查看: 5313|回復: 3
基于51單片機的紅外遙控簡易LCD12864菜單程序(四項 八項)
ID:82083 發表于 2015-6-6 15:06 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 qinqin 于 2015-6-6 15:11 編輯
本程序已通過實際電路測試
四項菜單程序:
  1. #include<reg52.h>
  3. sbit rs=P1^0;  // lcd12864 RS端
  4. sbit rw=P1^1;  // lcd12864 RW端
  5. sbit en=P1^2; // lcd12864 EN端
  6. sbit ultra_red=P3^3;  //紅外接受端
  7. uchar cc=0;   //指針
  8. uchar dat[4];    //紅外線信號數據存放單元:dat[0]存放用戶碼;dat[1]存放用戶反碼;dat[2]存放數據碼;dat[3]存放數據反碼。
  9. bit r;    //指針
  10. uchar code user1[]={"北京城市學院"};
  11. uchar code user2[]={"08級本科"};
  12. uchar code user3[]={"微電子"};
  13. uchar code user4[]={"王云"};
  14. uchar code table1[]={"菜單1 "};
  15. uchar code table2[]={"菜單2 "};
  16. uchar code table3[]={"菜單3 "};
  17. uchar code table4[]={"菜單4 "};
  18. uchar code tt1[]={0x08,0x20,0x08,0x20,0xFF,0xFE,0x08,0x20,0x00,0x10,0x00,0xF8,0x3F,0x00,0x11,0x10,
  19.                    0x08,0x20,0x01,0x00,0x7F,0xFC,0x05,0x40,0x09,0x20,0x31,0x18,0xC1,0x06,0x01,0x00,}; //“菜”
  20. uchar code tt2[]={0x10,0x10,0x08,0x20,0x04,0x40,0x3F,0xF8,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,
  21.                   0x21,0x08,0x3F,0xF8,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00};//“單”
  22. uchar code tt3[]={0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x70,0x00,0x10,0x00,0x10,0x00,0x10,0x00,
  23.                    0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x7C,0x00,0x00,0x00,0x00,0x00};//“1”
  24. uchar code tt4[]={0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x04,0x00,
  25.                   0x04,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x42,0x00,0x7E,0x00,0x00,0x00,0x00,0x00};//“2”
  26. uchar code tt5[]={0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x42,0x00,0x42,0x00,0x04,0x00,0x18,0x00,
  27.                    0x04,0x00,0x02,0x00,0x02,0x00,0x42,0x00,0x44,0x00,0x38,0x00,0x00,0x00,0x00,0x00};//“3”
  28. uchar code tt6[]={0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,0x00,0x14,0x00,0x24,0x00,0x24,0x00,
  29.                    0x44,0x00,0x44,0x00,0x7E,0x00,0x04,0x00,0x04,0x00,0x1E,0x00,0x00,0x00,0x00,0x00};//“4”
  30. ////////////////////////////////////////////////////////  延時程序
  31. void delay(uchar H,uchar L)
  32. {  TH0=H;TL0=L;
  33.    TF0=0;
  34.    while(!TF0);
  35. }
  36. //////////////////////////////////////////////////  lcd12864寫指令程序
  37. void w_comd(uchar dat)
  38. {   en=1;rs=0;rw=0;
  39.     P0=dat;
  40.     delay(0xff,0xb8);
  41.     en=0;   // en從1變到0,指令寫入
  42.     delay(0xff,0xb8);
  43. }
  44. //////////////////////////////////////  lcd12864寫數據程序
  45. void w_data(uchar dat)
  46. {   en=1;rs=1;rw=0;
  47.     P0=dat;
  48.     delay(0xff,0xb8);
  49.     en=0;// en從1變到0,數據寫入
  50.     delay(0xff,0xb8);
  51. }
  52. ///////////////////////////////////////////////////////// 初始化lcd12864
  53. void set_lcd12864()
  54. {   w_comd(0x01);  //清屏
  55.     delay(0xee,0x08);
  56.     w_comd(0x30);  //設定基本指令
  57.     w_comd(0x0c);
  58.     w_comd(0x06);
  59.     w_comd(0x02);
  60.     delay(0xee,0x08);
  61. }
  62. ///////////////////////////////////////////////////// 顯示程序段
  63. void view(uchar addr,uchar *i)
  64. {   w_comd(addr);    //寫入行列地址
  65.     while(*i!='\0')  // 指針所指內容不為空循環
  66.       {  w_data(*i);
  67.   i++;
  68.       }
  69. }
  70. ///////////////////////////////////////////////////////  cgram數據寫入程序段
  71. void cgram_data(uchar addr,uchar *i)
  72. {   uchar a;
  73.     w_comd(addr); //地址寫入
  74.     for(a=0;a<32;a++) //寫入32個8位數據
  75.        w_data(0xff-(*i++)); //為反白輸出,所以此處采用0XFF減原有數據,達到翻白效果
  76. }                           //(用程序翻白,只能使一三行,或二四行同時翻白)
  77. ///////////////////////////////////////////  顯示自定義字符
  78. void cgram_display(uchar addr,uchar z)
  79. { w_comd(addr);  //寫入行列地址
  80. w_data(0x00); //不知道為什么,必需得寫,不然就會出錯
  81. w_data(z);   //對應編碼寫入,編碼一定要與寫入cgram地址一一對應,不然也會出錯
  82. }
  83. /////////////////////////////////////////////////////// 寫cgram數據程序
  84. void cgram()
  85. {   view(0x83,table1);
  86.     view(0x93,table2);
  87.     view(0x8b,table3);
  88.     view(0x9b,table4);
  89.     w_comd(0x30);
  90.     w_comd(0x02);//允許修改cgram地址
  91.     delay(0xee,0x08);
  92.     switch(cc)
  93.        {   case 0:  cgram_data(0x40,tt1);
  94.                  cgram_display(0x83,0x00);
  95.                  cgram_data(0x50,tt2);
  96.    cgram_display(0x84,0x02);
  97.    cgram_data(0x60,tt3);
  98.    cgram_display(0x85,0x04);
  99.    break;
  100.     case 1: cgram_data(0x40,tt1);
  101.           cgram_display(0x93,0x00);
  102.                  cgram_data(0x50,tt2);
  103.    cgram_display(0x94,0x02);
  104.    cgram_data(0x60,tt4);
  105.    cgram_display(0x95,0x04);
  106.    break;
  107.            case 2:  cgram_data(0x40,tt1);
  108.           cgram_display(0x8b,0x00);
  109.                  cgram_data(0x50,tt2);
  110.    cgram_display(0x8c,0x02);
  111.    cgram_data(0x60,tt5);
  112.    cgram_display(0x8d,0x04);
  113.    break;
  114.            case 3: cgram_data(0x40,tt1);
  115.           cgram_display(0x9b,0x00);
  116.                  cgram_data(0x50,tt2);
  117.           cgram_display(0x9c,0x02);
  118.    cgram_data(0x60,tt6);
  119.           cgram_display(0x9d,0x04);
  120.    break;
  121.            default:     break;
  122.     }
  123. }
  124. ////////////////////////////////////////////
  125. void display()
  126. {   cgram();
  127. }
  128. ////////////////////////////////////////////////
  129. void main()
  130. {   uchar i;
  131.     TMOD=0x01;  //啟用定時器0方式1
  132.     TR0=1;  //啟動定時器0
  133.     EA=1;   //開總中斷
  134.     set_lcd12864();//初始化LCD12864
  135.     view(0x81,user1);
  136. for(i=10;i>0;i--)
  137.    delay(0x15,0xa0);
  138.     view(0x92,user2);
  139. for(i=10;i>0;i--)
  140.    delay(0x15,0xa0);
  141. view(0x8b,user3);
  142. for(i=10;i>0;i--)
  143.    delay(0x15,0xa0);
  144. view(0x9b,user4);
  145. for(i=50;i>0;i--)
  146.    delay(0x15,0xa0);
  147. w_comd(0x01);
  148. delay(0xee,0x08);
  149.     while(1)
  150.        {
  151.     r=0;
  152. delay(0x3c,0xb0);
  153.     display();
  154. dat[4]=0;
  155.     EX1=1;
  156.     while(!r)  //  等待中斷
  157.                delay(0xff,0x9c);
  158.        }
  159. }
  160. ////////////////////////////////////////  紅外中斷程序
  161. void int1()interrupt 2
  162. {   uchar i,j,n=0;
  163.     dat[4]=0;
  164.     EX1=0; //必須將中斷關閉,否則將無法準確解讀
  165. delay(0xf8,0x30);
  166. if(ultra_red)  //延時2ms后判斷是否為高電平,若是,則跳出中斷(紅外發射端發射信號以9ms高電平開始,接收端接受信號與發射信號相反)
  167.     {  r=1;
  168.        delay(0x15,0xa0);
  169.        return;
  170.     }
  171. while(!ultra_red) delay(0xff,0x9c);//等待9ms低電平
  172. while(ultra_red) delay(0xff,0x9c); //等待4.5ms高電平
  173. for(i=0;i<4;i++)
  174.     for(j=0;j<8;j++)
  175.       {  while(!ultra_red) delay(0xff,0x9c); //等待0.56ms的低電平區
  176.        while(ultra_red)
  177.        {  delay(0xff,0x9c);  //每0.1ms,指針n自加1
  178.        n++;
  179.     }
  180.     dat[i]>>=1;    //最高位寫入0
  181.     if(n>6) dat[i]=dat[i]|0x80;  //若n>6,說明高電平持續時間大于0.56ms,則將高位置1
  182.     n=0;  //指針清零
  183.    }
  184. if(dat[2]==~dat[3])   //若數據碼與數據反碼的非相同,說明解碼成功
  185.     {   switch(dat[2])
  186.           {  case 0x01: cc=0;break;//根據自己的紅外發射器編碼
  187.       case 0x02: cc=1;break;
  188.       case 0x03: cc=2;break;
  189.       case 0x04: cc=3;break;
  190.       default:break;
  191.     }
八項菜單程序:
  7. uchar cc=0;   //指針
  9. bit r;    //指針
  18. uchar code table5[]={"菜單5 "};
  19. uchar code table6[]={"菜單6 "};
  20. uchar code table7[]={"菜單7 "};
  21. uchar code table8[]={"菜單8 "};
  22. uchar code tt1[]={0x08,0x20,0x08,0x20,0xFF,0xFE,0x08,0x20,0x00,0x10,0x00,0xF8,0x3F,0x00,0x11,0x10,
  23.                    0x08,0x20,0x01,0x00,0x7F,0xFC,0x05,0x40,0x09,0x20,0x31,0x18,0xC1,0x06,0x01,0x00,}; //“菜”
  24. uchar code tt2[]={0x10,0x10,0x08,0x20,0x04,0x40,0x3F,0xF8,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,
  25.                   0x21,0x08,0x3F,0xF8,0x01,0x00,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00};//“單”
  26. uchar code tt3[]={0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x70,0x00,0x10,0x00,0x10,0x00,0x10,0x00,
  27.                    0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x7C,0x00,0x00,0x00,0x00,0x00};//“1”
  28. uchar code tt4[]={0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x04,0x00,
  29.                   0x04,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x42,0x00,0x7E,0x00,0x00,0x00,0x00,0x00};//“2”
  30. uchar code tt5[]={0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x42,0x00,0x42,0x00,0x04,0x00,0x18,0x00,
  31.                    0x04,0x00,0x02,0x00,0x02,0x00,0x42,0x00,0x44,0x00,0x38,0x00,0x00,0x00,0x00,0x00};//“3”
  32. uchar code tt6[]={0x00,0x00,0x00,0x00,0x00,0x00,0x04,0x00,0x0C,0x00,0x14,0x00,0x24,0x00,0x24,0x00,
  33.                    0x44,0x00,0x44,0x00,0x7E,0x00,0x04,0x00,0x04,0x00,0x1E,0x00,0x00,0x00,0x00,0x00};//“4”
  34. uchar code tt7[]={0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x40,0x00,0x40,0x00,0x40,0x00,0x58,0x00,
  35.                    0x64,0x00,0x02,0x00,0x02,0x00,0x42,0x00,0x44,0x00,0x38,0x00,0x00,0x00,0x00,0x00,};//"5"
  36. uchar code tt8[]={0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,0x24,0x00,0x40,0x00,0x40,0x00,0x58,0x00,
  37.                    0x64,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x24,0x00,0x18,0x00,0x00,0x00,0x00,0x00,};//"6"
  38. uchar code tt9[]={0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x00,0x44,0x00,0x44,0x00,0x08,0x00,0x08,0x00,
  39.                    0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x10,0x00,0x00,0x00,0x00,0x00,};//"7"
  40. uchar code tt10[]={0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x24,0x00,
  41.                     0x18,0x00,0x24,0x00,0x42,0x00,0x42,0x00,0x42,0x00,0x3C,0x00,0x00,0x00,0x00,0x00,};//"8"
  42. ////////////////////////////////////////////////////////  延時程序
  43. void delay(uchar H,uchar L)
  44. {  TH0=H;TL0=L;
  45.    TF0=0;
  46.    while(!TF0);
  47. }
  48. //////////////////////////////////////////////////  lcd12864寫指令程序
  49. void w_comd(uchar dat)
  50. {   en=1;rs=0;rw=0;
  51.     P0=dat;
  52.     delay(0xff,0xb8);
  53.     en=0;   // en從1變到0,指令寫入
  54.     delay(0xff,0xb8);
  55. }
  56. //////////////////////////////////////  lcd12864寫數據程序
  57. void w_data(uchar dat)
  58. {   en=1;rs=1;rw=0;
  59.     P0=dat;
  60.     delay(0xff,0xb8);
  61.     en=0;// en從1變到0,數據寫入
  62.     delay(0xff,0xb8);
  63. }
  64. ///////////////////////////////////////////////////////// 初始化lcd12864
  65. void set_lcd12864()
  66. {   w_comd(0x01);  //清屏
  67.     delay(0xee,0x08);
  68.     w_comd(0x30);  //設定基本指令
  69.     w_comd(0x0c);
  70.     w_comd(0x06);
  71.     w_comd(0x02);
  72.     delay(0xee,0x08);
  73. }
  74. ///////////////////////////////////////////////////// 顯示程序段
  75. void view(uchar addr,uchar *i)
  76. {   w_comd(addr);    //寫入行列地址
  77.     while(*i!='\0')  // 指針所指內容不為空循環
  78.       {  w_data(*i);
  79.   i++;
  80.       }
  81. }
  82. ///////////////////////////////////////////////////////  cgram數據寫入程序段
  83. void cgram_data(uchar addr,uchar *i)
  84. {   uchar a;
  85.     w_comd(addr); //地址寫入
  86.     for(a=0;a<32;a++) //寫入32個8位數據
  87.        w_data(0xff-(*i++)); //為反白輸出,所以此處采用0XFF減原有數據,達到翻白效果
  88. }                           //(用程序翻白,只能使一三行,或二四行同時翻白)
  89. ///////////////////////////////////////////  顯示自定義字符
  90. void cgram_display(uchar addr,uchar z)
  91. { w_comd(addr);  //寫入行列地址
  92. w_data(0x00); //不知道為什么,必需得寫,不然就會出錯
  93. w_data(z);   //對應編碼寫入,編碼一定要與寫入cgram地址一一對應,不然也會出錯
  94. }
  95. /////////////////////////////////////////////////////// 寫cgram數據程序
  96. void cgram()
  97. {   view(0x80,table1);
  98.     view(0x90,table2);
  99.     view(0x88,table3);
  100.     view(0x98,table4);
  101. view(0x84,table5);
  102. view(0x94,table6);
  103. view(0x8c,table7);
  104. view(0x9c,table8);
  105.     w_comd(0x30);
  106.     w_comd(0x02);//允許修改cgram地址
  107.     delay(0xee,0x08);
  108.     switch(cc)
  109.        {   case 0:  cgram_data(0x40,tt1);
  110.                  cgram_display(0x80,0x00);
  111.                  cgram_data(0x50,tt2);
  112.    cgram_display(0x81,0x02);
  113.    cgram_data(0x60,tt3);
  114.    cgram_display(0x82,0x04);
  115.    break;
  116.     case 1: cgram_data(0x40,tt1);
  117.           cgram_display(0x90,0x00);
  118.                  cgram_data(0x50,tt2);
  119.    cgram_display(0x91,0x02);
  120.    cgram_data(0x60,tt4);
  121.    cgram_display(0x92,0x04);
  122.    break;
  123.            case 2:  cgram_data(0x40,tt1);
  124.           cgram_display(0x88,0x00);
  125.                  cgram_data(0x50,tt2);
  126.    cgram_display(0x89,0x02);
  127.    cgram_data(0x60,tt5);
  128.    cgram_display(0x8a,0x04);
  129.    break;
  130.            case 3: cgram_data(0x40,tt1);
  131.           cgram_display(0x98,0x00);
  132.                  cgram_data(0x50,tt2);
  133.           cgram_display(0x99,0x02);
  134.    cgram_data(0x60,tt6);
  135.           cgram_display(0x9a,0x04);
  136.    break;
  137.           case 4: cgram_data(0x40,tt1);
  138.           cgram_display(0x84,0x00);
  139.                  cgram_data(0x50,tt2);
  140.           cgram_display(0x85,0x02);
  141.    cgram_data(0x60,tt7);
  142.           cgram_display(0x86,0x04);
  143.    break;
  144.           case 5: cgram_data(0x40,tt1);
  145.           cgram_display(0x94,0x00);
  146.                  cgram_data(0x50,tt2);
  147.           cgram_display(0x95,0x02);
  148.    cgram_data(0x60,tt8);
  149.           cgram_display(0x96,0x04);
  150.    break;
  151.           case 6: cgram_data(0x40,tt1);
  152.           cgram_display(0x8c,0x00);
  153.                  cgram_data(0x50,tt2);
  154.           cgram_display(0x8d,0x02);
  155.    cgram_data(0x60,tt9);
  156.           cgram_display(0x8e,0x04);
  157.    break;
  158.           case 7: cgram_data(0x40,tt1);
  159.           cgram_display(0x9c,0x00);
  160.                  cgram_data(0x50,tt2);
  161.           cgram_display(0x9d,0x02);
  162.    cgram_data(0x60,tt10);
  163.           cgram_display(0x9e,0x04);
  164.    break;
  165.            default:     break;
  166.     }
  167. }
  168. ////////////////////////////////////////////
  169. void display()
  170. {   cgram();
  171. }
  172. ////////////////////////////////////////////////
  173. void main()
  174. {   uchar i;
  175.     TMOD=0x01;  //啟用定時器0方式1
  176.     TR0=1;  //啟動定時器0
  177.     EA=1;   //開總中斷
  178.     set_lcd12864();//初始化LCD12864
  179.     view(0x81,user1);
  180. for(i=10;i>0;i--)
  181.    delay(0x15,0xa0);
  182.     view(0x92,user2);
  183. for(i=10;i>0;i--)
  184.    delay(0x15,0xa0);
  185. view(0x8b,user3);
  186. for(i=10;i>0;i--)
  187.    delay(0x15,0xa0);
  188. view(0x9b,user4);
  189. for(i=50;i>0;i--)
  190.    delay(0x15,0xa0);
  191. w_comd(0x01);
  192. delay(0xee,0x08);
  193.     while(1)
  194.        {
  195.     r=0;
  196. delay(0x3c,0xb0);
  197.     display();
  198. dat[4]=0;
  199.     EX1=1;
  200.     while(!r)  //  等待中斷
  201.                delay(0xff,0x9c);
  202.        }
  203. }
  204. ////////////////////////////////////////  紅外中斷程序
  205. void int1()interrupt 2
  206. {   uchar i,j,n=0;
  207.     dat[4]=0;
  208.     EX1=0; //必須將中斷關閉,否則將無法準確解讀
  209. delay(0xf8,0x30);
  210. if(ultra_red)  //延時2ms后判斷是否為高電平,若是,則跳出中斷(紅外發射端發射信號以9ms高電平開始,接收端接受信號與發射信號相反)
  211.     {  r=1;
  212.        delay(0x15,0xa0);
  213.        return;
  214.     }
  215. while(!ultra_red) delay(0xff,0x9c);//等待9ms低電平
  216. while(ultra_red) delay(0xff,0x9c); //等待4.5ms高電平
  217. for(i=0;i<4;i++)
  218.     for(j=0;j<8;j++)
  219.       {  while(!ultra_red) delay(0xff,0x9c); //等待0.56ms的低電平區
  220.        while(ultra_red)
  221.        {  delay(0xff,0x9c);  //每0.1ms,指針n自加1
  222.        n++;
  223.     }
  224.     dat[i]>>=1;    //最高位寫入0
  225.     if(n>6) dat[i]=dat[i]|0x80;  //若n>6,說明高電平持續時間大于0.56ms,則將高位置1
  226.     n=0;  //指針清零
  227.    }
  228. if(dat[2]==~dat[3])   //若數據碼與數據反碼的非相同,說明解碼成功
  229.     {   switch(dat[2])
  230.           {  case 0x01: cc=0;break;
  231.       case 0x02: cc=1;break;
  232.       case 0x03: cc=2;break;
  233.       case 0x04: cc=3;break;
  234.    case 0x05: cc=4;break;
  235.    case 0x06: cc=5;break;
  236.    case 0x07: cc=6;break;
  237.    case 0x08: cc=7;break;
  238.    case 0x09: cc=8;break;
  239.       default:break;
  240.     }
ID:82331 發表于 2015-6-7 17:48 | 只看該作者
幫頂~~~~~~~~~~~~~~~~~~~~~~~~
ID:406128 發表于 2018-11-8 09:29 | 只看該作者
樓主可否打包資料上傳給我們看看
ID:362076 發表于 2018-11-11 19:50 | 只看該作者
這個程序只是演示作用,樓主并沒有預留出功能控制的位置和接口,而且也沒有考慮到每一級菜單的長度問題,例如一個菜單是“射頻卡管理”這五個字,那么你菜單的位置就放不下啦,同時,多級菜單的思路也沒有體現。
