPL P1.0
CJNE R0,#5,T1RTI ;鬧鈴時(shí)間設(shè)為5秒
CLR TR1 ;關(guān)鬧鈴
T1RTI:
RETI DLY:
MOV R7,#20
MOV R6,#25
DJNZ R6,$
DJNZ R7,$-4
RET
SEG7:
INC A
MOVC A,@A+PC
RET
DB 03FH ;0 共陰
DB 006H ;1
DB 05BH ;2
DB 04FH ;3
DB 066H ;4
DB 06DH ;5
DB 07DH ;6
DB 007H ;7
DB 07FH ;8
DB 06FH ;9 END
;12M晶振 2010 01 14 調(diào)試完成 3.15 修改 2011 03 03 注釋
;2011 11 25 加上鬧鈴 E:\DPJ\CLOCK\CLOCK-MX\CLOCKADJCC-MX.ASM
;2011 12 03 加上整點(diǎn)提醒,響1S 鬧鈴響3 S E:\DPJ\CLOCK\CLOCK-定時(shí)整點(diǎn)\CLOCKADJCC-ZDNL.ASM
STRT EQU P2.6
STP EQU P2.7
CLRR EQU P3.0
SEC EQU P3.5
MIN EQU P3.6
HOUR EQU P3.7
ORG 00H
AJMP MAIN
ORG 0BH
AJMP T0INT
ORG 1BH
AJMP T1INT
ORG 30H MAIN:
MOV SP,#60H
MOV R4,#20
MOV TMOD,#11H
MOV TL0,#0B0H;#58H
MOV TH1,#0FEH
MOV TL1,#0CH
SETB EA
SETB ET0
SETB ET1 kS:
ACALL DISP
ACALL DISP
JNB SEC,$-2
AJMP SINC kM:
ACALL DISP
JNB MIN,$-2
AJMP MINC KH:
ACALL DISP
JNB HOUR,$-2
AJMP HINC SINC:
JB 7FH,SINC_A
INC 26H ;秒調(diào)整
MOV A,26H
CJNE A,#60,SINC0
MOV 26H,#0
AJMP SINC0
SINC_A:
INC 36H ;鬧秒調(diào)整
MOV A,36H
CJNE A,#60,SINC0
MOV 36H,#0
JB 7FH,MINC_A
INC 27H ;分調(diào)整
MOV A,27H
CJNE A,#60,MINC0
MOV 27H,#0
MINC_A:
INC 37H ;鬧分調(diào)整
MOV A,37H
CJNE A,#60,MINC0
MOV 37H,#0
MINC0:
AJMP KM HINC:
JB 7FH,HINC_A
MOV A,28H
CJNE A,#24,HINC0
MOV 28H,#0
HINC_A:
MOV A,38H
CJNE A,#24,HINC0
MOV 38H,#0
HINC0:
AJMP KH
k1:
JB STRT,K2
ACALL DISP
JNB STRT,$-2
AJMP START k2:
JB STP,K3 ;暫停鍵
ACALL DISP
JNB STP,$-2
AJMP CL_AL
K3:
JB CLRR,KS0
ACALL DISP
JNB CLRR,CLEAR ;清零鍵
KS0:
AJMP KS START:
CPL TR0 ;開(kāi)始/暫停
SETB 7DH ;7DH為開(kāi)始鍵按下標(biāo)志,此作為允許鬧鈴標(biāo)志
AJMP K1
CL_AL:
AJMP K2 CLEAR:
CLR TR0 ;清零
MOV A,#0
MOV 26H,A
MOV 27H,A
MOV 28H,A
MOV 36H,A
MOV 37H,A
MOV 38H,A
AJMP KS DISP:
JB 7FH,DISP_A
MOV 2AH,27H
MOV 2BH,28H
AJMP DISP1
DISP_A:
MOV 29H,36H
MOV 2AH,37H
MOV 2BH,38H
DISP1:
MOV A,29H
MOV B,#10
DIV AB
MOV A,2AH
MOV B,#10
DIV AB
MOV A,2BH
MOV B,#10
DIV AB
MOV A,20H ;秒個(gè)位
ACALL SEG7
MOV P0,A
CLR P2.0
ACALL DLY
SETB P2.0
MOV A,21H ;秒十位
ACALL SEG7
MOV P0,A
CLR P2.1
ACALL DLY
SETB P2.1
MOV A,22H ;分個(gè)位
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.2
ACALL DLY
SETB P2.2
MOV A,23H ;分十位
ACALL SEG7
MOV P0,A
CLR P2.3
ACALL DLY
SETB P2.3
ACALL SEG7
MOV P0,A
SETB P0.7
CLR P2.4
ACALL DLY
SETB P2.4
MOV A,25H ;時(shí)十位
ACALL SEG7
MOV P0,A
CLR P2.5
ACALL DLY
SETB P2.5
RET
ALARM:
JNB 7DH,RT ;開(kāi)始鍵未按下跳出
MOV A,28H ;開(kāi)機(jī)時(shí),時(shí)分秒都 為0,跳出
JZ AL0M
AJMP ALARM1
AL0M:
MOV A,27H
JZ AL0S
AJMP ALARM1
AL0S:
MOV A,26H
JZ RT
ALARM1:
CJNE A,38H,AL ;不等返回,相等,轉(zhuǎn)分鐘比較
MOV A,27H ;比較分鐘?
CJNE A,37H,AL
MOV A,26H ;比較秒
CJNE A,36H,AL
AJMP ALARM2 ;轉(zhuǎn)鬧鈴 AL: ;整點(diǎn)提醒
MOV A,28H
JZ RT ;小時(shí)不是00,判分是不是00
MOV A,27H
JNZ RT ;分不是00,跳出
MOV A,26H
JNZ RT
AJMP ALARM3 ;秒不為00,跳出。為00,整點(diǎn)提醒
ALARM2: ;鬧鈴3 S
SETB TR1
MOV R0,#0
AJMP RT
ALARM3: ;整點(diǎn)提醒1S
SETB TR1
MOV R0,#2
RT:
RET T0INT:
MOV TH0,#03CH;定時(shí)中斷子程序。重裝定時(shí)常數(shù)
MOV TL0,#0B0H
MOV R4,#20
INC R0 ;響鈴時(shí)間
MOV A,26H
INC 27H ;分+1
MOV A,27H
CJNE A,#60,T0INTR
MOV 27H,#0
INC 28H
MOV A,28H
CJNE A,#24,T0INTR
MOV 28H,#0
T0INTR:
RETI T1INT:
MOV TH1,#0FEH
MOV TL1,#0CH
CPL P1.0
CJNE R0,#3,T1RTI ;鬧鈴時(shí)間設(shè)為5秒
CLR TR1 ;關(guān)鬧鈴
T1RTI:
RETI DLY:
MOV R7,#20
MOV R6,#25
DJNZ R6,$
DJNZ R7,$-4
RET
SEG7:
INC A
MOVC A,@A+PC
RET
DB 03FH ;0 共陰
DB 006H ;1
DB 05BH ;2
DB 04FH ;3
DB 066H ;4
DB 06DH ;5
DB 07DH ;6
DB 007H ;7
DB 07FH ;8
DB 06FH ;9 END
