查看: 5843|回復: 0
STM32之SYSCLK滴答精確延時程序 寄存器實現
ID:82781 發表于 2015-6-14 03:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
要知道時間對程序來說也是生命!該延時的要延時,不該延時的不能延時,操作器件不也就是操作時序嗎?,所以延時是非常重要的,但是ARM的運算速度非常快,用普通單片機似的延時恐怕。。。,很難算得很精確,這就出來了滴答時鐘,他和內核在一塊,方便的時鐘選擇,簡單的寄存器,就搞定。
本程是查詢程序,下一步亞用中斷實現!
值得注意的是我沒找到庫函數!所以采用的是操作寄存器實現的!
SYSCLK=72mhz
  1. #include "main.h"
  2. GPIO_InitTypeDef GPIO_InitStructure;
  3. void mysysint()//系統初始化程序
  4. {
  5. ErrorStatus HSEStartUpStatus;//說明標志位
  6. RCC_DeInit();//所有外設全部缺省設置
  7. /* Enable HSE */
  8. RCC_HSEConfig(RCC_HSE_ON);
  9. /* Wait till HSE is ready and if Time out is reached exit */
  10. HSEStartUpStatus = RCC_WaitForHSEStartUp();
  11. if(HSEStartUpStatus == SUCCESS)//啟動成功
  12. {
  13. /*這兩條FLASH指令必須加上,不知為啥?不加上就運行幾秒后出錯,參照系統初始化*/
  14. /* Enable The Prefetch Buffer */
  15. FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);//FLASH緩存開啟
  16. /* Configure the Latency cycle: Set 2 Latency cycles */
  17.   FLASH_SetLatency(FLASH_Latency_2);  //設置FLASH這些位表示SYSCLK(系統時鐘)周期與閃存訪問時間的比例,為010:兩個等待狀態,當 48MHz < SYSCLK ≤ 72MHz
  18. /* Set PLL clock output to 72MHz using HSE (8MHz) as entry clock */
  19. RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//外部時鐘為8M,PLL的輸入時鐘=8MHZ,倍頻系數9,
  20. /* Configure HCLK such as HCLK = SYSCLK */
  21. RCC_HCLKConfig(RCC_SYSCLK_Div1);//設置了啦AHB分頻器的分頻系數=1,即HCLK=SYSCLK=72MHZ
  22. /* Configure PCLK1 such as PCLK1 = HCLK/2 */
  23. RCC_PCLK1Config(RCC_HCLK_Div2);//設置了APB1外設的時鐘頻率最大是36M這里是APB1的分頻器設為2,PCLK1=HCLK/2=72/2=36MHZ正好是最大值
  24. /* Configure PCLK2 such as PCLK2 = HCLK */
  25. RCC_PCLK2Config(RCC_HCLK_Div1);//設置PLCK2=HCLK=72MHZ,的APB2分頻器=1
  26. /* Select the PLL as system clock source */
  27. RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//設置了SYSCLK的提供者為PLL,頻率由上面算出=72MHZ
  28. /* disable PLL Ready interrupt */
  29. RCC_ITConfig(RCC_IT_PLLRDY, DISABLE);//PLL中斷關閉
  30. /* disable PLL Ready interrupt */
  31. RCC_ITConfig(RCC_IT_HSERDY,DISABLE);//HSE中斷關閉
  32. /* disable PLL Ready interrupt */
  33. RCC_ITConfig(RCC_IT_HSIRDY, DISABLE); //HSI中斷關閉
  34. /* disable PLL Ready interrupt */
  35. RCC_ITConfig(RCC_IT_LSERDY, DISABLE); //LSE中斷關閉
  36. /* disable PLL Ready interrupt */
  37. RCC_ITConfig(RCC_IT_LSIRDY, DISABLE); //LSI中斷關閉
  38. /* PLL clock divided by 1.5 used as USB clock source */
  39. RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);//設置USB的時鐘為=72、1.5=48mhz
  40. /* Configure ADCCLK such as ADCCLK = PCLK2/2 */
  41. RCC_ADCCLKConfig(RCC_PCLK2_Div2);//設置ADC時鐘=PCLK2/2= 36MHZ
  42. /* disable the LSE */
  43. RCC_LSEConfig(RCC_LSE_OFF);//外部低速晶振關閉
  44. /*DISable the RTC clock */
  45. RCC_RTCCLKCmd(DISABLE);
  46. /* DISable the Clock Security System */
  47. RCC_ClockSecuritySystemCmd(DISABLE);
  48. /* Enable the PLL */
  49. RCC_PLLCmd(ENABLE);//使能PLL
  50. /* PLL ans system clock config */
  51. }
  52. else
  53. {
  54. /* Add here some code to deal with this error */
  55. }
  56. }
  57. /** @addtogroup STM32F10x_StdPeriph_Examples
  58.   * @{
  59.   */
  60. /** @addtogroup SysTick_TimeBase
  61.   * @{
  62.   */
  63. /* Private typedef -----------------------------------------------------------*/
  64. /* Private define ------------------------------------------------------------*/
  65. /* Private macro -------------------------------------------------------------*/
  66. /* Private variables ---------------------------------------------------------*/
  67. static __IO uint32_t TimingDelay;
  68. /* Private function prototypes -----------------------------------------------*/
  69. void Delay(__IO uint32_t nTime);
  70. /* Private functions ---------------------------------------------------------*/
  71. /**
  72.   * @brief  Main program.
  73.   * @param  None
  74.   * @retval None
  75.   */
  76. void wang_mySYStick_init()
  77. {
  78. //SysTick->LOAD=72000; //53MHZ下定時1ms
  79. SysTick->LOAD  = 72000;
  80. SysTick->CTRL=0x00000005;//表示HCLK=SYStick時鐘,開啟滴答,關閉中斷
  81. }
  82. /*
  83. *此函數為滴答時鐘的查詢函數,不斷地在查詢標志位!!!
  84. *
  85. *  王均偉
  86. *
  87. * 形參為時間值,延時時間=TIME*1毫秒
  88. */
  89. void mydelay(unsigned int time) //20110725他媽的我沒找到關于這個版本的庫函數,直接對寄存器操作了、反而感覺更親切了。很想51
  90. {
  91. unsigned long a,b;
  92.    while(time)
  93.    {
  94.      a=SysTick->CTRL;
  95.   b=a&0x00010000;
  96.    if(b==0x00010000)
  97.    {
  98.     SysTick->LOAD  = 72000-1;  //用的72MHZ時鐘,一直使用的話要減一。。。
  99.   time--;
  100.    }
  101.    }
  102. }
  103. int main(void)
  104. {
  105. mysysint();//系統初始化程序
  106. /* GPIOD Periph clock enable */
  107.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);//使能時鐘
  108. /* Configure PD0 and PD2 in output pushpull mode */
  109.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9| GPIO_Pin_10| GPIO_Pin_11;
  110.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  111.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  112.   GPIO_Init(GPIOD, &GPIO_InitStructure);
  113. wang_mySYStick_init();//滴答初始化!
  114.   while(1)
  115.   {
  116.       /* Set the GPIOA port pin 10 and pin 15 */
  117.   GPIO_SetBits(GPIOD,  GPIO_Pin_8);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
  118. mydelay(100);
  119.    /* Clears the GPIOA port pin 10 and pin 15 */
  120.     GPIO_ResetBits(GPIOD,  GPIO_Pin_8);//GPIOD->BRR  = 0x00000f00;
  121. mydelay(100);
  122.   /* Set the GPIOA port pin 10 and pin 15 */
  123.   GPIO_SetBits(GPIOD, GPIO_Pin_9);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
  124. mydelay(100);
  125.    /* Clears the GPIOA port pin 10 and pin 15 */
  126.     GPIO_ResetBits(GPIOD,  GPIO_Pin_9);//GPIOD->BRR  = 0x00000f00;
  127. mydelay(100);
  128.   /* Set the GPIOA port pin 10 and pin 15 */
  129.   GPIO_SetBits(GPIOD, GPIO_Pin_10);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
  130. mydelay(100);
  131.    /* Clears the GPIOA port pin 10 and pin 15 */
  132.     GPIO_ResetBits(GPIOD,  GPIO_Pin_10);//GPIOD->BRR  = 0x00000f00;
  133.   mydelay(100);
  134.   /* Set the GPIOA port pin 10 and pin 15 */
  135.   GPIO_SetBits(GPIOD, GPIO_Pin_11);//GPIOD->BSRR = 0x00000f00;//置為PD8-PD11
  136. mydelay(100);
  137.    /* Clears the GPIOA port pin 10 and pin 15 */
  138.     GPIO_ResetBits(GPIOD,  GPIO_Pin_11);//GPIOD->BRR  = 0x00000f00;
  139. mydelay(100);
  140.   }
