查看: 2807|回復: 0
矩陣鍵盤程序
ID:82008 發表于 2015-6-5 00:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit duxu=P2^6;
sbit wexu=P2^7;
uchar temp,num;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
        duxu=1;
        P0=0;
        duxu=0;
        wexu=1;
        P0=0xc0;
        wexu=0;
                P3=0xfe;
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P3;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xee:num=1;
                                        break;
                                        case 0xde:num=2;
                                        break;
                                        case 0xbe:num=3;
                                        break;
                                        case 0x7e:num=4;
                                        break;
                                while(temp!=0xf0)
                                        temp=P3;
                                        temp=temp&0xf0;
                        duxu=1;
                        P0=table[num-1];
                        duxu=0;
                P3=0xfd;
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P3;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xed:num=5;
                                        break;
                                        case 0xdd:num=6;
                                        break;
                                        case 0xbd:num=7;
                                        break;
                                        case 0x7d:num=8;
                                        break;
                                while(temp!=0xf0)
                                        temp=P3;
                                        temp=temp&0xf0;
                        duxu=1;
                        P0=table[num-1];
                        duxu=0;
                P3=0xfb;
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P3;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xeb:num=9;
                                        break;
                                        case 0xdb:num=10;
                                        break;
                                        case 0xbb:num=11;
                                        break;
                                        case 0x7b:num=12;
                                        break;
                                while(temp!=0xf0)
                                        temp=P3;
                                        temp=temp&0xf0;
                        duxu=1;
                        P0=table[num-1];
                        duxu=0;
                P3=0xf7;
                temp=P3;
                temp=temp&0xf0;
                if(temp!=0xf0)
                        delay(5);
                        temp=P3;
                        temp=temp&0xf0;
                        if(temp!=0xf0)
                                temp=P3;
                                switch(temp)
                                        case 0xe7:num=13;
                                        break;
                                        case 0xd7:num=14;
                                        break;
                                        case 0xb7:num=15;
                                        break;
                                        case 0x77:num=16;
                                        break;
                                while(temp!=0xf0)
                                        temp=P3;
                                        temp=temp&0xf0;
                        duxu=1;
                        P0=table[num-1];
                        duxu=0;
