fyd12864-0204b 液晶 st7920控制器 程序燒進去 ,本來輸入的是 “ 床前明月光,疑是地上霜。舉頭望明月,低頭思故鄉! 可是卻顯示 “ 黨潛明彰廣一 由飼蒂上雙。摳頭望明彰一 低頭私顧鄉!蔽覄倢W單片機,在此請教大家了。以下是我用的程序,字數對,位置也對,就是字錯。 #include<reg52.h> #include<intrins.h> //#include<stdlib.h> //rand(); #define uint unsigned int #define uchar unsigned char
#define LCD_data P0; sbit LCD_RS =P2^6; sbit LCD_RW =P2^5; sbit LCD_EN =P2^7; sbit LCD_PSB = P3^2; sbit wela =P1^2; sbit dula=P1^3;
//uchar dis1[10]; uchar code dis1[]={"床前明月光,"}; uchar code dis2[]={"疑是地上霜。"}; uchar code dis3[]={"舉頭望明月,"}; uchar code dis4[]={"低頭思故鄉。"}; void delay_1ms(uint x) { uint i,j; for(j=0;j<x;j++) for(i=0;i<110;i++); } void write_cmd(uchar cmd) { LCD_RS=0; LCD_RW=0; LCD_EN=0; P0=cmd; delay_1ms(5); LCD_EN = 1; delay_1ms(5); LCD_EN= 0; }
void write_dat(uchar dat) { LCD_RS = 1; LCD_RW= 0; LCD_EN= 0; P0=dat; delay_1ms(5); LCD_EN= 1; delay_1ms(5); LCD_EN= 0; }
void lcd_pos(uchar X,uchar Y) { uchar pos; if(X==0) {X=0x80;} else if(X==1) {X=0x90;} else if(X==2) {X=0x88;} else if(X==3) {X=0x98;} pos= X+Y; write_cmd(pos); }
void lcd_init() { LCD_PSB=1; write_cmd(0x30); delay_1ms(5); write_cmd(0x0c); delay_1ms(5); write_cmd(0x01); delay_1ms(5); }
void main() { uchar i; wela=0; dula=0; delay_1ms(5); lcd_init();
while(1) { lcd_pos(0,0); i=0; while(dis1!='\0') { write_dat(dis1); i++; }
lcd_pos(1,0); i=0; while(dis2!='\0') { write_dat(dis2); i++; } delay_1ms(10);
lcd_pos(2,0); i=0; while(dis3!='\0') { write_dat(dis3); i++; } delay_1ms(10);
lcd_pos(3,0); i=0; while(dis4!='\0') { write_dat(dis4); i++; } delay_1ms(10); }
//delay_1ms(10);
