//實(shí)現(xiàn)串口中斷接收HAO三個(gè)字符,如果接收成功,PB0-PB7輪流點(diǎn)亮一次,并返回OK\r\n。如果
//接收3個(gè)字或者更多字符錯(cuò)誤就返回ERR\r\n.使用1MHz內(nèi)部RC震蕩。
#include <iom16v.H>
#include <macros.h>
uchar flag=0;
uchar REC_count;
uchar Receive_Data2[3]={'0','0','0'};
//uchar REC_count=0;
void delay_ms(uint i)
uint j,k;
for(k=0;k<i;k++)
for(j=0;j<3000;j++);
NOP();
//發(fā)送子函數(shù)
void USART_Transmit( unsigned char data )
/* 等待發(fā)送緩沖器為空 */
while ( !( UCSRA & (1<<UDRE)) );
/* 將數(shù)據(jù)放入緩沖器,發(fā)送數(shù)據(jù) */
UDR = data;
//USART初始化子函數(shù)
void USART_init()
UCSRB = 0x00; /*允許接收和發(fā)送*/
UCSRA = 0x02; /*倍速*/
UCSRC = 0x86; /*8位數(shù)據(jù)*/
UBRRL = 12; /*9600*/
UBRRH = 0x00;
UCSRB = 0x98; /*允許接收和發(fā)送*/
//串口接收中斷
#pragma interrupt_handler USART_RXC:12
void USART_RXC(void)
uchar sreg;
sreg=SREG;
Receive_Data2[REC_count]=UDR;
REC_count++;
if(REC_count==3)
flag=2;
REC_count=0;
SREG=sreg;
void main(void)
uchar i;
uchar Receive_Data1[3]={'H','A','O'};
DDRA=0x00;
PORTA=0xFF;
DDRB=0xFF;
PORTB=0xFF;
DDRD=0xFF;
PORTD=0xFF;
CLI();
USART_init();
SEI();
switch(flag)
case 1: //接收成功后的狀態(tài)
for(i=0;i<8;i++)
PORTB=~(1<<i);
delay_ms(50);
flag=0;
break;
case 2: //判斷接收的字符是否正確
for(i=0;i<3;i++)
if(Receive_Data1[ i]!=Receive_Data2)
break;
if(i==3)
USART_Transmit('O' );//接收成功發(fā)送OK\r\n
USART_Transmit('K' );
USART_Transmit('\r' );
USART_Transmit('\n' );
flag=1;
flag=0;
USART_Transmit('E' );
USART_Transmit('R' );
REC_count=0;
break;
default: //沒(méi)有接收或者接收錯(cuò)誤后的操作
PORTB=0xFF;
delay_ms(50);
PORTB=0x00;
delay_ms(50);
break;
