查看: 3582|回復(fù): 0
atmega16 f (ds18b20_init(0,25,35,DS18B20_12BIT_RES))
ID:80779 發(fā)表于 2015-5-24 16:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <mega16.h>
#include <delay.h>
#include <stdlib.h>
// 1 Wire Bus functions
#asm
   .equ __w1_port=0x12 ;PORTD
   .equ __w1_bit=5
#endasm
#include <1wire.h>
// DS1820 Temperature Sensor functions
#include <ds18b20.h>
// Alphanumeric LCD Module functions
#asm
   .equ __lcd_port=0x18 ;PORTB
#endasm
#include <lcd.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
unsigned char string[6];
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// 1 Wire Bus initialization
w1_init();
// LCD module initialization
lcd_init(8);
/* set the temperature alarms & temperature
   measurement resolutions for all the devices
   temp_low=25 temp_high=35 resolution 12bits */
if (ds18b20_init(0,25,35,DS18B20_12BIT_RES))
       lcd_putsf("INIT OK"); else lcd_putsf("INIT ERR");
delay_ms(1000);
while (1)
     ftoa( ds18b20_temperature(0),2,string);
     lcd_clear();
     lcd_putsf("TEMP NOW") ;
     lcd_gotoxy(2,1) ;
     lcd_puts(string);
這段程序關(guān)于
這兩個地方不是特別懂
