查看: 2445|回復: 0
1602液晶的驅動案例
ID:82008 發表于 2015-6-5 00:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
uchar code table[]="Yin Jian Jun !";
uchar code table1[]="TEL: 18755359012";
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit dula=P2^6;
sbit wela=P2^7;
uchar num;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        dula=0;
        wela=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0e);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80+0x10);
        init();
        for(num=0;num<14;num++)
                write_data(table[num]);
                delay(20);
//        write_com(1);
        write_com(0x80+0x50);
        for(num=0;num<16;num++)
                write_data(table1[num]);
                delay(20);
                write_com(0x18);
                delay(20);
        delay(20000);
        write_com(0x01);
        while(1);
