查看: 10161|回復(fù): 6
單片機(jī)控制lcd12232字幕顯示程序
ID:85192 發(fā)表于 2015-7-10 02:05 | 顯示全部樓層 |閱讀模式
12232在proteus 里模型用關(guān)鍵字P ,“12232” 查不出LCD的,要用1232 查找 。
//12232LCD proteus仿真
//2012 01 20   E:\DPJ_C\12232\12232UV4\12232_2C.C
#include<reg51.h>
#include<intrins.h>
#include"chr16.h"
#define LCD_DB P0
sbit E2=P3^5;
sbit E1=P3^6;
sbit A0=P3^7;
void WR_Mcom(uchar i)
E1=1;
_nop_();
_nop_();
A0=0;
_nop_();
_nop_();
LCD_DB=i;
_nop_();
_nop_();
E1=0;
_nop_();
_nop_();
void WR_Mdat(uchar i)
E1=1;
_nop_();
_nop_();
A0=1;
_nop_();
_nop_();
LCD_DB=i;
_nop_();
_nop_();
E1=0;
_nop_();
_nop_();
void WR_Scom(uchar i)
A0=0;
_nop_();
_nop_();
E2=1;
_nop_();
_nop_();
LCD_DB=i;
_nop_();
_nop_();
E2=0;
_nop_();
_nop_();
void WR_Sdat(uchar i)
A0=1;
_nop_();
_nop_();
E2=1;
_nop_();
_nop_();
LCD_DB=i;
_nop_();
_nop_();
E2=0;
_nop_();
_nop_();
void lcdini()
WR_Mcom(0XE2);
WR_Scom(0XE2);//
WR_Mcom(0XAE);
WR_Scom(0XAE);//POWER SAVE
WR_Mcom(0XA4);
WR_Scom(0XA4);//
WR_Scom(0XA9);//1/32 占空比
WR_Mcom(0XA1);
WR_Scom(0XA1);
WR_Mcom(0XEE);
WR_Scom(0XEE);//寫模式
WR_Mcom(0X00);
WR_Mcom(0XC0);
WR_Scom(0X00);
WR_Scom(0XC0);
WR_Mcom(0XAF);
WR_Scom(0XAF);
void SetPage(uchar page0,uchar page1)
WR_Mcom(0xB8|page1);
WR_Scom(0xB8|page0);
void SetAddress(uchar address0,uchar address1)
WR_Mcom(address1&0x7F);
WR_Scom(address0&0x7F);
void clrscr( )
uchar i;
uchar page;
for (page=0;page<4;page++)
  SetPage(page,page);
  SetAddress(0,0);
  for (i=0;i<61;i++)
    WR_Mdat(0);
    WR_Sdat(0);
void display()
uchar i,j,page;
for(page=0;page<4;page++)
  SetPage(page,page);
  SetAddress(0,0);
  for(i=0;i<4;i++)
   for(j=0;j<15;j++)
    if(page<2)
     WR_Mdat(chr16[2*i][j+page*15]);
     WR_Sdat(chr16[2*i+8][j+page*15]);
     WR_Mdat(chr16[2*i+16][j+(page-2)*15]);
     WR_Sdat(chr16[2*i+24][j+(page-2)*15]);
lcdini();
clrscr();
  display();
CHR16.H  //
unsigned char code chr16[32][15]={
{0x00,0x40,0x40,0xDA,0xFE,0x24,0x20,0xF8,0xDE,0xD6,0xD8,0xC8,0x48,0x00,0x00,},
{0x08,0x0C,0x07,0x3F,0x3F,0x03,0x0F,0x1F,0x17,0xD5,0xFF,0x3F,0x11,0x11,0x01,},/*"梅",0*/
{0x00,0x00,0x10,0x10,0x9C,0x9C,0x10,0x98,0x9E,0x0E,0x88,0x88,0x08,0x00,0x00,},
{0x10,0x18,0x0C,0x7F,0x7F,0x08,0x08,0x3F,0x7F,0x43,0x41,0x40,0x78,0x38,0x00,},/*"花",1*/
{0x00,0x00,0x20,0x20,0xE0,0xE0,0x60,0xFA,0xFE,0x24,0x60,0x60,0x20,0x00,0x00,},
{0x00,0x10,0x19,0x0F,0x07,0x24,0x38,0x1F,0x07,0x0C,0x38,0x30,0x20,0x20,0x00,},/*"歡",2*/
{0x00,0x00,0x00,0x08,0xA8,0xA8,0xFE,0x7E,0xEC,0xC4,0x44,0x00,0x00,0x00,0x00,},
{0x08,0x08,0x08,0x08,0x6A,0xEF,0xAD,0xBD,0xD7,0x77,0x34,0x04,0x04,0x04,0x00,},/*"喜",3*/
{0x00,0x40,0x40,0x18,0x98,0x84,0xFC,0xFC,0xEC,0xFE,0xDE,0xC4,0x40,0x00,0x00,},
{0x00,0x10,0x3C,0x3E,0x42,0x45,0x6D,0x3D,0x1F,0x3F,0x63,0x60,0x40,0x40,0x40},/*"漫",4*/
{0x00,0x00,0x80,0x88,0x88,0x88,0xF8,0x7C,0x44,0x44,0x40,0x40,0x00,0x00,0x00,},
{0x00,0x20,0x20,0x30,0x1C,0x0F,0x03,0x07,0x0E,0x18,0x30,0x30,0x20,0x20,0x00,},/*"天",5*/
{0x00,0x80,0xF0,0x70,0x64,0x64,0xFC,0xFC,0xD6,0xD2,0x10,0x30,0x30,0x00,0x00,},
{0x00,0x00,0x00,0x44,0x55,0x55,0x55,0x5F,0x6A,0x3E,0x1E,0x00,0x00,0x00,0x00,},/*"雪",6*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,},
{0x00,0x00,0x68,0x78,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*",",7*/
{0x00,0x00,0x10,0xB0,0xB0,0x00,0xE0,0xF8,0xDE,0xD6,0x10,0x10,0x00,0x00,0x00,},
{0x00,0x08,0x0C,0x0F,0x23,0x3B,0x1B,0x42,0x7F,0x7F,0x09,0x39,0x31,0x00,0x00,},/*"凍",8*/
{0x00,0x00,0x00,0xC8,0xE8,0xA8,0x88,0xFC,0xF4,0x84,0xC4,0x40,0x00,0x00,0x00,},
{0x00,0x20,0x31,0x1B,0x0E,0x07,0x01,0x1F,0x3F,0x31,0x20,0x30,0x3C,0x1C,0x00,},/*"死",9*/
{0x00,0x00,0x08,0x08,0x0E,0xCE,0xE8,0x68,0xCE,0x8E,0x0E,0x04,0x00,0x00,0x00,},
{0x08,0x08,0x0C,0x06,0x3F,0x7F,0x42,0x5E,0x5E,0x43,0x73,0x73,0x02,0x02,0x02,},/*"蒼",10*/
{0x00,0xC0,0xC0,0xFC,0xFC,0xE0,0xF8,0xB8,0xE8,0xF8,0xDC,0xCC,0x80,0x00,0x00,},
{0x00,0x10,0x19,0x0F,0x07,0x07,0x07,0x0F,0x1F,0x3F,0x27,0x27,0x30,0x30,0x00,},/*"蠅",11*/
{0x00,0x00,0x00,0x00,0x80,0x90,0xFE,0xFE,0x90,0xD0,0x40,0x00,0x00,0x00,0x00,},
{0x00,0x20,0x31,0x19,0x0D,0x07,0xFF,0xFF,0x06,0x0C,0x18,0x10,0x30,0x20,0x00,},/*"未",12*/
{0x00,0x00,0x00,0x80,0xB8,0x78,0xE8,0xEC,0x3C,0x3C,0x00,0x00,0x00,0x00,0x00,},
{0x20,0x30,0x1C,0x0F,0x07,0x04,0x0F,0x0F,0x19,0x31,0x30,0x20,0x20,0x20,0x20,},/*"足",13*/
{0x00,0x80,0x80,0x80,0xC8,0xE8,0xB8,0x9E,0xFE,0xEC,0xC4,0x40,0x40,0x40,0x00,},
{0x00,0x00,0x00,0x00,0x0E,0x0E,0x0E,0x06,0xC2,0xFF,0x3F,0x00,0x00,0x00,0x00,},/*"奇",14*/
{0x00,0x00,0x30,0x30,0x30,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,},/*"。",15*/
2012 01 24 更新  原來的程序雖然正常運(yùn)行,但總覺得數(shù)組部分有點(diǎn)問題。更改 display()子函數(shù)如下,總算可以了。
void display()
uchar i,j,page;
  SetPage(page,page);
  SetAddress(0,0);
  for(i=0;i<4;i++)
   for(j=0;j<15;j++)
    if(page<2)
     WR_Mdat(chr16[2*i+page][j]);
     WR_Sdat(chr16[2*i+8+page][j]);
     WR_Mdat(chr16[2*i+14+page][j]);
       WR_Sdat(chr16[2*i+22+page][j]);
ID:476313 發(fā)表于 2019-4-24 22:02 | 顯示全部樓層
mark下
ID:384274 發(fā)表于 2020-3-10 12:49 | 顯示全部樓層
顯示數(shù)字應(yīng)該怎么寫???
ID:584814 發(fā)表于 2020-3-10 15:34 | 顯示全部樓層
zzt223 發(fā)表于 2020-3-10 12:49
同上面程序一樣樣先寫出字模然后調(diào)用,或直接改那個(gè)字模就可以。
ID:384274 發(fā)表于 2020-3-10 18:12 | 顯示全部樓層
man1234567 發(fā)表于 2020-3-10 15:34
為什么我數(shù)字顯示的時(shí)候數(shù)字是反轉(zhuǎn)90度,很納悶
ID:384274 發(fā)表于 2020-3-10 18:13 | 顯示全部樓層
老哥有沒有好的方法
ID:892752 發(fā)表于 2021-3-16 19:30 | 顯示全部樓層
如何讓他們滾動顯示
