#include<reg52.h>
sbit IN1=P2^0;
sbit ENA=P2^1;
sbit IN2=P2^2;
sbit IN4=P2^3;
sbit ENB=P2^4;
sbit IN3=P2^5;
sbit hw1=P1^0;
sbit hw2=P1^1;
sbit hw3=P1^2;
sbit hw4=P1^3;
uchar PWM1=0 ; //**右邊電機(jī)的占空比**//
uchar PWM2=0 ; //**左邊電機(jī)的占空比**//
uchar num=0; //**定時器中斷計(jì)數(shù)器**//
uchar flag;
void init()
TMOD=0x01;
TH0=(65536-50)/256;
TL0=(65536-50)%256;
EA=1;
ET0=1;
TR0=1;
IN1=0;
IN2=0;
IN3=0;
IN4=0;
init();
if(hw1||hw2||hw3||hw4)//如果檢測到信號
if(hw1&&hw2&&hw3&&hw4)
ENA=0;
ENB=0;
if(hw1&&!hw2&&!hw3&&!hw4)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=0;
PWM2=15;
flag=1;
if(!hw1&&hw2&&!hw3&&!hw4)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=0;
PWM2=13;
flag=2;
if(!hw1&&!hw2&&hw3&&!hw4)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=13;
PWM2=0;
flag=3;
if(!hw1&&!hw2&&!hw3&&hw4)
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=15;
PWM2=0;
flag=4;
else //如果檢測不到信號
switch(flag)
case 1:
// IN1=1;
// IN2=0;
// IN3=1;
// IN4=0;
// PWM1=10;
// PWM2=5;
IN1=0;
IN2=1;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
//flag=0;
} break;
case 2:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 3:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=8;
PWM2=8;
flag=0;
} break;
case 4:
IN1=1;
IN2=0;
IN3=0;
IN4=1;
PWM1=12;
PWM2=12;
// flag=0;
} break;
default:
IN1=1;
IN2=0;
IN3=1;
IN4=0;
PWM1=12;
PWM2=12;
void timer0() interrupt 1
TH0=(65536-50)/256;
TL0=(65536-50)%256;
num++;
if(num>=40)num=0;
if(num<PWM1)ENA=1;
else ENA=0;
if(num<PWM2)ENB=1;
else ENB=0;
