查看: 9407|回復(fù): 11
16*16滾動(dòng)點(diǎn)陣屏+音樂盒C語言源程序
ID:83710 發(fā)表于 2015-6-25 21:56 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
   這個(gè)東西是09年剛學(xué)單片機(jī)時(shí)做的,基于51單片機(jī)。點(diǎn)陣屏用的是一個(gè)集成好的模塊,就是四個(gè)595兩兩級(jí)聯(lián)分別控制行和列,屏可能有點(diǎn)老,所以不是很亮。字摸直接用網(wǎng)上的字摸提取軟件就能提取。另外用定時(shí)計(jì)數(shù)器產(chǎn)生方波做了一個(gè)音樂播放器(用了一個(gè)運(yùn)放),放的是天空之城的音樂,同時(shí)用一個(gè)兩位數(shù)碼管顯示當(dāng)前的音樂音階(第一位數(shù)碼管表示高中低音)。感覺里面用了不少51的資源,挺好的程序,現(xiàn)在完全開源的給大家分享出來
作品圖片:
  1. #include<reg51.h>
  2. sbit RCK=P2^2;
  3. sbit SRCK_1=P2^3;
  4. sbit SRCK_2=P2^4;
  5. sbit SER_IN_1=P2^5;
  6. sbit SER_IN_2=P2^6;
  7. sbit DIG1=P2^0;
  8. sbit DIG2=P2^1;
  9. sbit buz=P2^7;
  10. unsigned char num=13;--字幕有多少個(gè)字
  11. unsigned int speed=85;--每狀態(tài)持續(xù)時(shí)間,數(shù)字越小,字幕速度越快
  12. unsigned int  song_num=136;--音節(jié)個(gè)數(shù)
  13. unsigned char code song[]=--中音前綴為1,低音為0,高音為2+后位為歌譜
  14. {
  15.   16,17,21,17,21,23,17,13,13,16,15,16,21,15,10,13,13,14,13,14,21,
  16.   10,13,01,21,21,21,17,14,14,17,17,10,16,17,21,17,21,23,17,10,13,13,16,15,16,21,
  17.   15,10,13,14,21,17,17,21,22,22,23,21,10,21,17,16,16,17,15,16,10,21,22,23,22,23,
  18.   25,22,10,15,15,21,17,21,23,23,10,10,16,17,21,17,22,22,21,15,15,10,24,23,22,21,
  19.   23,23,10,23,26,25,25,23,22,21,10,21,22,21,22,22,25,23,10,23,26,25,23,22,21,10,
  20.   21,22,21,22,22,17,16,10,16,17,16
  21. };
  22. unsigned char code song_speed[]=--節(jié)拍,數(shù)目越大聲音持續(xù)時(shí)間越長(zhǎng),與各曲譜位置對(duì)應(yīng)
  23. {
  24.   40,60,120,80,100,100,300,40,60,120,80,100,100,200,100,50,50,120,80,80,120,100,200,25,25,
  25.   25,25,120,80,105,95,200,100,50,50,120,80,100,100,200,100,50,50,120,80,100,100,300,50,50,
  26.   100,40,50,110,100,33,33,33,100,100,120,80,50,50,100,100,200,100,50,50,120,80,100,100,
  27.   200,100,50,50,110,90,100,100,200,100,100,45,55,100,100,50,50,110,80,110,100,100,100,100,100,
  28.   400,200,100,100,200,100,100,50,50,100,50,50,100,45,55,100,100,200,100,100,200,200,120,80,
  29.   200,50,50,100,60,40,50,100,200,100,50,50,400
  30. };
  31. unsigned char code hanzi[]=--字模提取BADC,右旋90度
  32. {
  33. 0x80,0x00,0x80,0x00,0x80,0x00,0x80,0x00,0xFF,0xFF,0x80,0x40,0x80,0x40,0xA0,0x23,--長(zhǎng)
  34. 0x90,0x04,0x88,0x08,0x84,0x10,0x86,0x20,0x80,0x60,0xC0,0x20,0x80,0x00,0x00,0x00,
  35. 0x20,0x04,0x22,0x04,0x2A,0x02,0x2A,0x01,0xAA,0xFF,0x6A,0x49,0x3A,0x49,0x2F,0x49,--春
  36. 0x2A,0x49,0x6A,0x49,0xAA,0xFF,0x2A,0x01,0x2A,0x02,0x22,0x06,0x20,0x02,0x00,0x00,
  37. 0x44,0x10,0x44,0x30,0xFC,0x1F,0x46,0x08,0x44,0x48,0x00,0x48,0xFE,0x44,0x92,0x44,--理
  38. 0x92,0x44,0xFE,0x7F,0x92,0x44,0x92,0x46,0xFF,0x44,0x02,0x60,0x00,0x40,0x00,0x00,
  39. 0x00,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0xFC,0x3F,--工
  40. 0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x06,0x20,0x04,0x30,0x00,0x20,0x00,0x00,
  41. 0x80,0x00,0x80,0x40,0x40,0x40,0x20,0x4A,0x50,0x52,0x48,0x62,0x44,0x42,0xC3,0x7F,--姓   0x44,0x42,0x68,0x62,0x50,0x52,0x20,0x4A,0x40,0x60,0xC0,0x40,0x40,0x00,0x00,0x00,
  42. 0x10,0x00,0x10,0x80,0x10,0x40,0x10,0x30,0x10,0x0C,0x90,0x23,0x7F,0x20,0x10,0x10,--名0xF0,0x3F,0x12,0x44,0x14,0x42,0x10,0x41,0xD0,0x40,0x18,0x40,0x10,0x78,0x00,0x00,
  43. 0x80,0x00,0x40,0x00,0x20,0x00,0xF8,0xFF,0x87,0x00,0x40,0x00,0x30,0x00,0x0F,0x00,--作
  44. 0xF8,0xFF,0x88,0x08,0x88,0x08,0xC8,0x08,0x88,0x0C,0x0C,0x08,0x08,0x00,0x00,0x00,
  45. 0x00,0x00,0x00,0xFF,0x00,0x41,0x7E,0x41,0x22,0x41,0x22,0x41,0xA2,0xFF,0x22,0x01,--品
  46. 0x22,0xFF,0x22,0x41,0x22,0x41,0x7F,0x41,0x02,0x41,0x80,0xFF,0x00,0x01,0x00,0x00,
  47. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x7C,0x3B,0xFE,--!
  48. 0x3B,0xFE,0x10,0x7C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  49. 0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,-圖
  50. 0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,
  51. 0x00,0x01,0x40,0x00,0x10,0x00,0x04,0x00,0x01,0x00,0x04,0x00,0x10,0x00,0x40,0x00,
  52. 0x00,0x01,0x00,0x04,0x00,0x10,0x00,0x04,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,
  53. 0x00,0x01,0x40,0x00,0x10,0x00,0x04,0x00,0x01,0x00,0x04,0x00,0x10,0x00,0x40,0x00,-案
  54. 0x00,0x01,0x00,0x04,0x00,0x10,0x00,0x04,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,
  55. 0xF0,0x00,0x08,0x01,0x14,0x02,0x52,0x04,0x12,0x08,0x12,0x10,0x24,0x22,0x58,0x55,
  56. 0x88,0x68,0x04,0x20,0x12,0x10,0x12,0x08,0x52,0x04,0x14,0x02,0x08,0x01,0xF0,0x00
  57. };
  58. unsigned char code  saomiao[]=--字幕掃描數(shù)組
  59. {
  60.   0x00,0x01,0x00,0x02,0x00,0x04,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x40,0x00,0x80,
  61.   0x01,0x00,0x02,0x00,0x04,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x40,0x00,0x80,0x00
  62. };
  63. unsigned char tone_l_h[]={0xf0,0xf9,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc};--底音高8位頻率
  64. unsigned char tone_l_l[]={0xf0,0x21,0xe0,0x8b,0xd7,0x68,0xe8,0x5b};--底音低8位頻率
  65. unsigned char tone_m_h[]={0xf0,0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe};--中音高8位頻率
  66. unsigned char tone_m_l[]={0xf0,0x8f,0xef,0x45,0x6c,0xb5,0xf5,0x2e};--中音低8位頻率
  67. unsigned char tone_h_h[]={0xf0,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xff};--高音高8位頻率
  68. unsigned char tone_h_l[]={0xf0,0x47,0x77,0xa2,0xb6,0xda,0xfa,0x16};--高音低8位頻率
  69. unsigned char code number[]={0xc0,0xf9,0xa4,0xb0,0X99,0X92,0X82,0Xf8,0X80,0X90};--數(shù)碼管顯示0~9
  70. unsigned char tone_yin[]={0xf7,0xbf,0xfe};--低中高音節(jié)數(shù)碼管顯示
  71. unsigned char *s=saomiao,*h=hanzi,*w,*t,flog1=0,flog2=0,x,m,count,TH_M0,TL_M0,n;
  72. unsigned int cx;
  73. void delay(unsigned int num)--普通延時(shí)函數(shù),用于調(diào)整音調(diào)
  74. {
  75.   unsigned int z;
  76.   for(z=0;z<num;z++)
  77.   {;}
  78. }
  79. delay_1()--倒計(jì)時(shí)延時(shí)函數(shù),可控制執(zhí)行次數(shù),用于控制字幕滾動(dòng)速度
  80. {
  81.   cx--;
  82.   if(cx!=0) return(1);
  83.   if(cx==0) return(0);
  84.   }
  85. void write_1(unsigned char byte)--字模寄存器寫入(根據(jù)點(diǎn)陣特點(diǎn),調(diào)整輸出次序)
  86. {
  87.   unsigned char i;
  88.   for(i=0;i<8;i++)
  89.    {
  90.     SRCK_1=0;
  91.     if((byte&0x01)==0)
  92.       SER_IN_1=0;
  93.     else SER_IN_1=1;
  94.      SRCK_1=1;
  95.      byte=byte>>1;
  96.    }
  97.   SRCK_1=0;
  98. }
  99. void write_2(unsigned char byte)--掃描行寄存器寫入
  100. {
  101.   unsigned char i;
  102.   for(i=0;i<8;i++)
  103.    {
  104.     SRCK_2=0;
  105.     if((byte&0x80)==0)
  106.          SER_IN_2=0;
  107.     else SER_IN_2=1;
  108.     SRCK_2=1;
  109.     byte=byte<<1;
  110.     }
  111.   SRCK_2=0;
  112. }
  113. void scan()--執(zhí)行一次,掃描一行
  114.   {
  115.     unsigned char j;
  116.     flog1++;
  117.     if(flog1==17)
  118.       {
  119.         flog1=1;
  120.         s=saomiao;
  121.       }
  122.     for(j=0;j<2;j++)
  123.       {
  124.         write_2(*(s++));
  125.       }
  126.
  127.   }
  128. void gundong(unsigned char n)--每次賦值是輸入2個(gè)值,n從1開始,產(chǎn)生滾動(dòng)
  129. {
  130.   unsigned char j;
  131.   if(flog2==0)
  132.     {
  133.      t=&hanzi[2*(n-1)];
  134.      if(n<=((num-1)*16+1))
  135.        {
  136.          w=&hanzi[2*(n-1)+32];
  137.        }
  138.       else
  139.        {
  140.          w=&hanzi[2*(n-1)-2*(num-1)*16];--每次只顯示16位,32個(gè)字節(jié),w是尾地址
  141.        }
  142.      h=t;
  143.      flog2++;
  144.     }
  145.      if(h==w)--他和下面的IF不可調(diào)換次序
  146.     {
  147.      h=t;
  148.     }
  149.     if(h==(hanzi+num*32))
  150.     {
  151.      h=hanzi;
  152.     }
  153.   for(j=0;j<2;j++)
  154.     {
  155.      write_1(*(h++));
  156.     }
  157. }
  158. main()
  159. {
  160.   unsigned char i;
  161.   cx=speed;
  162.   SRCK_1=0;
  163.   SRCK_2=0;
  164.   RCK=0;--清零很重要???
  165.   n=0;
  166.   EA=1;--打開中斷
  167.   ET0=1;
  168.   ET1=1;--易錯(cuò)點(diǎn),定時(shí)器打開,中斷也得開
  169.   TMOD=0x11;--打開定時(shí)器
  170.   TR0=1;
  171.   TR1=1;
  172.   PT0=1;--優(yōu)先級(jí)設(shè)定
  173.   while(1)
  174.     {
  175.      for(i=0;i<song_num;i++)
  176.        {
  177.          x=song[i];
  178.          m=song[i]/10;
  179.          switch(m)--分中底高位賦值
  180.            {
  181.              case 0:{TH_M0=tone_l_h[x];TL_M0=tone_l_l[x];break;}
  182.              case 1:{TH_M0=tone_m_h[x];TL_M0=tone_m_l[x];break;}
  183.              case 2:{TH_M0=tone_h_h[x];TL_M0=tone_h_l[x];break;}
  184.            }
  185.          TH0=TH_M0;
  186.          TL0=TL_M0;
  187.          delay(song_speed[i]*20);--節(jié)奏控制
  188.       }
  189.    }
  190. }
  191. void play_music(void) interrupt 1 --輸出音樂函數(shù)+數(shù)碼輸出函數(shù)
  192. {
  193. TH0=TH_M0;
  194. TL0=TL_M0;
  195. if(x!=0) buz=!buz;
  196. if(x==0) buz=0;
  197. count++;
  198. if(count==1)
  199.   {
  200.    DIG1=0;
  201.    DIG2=1;
  202.    P0=tone_yin[m];
  203.   }
  204. if(count==2)
  205. {
  206.   count=0;
  207.   DIG1=1;
  208.   DIG2=0;
  209.   P0=number[x];
  210. }
  211. }
  212. void play(void) interrupt 3
  213. {
  214.   if(n==(num*16))
  215.     {
  216.      n=0;
  217.     }
  218.   n++;
  219.   while(delay_1())
  220.     {
  221.      gundong(n);
  222.      scan();
  223.      RCK=0;
  224.      RCK=1;
  225.     }
  226.   flog1=0;
  227.   flog2=0;
  228.   cx=speed;
  229.   s=saomiao;
  230.   TH1=0xEF;--放后面,防止不準(zhǔn)
  231.   TL1=0xEF;
  232.   TF1=0;
  233. }
評(píng)分
參與人數(shù) 1黑幣 +8 收起 理由
xwnc + 8 很給力!
查看全部評(píng)分
收藏收藏2 分享淘帖 頂 踩
ID:98494 發(fā)表于 2015-12-11 18:45 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
無效樓層,該帖已經(jīng)被刪除
ID:99700 發(fā)表于 2015-12-20 23:45 來自觸屏版 | 只看該作者
很酷耶,電路圖能不能分享一下呢,我也想做一個(gè)
ID:70042 發(fā)表于 2015-12-22 08:42 | 只看該作者
不錯(cuò),有時(shí)間自己也做一個(gè)玩玩
ID:99700 發(fā)表于 2015-12-22 10:26 來自觸屏版 | 只看該作者
請(qǐng)問有原理圖能供參考一下么
ID:100555 發(fā)表于 2015-12-26 00:15 | 只看該作者
頂一個(gè) 有沒有電路圖了 謝謝
ID:1 發(fā)表于 2015-12-26 00:43 | 只看該作者
meinv 發(fā)表于 2015-12-22 10:26
請(qǐng)問有原理圖能供參考一下么
你可以參考這個(gè)圖,改下端口即可
  1. #include <reg52.h>
  3. uchar i,j,k=15;
  4. sbit  xsi=P2^0;
  5. sbit  xrck=P2^1;
  6. sbit  xsck=P2^2;
  7. sbit  ysi=P2^3;
  8. sbit  yrck=P2^4;
  9. sbit  ysck=P2^5;
  10. sbit kg= P3^2;
  11. uchar code zbm[][32]={
  12. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  13. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,},
  14. {0xFF,0xFF,0xFF,0xF7,0xBF,0xF7,0xBF,0xFB,0xBF,0xFD,0x03,0xE0,0xFF,0xFF,0xFF,0xFF,
  15. 0x01,0xF0,0x7F,0xEF,0xBF,0xEF,0x9F,0xEF,0xDF,0xEF,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF},/*"北",0*/
  16. {0xF7,0xFF,0xF7,0xFF,0xF7,0xEF,0xF7,0xF3,0x37,0xFF,0xB7,0xFE,0xB6,0xDE,0xD5,0x80,
  17. 0xDB,0xFE,0x5B,0xFF,0x9B,0xFB,0xFB,0xF7,0xFB,0xE7,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF},/*"京",1*/
  18. {0xFF,0xEF,0x5F,0xF7,0xDF,0xFA,0xEF,0xFD,0x0F,0xFA,0xFF,0xDF,0xBF,0xEF,0xC7,0xF3,
  19. 0x58,0xFC,0xEF,0xFB,0xAF,0xF7,0xCF,0xEF,0xEF,0xCF,0xFF,0xDF,0xFF,0xDF,0xFF,0xFF},/*"歡",2*/
  20. {0xBF,0xF7,0xBF,0xF7,0xBB,0xF6,0x37,0xF1,0xFF,0xF7,0x07,0xF6,0xF7,0xF6,0x7B,0xF7,
  21. 0xF9,0xEF,0x0F,0xE8,0xF7,0xEF,0x77,0xCF,0x07,0xCF,0xFF,0xEF,0xFF,0xEF,0xFF,0xFF},/*"迎",3*/
  22. {0xFF,0xFE,0x7F,0xFF,0xBF,0xFF,0x0F,0xC0,0xF1,0xFF,0xFF,0xF7,0xBF,0xF9,0xCF,0xEF,
  23. 0xD1,0xDF,0x5F,0xC0,0xEF,0xFF,0xAF,0xFD,0xCF,0xFB,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF},/*"你",4*/
  24. 0x87,0xFF,0x03,0xFF,0x01,0xFE,0x00,0xF8,0x01,0xF0,0x01,0xE0,0x03,0x80,0x07,0x00,
  25. 0x07,0x00,0x03,0x80,0x01,0xE0,0x01,0xF0,0x00,0xF8,0x01,0xFE,0x03,0xFF,0x87,0xFF,/*"心",5*/
  26. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  27. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,},
  28. };
  29. uchar code zbm1[][16]={
  30. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  31. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,},
  32. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xC0,0x6F,0xDB,0x63,0xEB,0x6C,0xEB},
  33. {0xEF,0xEF,0xEF,0xDF,0x0F,0x80,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*"自",0*/
  34. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x3B,0xF0,0xBB,0xEF,0xBB,0xEF,0xBB,0xEF,0xDD,0xEF},
  35. {0xCD,0xEF,0xF1,0xEF,0xFF,0xEF,0xFF,0xEF,0xFF,0xEF,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF},/*"己",1*/
  36. {0x7F,0xFF,0xBF,0xFF,0x0F,0xC0,0xD1,0xFF,0xDF,0xF1,0x01,0xF6,0xEF,0xF6,0xEF,0xE8},
  37. {0x3F,0xF7,0xCF,0xFA,0xD1,0xFD,0x1F,0xFA,0xEF,0xE7,0xEF,0xEF,0xFF,0xEF,0xFF,0xFF},/*"做",2*/
  38. {0xFF,0xFF,0x3F,0xF8,0x9F,0xE6,0xAF,0xF6,0xD3,0xF7,0x1F,0xE0,0x7F,0xFF,0xBF,0xFF},
  39. {0x5F,0xFF,0xC7,0xFC,0xD9,0xEF,0xEF,0xDF,0x0F,0xE0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*"的",3*/
  40. {0xFF,0xFF,0x3F,0xCF,0x3F,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*":",4*/
  41. {0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xDF,0xFF,0xCF,0xFF,0xFF},/*"L",0*/
  42. {0xF7,0xDF,0x07,0xC0,0x77,0xDF,0x77,0xDF,0x17,0xDC,0xF7,0xDF,0xEF,0xE7,0xFF,0xFF},/*"E",1*/
  43. {0xF7,0xDF,0x07,0xC0,0xF7,0xDF,0xF7,0xDF,0xF7,0xDF,0xEF,0xEF,0x1F,0xF0,0xFF,0xFF},/*"D",2*/
  44. {0xFF,0xDF,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,0x7F,0xF4,0x7F,0xED,0x81,0xFD,0xB7,0xFD},
  45. {0xB7,0xF5,0xBB,0xED,0x3B,0xFE,0xFF,0xF7,0xFF,0xEF,0xFF,0xCF,0xFF,0xFF,0xFF,0xFF},/*"點(diǎn)",3*/
  46. {0xFF,0xFF,0x03,0xE0,0xBB,0xFF,0x6D,0xFF,0x11,0xFB,0xFF,0xFB,0x37,0xFB,0x57,0xFB},
  47. {0x67,0xFB,0x19,0x80,0xBB,0xFD,0xBB,0xFD,0xBF,0xFD,0xFF,0xFD,0xFF,0xFD,0xFF,0xFF},/*"陣",4*/
  48. {0xFF,0xEF,0xFF,0xF7,0xFF,0xF9,0x7F,0xFE,0x81,0xBD,0x75,0xDD,0x65,0xE5,0x55,0xF8},
  49. {0xB6,0xFD,0x9A,0xFD,0x28,0x80,0xBC,0xFE,0xBF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFF},/*"屏",5*/
  50. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},
  51. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,},
  52. };
  53. void ys (uchar a) //延時(shí)
  54. {
  55. uchar b;
  56. for (;a>0;a--)
  57. for (b=100;b>0;b--) ;
  58. }
  59. void yfs() //Y軸發(fā)數(shù)
  60. {
  61. ysck=0;
  62. yrck=0;
  63. k++;
  64. if (k==16)
  65. {
  66. k=0;
  67. ysi=0;
  68. }
  69. else
  70. ysi=1;
  71. ysck=1;
  72. P2=P2|0X14;
  73. //相當(dāng)于   xrck=1;  yrck=1;
  74. }
  75. void xfs(uchar a)   //X軸發(fā)數(shù)
  76. {
  77. uchar b,a1,a2;
  78. a1=~zbm[6][a*2+1];
  79. a2=~zbm[6][a*2];
  80. xsck=0;
  81. xrck=0;
  82. for (b=0;b<8;b++)
  83. {
  84. a1=a1<<1;
  85. xsi=CY;
  86. xsck=1;
  87. xsck=0;
  88. }
  89. for (b=0;b<8;b++)
  90. {
  91. a2=a2<<1;
  92. xsi=CY;
  93. xsck=1;
  94. xsck=0;
  95. }
  96. }
  97. void  fs(uchar a)      //X軸發(fā)數(shù)
  98. {
  99. uchar b;
  100. xsck=0;
  101. xrck=0;
  102. for (b=0;b<8;b++)
  103. {
  104. a=a<<1;
  105. xsi=CY;
  106. xsck=1;
  107. xsck=0;
  108. }
  109. }
  110. void gdhs(uchar *zz,uchar N,uchar Time) //流動(dòng)顯示N個(gè)漢字    滾動(dòng)函數(shù)
  111. { //參數(shù)三個(gè):字符串字模首地址、字?jǐn)?shù)、顯示流動(dòng)速度
  112. uchar FontNum,i,j,row; //循環(huán)變量,字?jǐn)?shù)計(jì)數(shù)、16次流動(dòng)、16列掃描
  113. for(FontNum=0;FontNum<N;FontNum++)
  114. {
  115. for(i=0;i<16;i++) //字到字流動(dòng) 16次左移才能完成
  116. {
  117. for(j=0;j<Time;j++) //顯示延遲,決定流動(dòng)速度
  118. {
  119. k=15;
  120. for(row=0;row<16;row++) //顯示16*16屏幕一次
  121. {
  122. yfs(); //選通顯示列  //行選線,P3 低四位
  123. fs (~*(zz+FontNum*32+(i+row)*2+1)); //以移動(dòng)偏移為基礎(chǔ)獲取新數(shù)據(jù)
  124. fs(~*(zz+FontNum*32+(i+row)*2)); //獲取顯示數(shù)據(jù) 循環(huán)顯示關(guān)鍵算法
  125. ys (12); //適當(dāng)延時(shí)
  126. }
  127. }
  128. }
  129. }
  130. }
  131. void wbzd ()  interrupt   0   //外部中斷
  132. {
  133.   j++;
  134.   if (j>1)
  135.   j=0;
  136.   ys(10);
  137.   while (!kg)
  138.   {
  139.    k=15;
  140.   for (i=0;i<16;i++)
  141.   {
  142.    yfs();
  143.    xfs(i);
  144. ys(10);
  145.    }
  146.   }
  147. if (j==0)
  148.    gdhs(zbm,8,2);
  149. if (j==1)
  150. gdhs(zbm1,10,1);
  151. }
  152. void main ()
  153. {
  154. EA = 1; //打開總中斷
  155. EX0=1;
  156. IT0=1;
  157. while (1)
  158. {
  159.      if (j==0)
  160.    gdhs(zbm,8,5);
  161.   if (j==1)
  162.      gdhs(zbm1,10,3);
  163. }
  164. }
ID:119015 發(fā)表于 2016-5-8 13:47 | 只看該作者
admin 發(fā)表于 2015-12-26 00:43
你可以參考這個(gè)圖,改下端口即可
電路圖不完整啊啊啊啊啊啊啊啊啊啊啊啊啊
ID:126077 發(fā)表于 2016-6-10 12:00 | 只看該作者
樓主能不能給發(fā)一下點(diǎn)陣的仿真圖,急求
ID:142098 發(fā)表于 2016-10-18 17:36 | 只看該作者
發(fā)個(gè)壓縮包不是更好一點(diǎn)?
ID:143435 發(fā)表于 2016-10-19 16:52 | 只看該作者
看起來很有趣  試試
ID:148523 發(fā)表于 2016-11-17 22:12 | 只看該作者
電路圖呢
