查看: 4996|回復: 1
LCD1602終于點亮了 上程序和電路圖
ID:82781 發表于 2015-6-13 20:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
uint dxf[8]; //定義一個數組,用于顯示秒高低位、 分高低位、 時高低位及冒號
uint num1,num2,num3,num4,num5,num6,count1;           //count1用于中斷50MS時間到判斷
uint fk0,fk1,fk2,fk3,fk4,fk5,fk6,fk7,ab1,ab2,ab3,ab4,ab5,ab6;
sbit LCDEn=P0^2;
sbit RS11=P0^0;
sbit rw=P0^1;
unsigned char code table[]={"HELLO 2015  "};
unsigned char code table1[]={"we are study:  "};
unsigned char code tab12[]={'0','1','2','3','4','5','6','7','8','9'}; //用于液晶顯示調用
unsigned char code tab13[]={":"} ;
unsigned char code tab11[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//用于數碼顯示調用
void delay2(num2)  //長延時
   uchar aa1;
   for(;num2>0;num2--)
    for(aa1=120;aa1>0;aa1--)
void T01() interrupt 1  /*****定時器T0中斷子程序*****/
    count1++ ;
   if(count1==4)
              num4++;
           count1=0;
  TH0=(65535-50000)/256;  /*******50ms定時器,高八位******/
  TL0= (65535-50000)%256;
void delay(unsigned int m )
   unsigned char n;        /****局部定義**/
   for(;m>1;m--)
    for(n=60;n>0;n--)
void okplay(  )// 開顯示
        uchar aa2;
   for(aa2=1;aa2<9;aa2++)
               if(num4==60)
                  num5++;
                if(num5==60)
                  num6++;
                   if(num6==24)
                          num6=0;
                  num5=0;
                 num4=0;
            switch(aa2)
         case 1:  dxf[0]=num6/10;          break;
         case 2:  dxf[1]=num6%10;        break;
         case 3:  dxf[2]=0[tab13] ;          break;
         case 4:  dxf[3]=num5/10;                 break;
         case 5:  dxf[4]=num5%10;        break;
         case 6:  dxf[5]=0[tab13] ;            break;
         case 7:  dxf[6]=num4/10;        break;
         case 8:  dxf[7]=num4%10;    P1=dxf[7][tab11]; P3=0X20;     break;
void lowcom(unsigned char a) /****寫命令**/
             LCDEn=0;
          RS11=0;
          rw=0;
          P2=a;
          delay(2);
          LCDEn=1;
          delay(2);
          LCDEn=0;
void lowwrite(uchar ab) /****寫數據**/
             LCDEn=0;
          RS11=1;
          rw=0;
          P2=ab;
          delay(2);
          LCDEn=1;
          delay(2);
          LCDEn=0;
/********初始化程序********/
void invion()
        lowcom(0x38); /****開顯示**/
        delay(2);
        lowcom(0x0f); /****初始化**/
        delay(2);
        lowcom(0x06);  /***寫一個指針數加1**/
        delay(2);
        lowcom(0x0C);/****開顯示不顯光標**/
        delay(2);
        unsigned char xx1,xx2;
        TMOD=0X01;
        TH0=(65535-50000)/256;  /*******5ms定時器,高八位******/
        EA=1; /******開總中斷******/
        ET0=1;/******允許T0中斷******/
        TR0=1; /*******T0中斷開始******/
        invion(); /****初始化**/
                              okplay();
                          lowcom(0x80);/****顯示第一行從第1 位開始顯示**/
                for(xx1=0;xx1<8;xx1++)
                                   //原顯示lowwrite( dxf[xx1][tab12]),因冒號無法顯示改為switch語句
                             switch(xx1)
                          case 0:lowwrite( dxf[xx1][tab12]); break ;
                          case 1: lowwrite(dxf[xx1][tab12]); break;
                          case 2: lowwrite(dxf[0][tab13]);   break;         //顯示冒號
                          case 3: lowwrite(dxf[xx1][tab12]); break;
                          case 4: lowwrite(dxf[xx1][tab12]); break;
                          case 5: lowwrite(dxf[0][tab13]);   break;        //顯示冒號
                          case 6: lowwrite(dxf[xx1][tab12]); break;
                          case 7: lowwrite(dxf[xx1][tab12]); break;
                           lowcom(0x80+0X40);/****顯示第二行靜態顯示**/
              for(xx2=0;xx2<14;xx2++)
                           lowwrite(table1[xx2]);
                        delay(10);
真的越來越難越來越要花好多的時間了----------真的是智商快到極限了---------如何12864TFF彩屏呢
ID:157057 發表于 2017-4-14 22:02 | 只看該作者
樓主的12864 已經成功了吧。
