查看: 11243|回復: 38
用24C04與單片機設計電子密碼鎖 程序+Protues仿真 1602LCD顯示
ID:84768 發表于 2015-7-4 17:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
進來請看
單片機程序與仿真文件下載: 用24C04與1602LCD設計電子密碼鎖.zip (26.03 KB, 下載次數: 180)
以下是源程序預覽:
  1. //-----------------------------------------------------------------
  2. //原始程序中相鄰兩位密碼不能相同.
  3. //本壓縮包中的HEX由修改后的新程序編譯生成,允許輸入任意密碼.
  4. //-----------------------------------------------------------------
  5. //實訓100例中本例內的main函數可用以下代碼替換.
  6. //改動的主要是main函數中while循環內的代碼.
  7. //-----------------------------------------------------------------
  8. // 主程序
  9. //-----------------------------------------------------------------
  10. void main()
  11. {
  12.    uchar i = 0;
  13.    uchar IIC_Password[10];
  14.    uchar IS_Valid_User = 0;
  15.    P0 = 0xFF;
  16.    P1 = 0xFF;
  17.    P2 = 0xFF;
  18.    TMOD = 0x02;                     //T0設置為8位自動重裝模式
  19.    TH0 = 175;
  20.    TL0 = 175;
  21.    TR0 = 1;                         //啟動T0
  22.    DelayMS(10);
  23.    LCD_Init();                      //初始化LCD
  24.
  25.    IIC_24C04_Init();                //初始化24C04
  26.
  27.    Display_String(Title_Text,0x00); //在第1行顯示標題
  28.
  29.    //24C04的內容已由初始化BIN文件導入
  30.    //將24C04中預先寫入的密碼讀入pass
  31.    RecString(0xa0, 0 , IIC_Password, 6);
  32.    IIC_Password[6] = '\0';
  33.    while(1)
  34.    {
  35.       P1 = 0xF0;
  36.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //掃描鍵盤獲取鍵序號KeyNo
  37.       switch ( KeyNo )
  38.       {
  39.            case 0:  case 1: case 2: case 3: case 4:
  40.            case 5:  case 6: case 7: case 8: case 9:
  41.
  42.                    if ( i<= 5 )             //密碼限制在6位以內
  43.                    {
  44.                         //如果i為0則執行一次清屏
  45.                         if (i ==0) Display_String("                ",0x40);
  46.
  47.                         UserPassword[i] = KeyNo + '0';
  48.                         UserPassword[i+1] = '\0';
  49.
  50.                         DSY_BUFFER[i] = '*';
  51.                         DSY_BUFFER[i+1] = '\0';
  52.
  53.                         Display_String(DSY_BUFFER,0x40);
  54.
  55.                         i++;
  56.                     }
  57.                     break;
  58.
  59.            case 10: //按A鍵開鎖
  60.                     if (strcmp(UserPassword,IIC_Password) == 0)
  61.                     {
  62.                        LED_OPEN = 0;  //點亮LED
  63.                        Clear_Password();
  64.                        Display_String("Unlock OK!      ",0x40);
  65.                        IS_Valid_User = 1;
  66.                     }
  67.                     else
  68.                     {
  69.                        LED_OPEN =1;   //關閉LED
  70.                        Clear_Password();
  71.                        Display_String("ERROR !         ",0x40);
  72.                        IS_Valid_User = 0;
  73.                     }
  74.                     i = 0;
  75.                     break;
  76.
  77.            case 11: //按B鍵上鎖
  78.                     LED_OPEN =1;
  79.                     Clear_Password();
  80.                     Display_String(Title_Text,0x00);
  81.                     Display_String("                ",0x40);
  82.                     i = 0;
  83.                     IS_Valid_User = 0;
  84.                     break;
  85.
  86.            case 12: //按C鍵設置新密碼
  87.                     //如果是合法用戶則提示輸入新密碼
  88.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  89.                     else
  90.                     {
  91.                        i = 0;
  92.                        Display_String("New Password:   ",0x00);
  93.                        Display_String("                ",0x40);
  94.                      }
  95.
  96.                     break;
  97.
  98.            case 13: //按D鍵保存新密碼
  99.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  100.                     else
  101.                     {
  102.                        SendString(0xa0, 0 , UserPassword, 6);
  103.
  104.                        //重新讀入剛寫的密碼
  105.                        RecString(0xa0, 0 , IIC_Password, 6);
  106.                        IIC_Password[6] = '\0';
  107.
  108.                        i = 0;
  109.                        Display_String(Title_Text,0x00);
  110.                        Display_String("Password Saved! ",0x40);
  111.                      }
  112.
  113.                     break;
  114.
  115.            case 14: //按E鍵消除所有輸入
  116.                     i = 0;
  117.                     Clear_Password();
  118.                     Display_String("                ",0x40);
  119.        }
  120.        Beep();
  121.        DelayMS(100);
  122.        P1= 0xF0;
  123.        while (P1 != 0xF0);    //如果有鍵未釋放則等待
  124.        while (P1 == 0xF0);    //如果沒有再次按下按鍵則等待
  125.    }
  126. }
參與人數 2黑幣 +55 收起 理由
tieq1952 + 5 贊一個!
admin + 50 共享資料的積分獎勵!
收藏收藏2 分享淘帖 頂 踩
ID:84777 發表于 2015-7-4 21:27 | 只看該作者
厲害,,,51黑有你更精彩!!
ID:86064 發表于 2015-7-18 20:01 | 只看該作者
厲害,,,,太棒了
ID:86086 發表于 2015-7-18 22:01 | 只看該作者
看看思路希望能得到一些靈感,謝謝分享
ID:70839 發表于 2015-8-11 18:25 | 只看該作者
支持樓主,很不錯,學習參考下
ID:76840 發表于 2015-8-12 12:28 | 只看該作者
怎么修改的密碼是錯誤的,不能保存進去?
ID:84033 發表于 2015-8-27 22:18 | 只看該作者
電子密碼鎖在今后還是有更大 的發展空間的
ID:79615 發表于 2015-8-28 22:06 來自觸屏版 | 只看該作者
很好的東西!!!!
ID:89999 發表于 2015-9-13 11:51 | 只看該作者
感謝分享
ID:44267 發表于 2015-9-18 11:12 | 只看該作者
太強了
ID:83138 發表于 2015-9-18 21:32 | 只看該作者
51Hei(51黑)論壇有你更精彩
ID:73691 發表于 2015-9-25 07:23 | 只看該作者
真的很不錯
ID:44267 發表于 2015-9-25 08:09 | 只看該作者
強強強強強強強強強強強強強強強
ID:90789 發表于 2015-10-5 15:43 來自觸屏版 | 只看該作者
ludaijin 發表于 2015-9-18 11:12
太強了
求兩個按鍵輸入的電子密碼鎖
ID:91448 發表于 2015-10-7 00:32 來自觸屏版 | 只看該作者
太強啦,學習~
ID:97070 發表于 2015-11-25 18:11 | 只看該作者
值得來圍觀,請問有仿真和程序嗎?
ID:97070 發表于 2015-11-25 18:24 | 只看該作者
居然不公開程序,有點失望
ID:98132 發表于 2015-12-5 17:22 | 只看該作者
這個程序有源代碼嗎
ID:98832 發表于 2015-12-10 15:10 | 只看該作者
有源代碼嗎?急需啊
ID:98832 發表于 2015-12-10 18:54 | 只看該作者
有沒有源代碼啊
ID:99459 發表于 2015-12-12 18:55 | 只看該作者
有沒有不用24c04的?
ID:44267 發表于 2015-12-22 16:32 | 只看該作者
樓上有朋友做出來了嘛
ID:120850 發表于 2016-5-15 22:14 | 只看該作者
程序是不是有錯》?除了頭文件之外還缺點什么?
ID:157011 發表于 2016-12-23 16:17 | 只看該作者
有源代碼嗎?我編譯的時候出現了錯誤
ID:89286 發表于 2016-12-25 09:24 | 只看該作者
thanks for sharing
ID:183867 發表于 2017-3-27 16:44 | 只看該作者
尤源代碼嗎
ID:159521 發表于 2017-3-27 17:39 | 只看該作者
很不錯,正在學習
ID:244527 發表于 2017-10-31 13:23 | 只看該作者
樓主,不用總線怎么寫啊
ID:245820 發表于 2017-11-3 21:33 | 只看該作者
非常不錯
ID:144383 發表于 2017-12-6 17:30 來自觸屏版 | 只看該作者
不錯學習一下
ID:257027 發表于 2017-12-6 20:39 | 只看該作者
支持樓主,很不錯,學習參考下
ID:259267 發表于 2017-12-11 15:40 | 只看該作者
厲害,,,51黑有你更精彩!!
ID:253767 發表于 2017-12-11 17:42 | 只看該作者
好東西,學習了
ID:287564 發表于 2018-3-13 10:46 | 只看該作者
厲害,,,51黑有你更精彩!!
ID:110278 發表于 2018-3-13 20:55 | 只看該作者
非常好,學習了。
ID:294933 發表于 2018-3-21 22:53 | 只看該作者
實訓想做這個   謝謝大佬的分享  對于我這種小白很有用  拿走了  就是有點貴啊  這個  傷心
ID:236699 發表于 2018-3-22 08:09 | 只看該作者
感謝分享
ID:294933 發表于 2018-3-22 09:09 | 只看該作者
大佬這個編譯了為什么會有錯啊  解釋下唄   小白一個不知道什么意思
ID:294933 發表于 2018-3-22 10:04 | 只看該作者
看不懂啊 大佬指點下  說明意思  頭文件一直報錯
